Roscoe, I pulled your #1 float bowl to put in a box with your brake bits, and the darn thing is missing the overflow stem. I've sent a PM to John(jtb) inquiring about his, so hopefully this is just a hiccup.
I really should have pulled the bowl and checked first, but I had no reason to think that the stem would be absent. The other three are there, must be a production line problem with the worker in charge of producing the #1 carbs. I'll send an email to Sochiro right away
No problem mate. I drilled out the broken stem and got some brass tubing from the hobby shop. It was a slightly smaller dia so I "Tinned" the tube with solder and pressed it in. I also soldered up the hole then redrilled a smaller one. I filled it with petrol and left it for a day sitting on white paper. No leaks so hopefully that will work. Fingers crossed.
Let me know if you get a reply from Sochiro. It'll be worth millions.
Cheers
Roscoe
