Author Topic: Wheel swaps???  (Read 1030 times)
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
Wheel swaps???
« on: March 15, 2008, 12:18:52 PM »
Does any one know if you can put a dual disk K wheel on a 78f front end? Are the hubs the same width? Is the spacing of the disks ( Disk off set ) K verses F the same width for the calipers to line up?? (K dual disk front wheel to 78F front tubes) Thanks for any input!
                                         Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Offline eurban
Re: Wheel swaps???
« Reply #1 on: March 15, 2008, 06:26:19 PM »
Swapping the spoke K wheels onto a F2/F3 is not straightforward.  The K rotors are larger diameter, thicker and not of the same off set as the Fs rotors. They will not directly work with your F calipers.  The F also uses a five bolt rotor while the Ks hub is setup for a six bolt.  This means that you can't swap the F rotors onto the K hub.  You also can't directly bolt on a pair of K calipers onto your Fs fork legs since the two are a completely different design (F is trailing, K is leading type) with different attachment method.   You could get a pair of K forks and slide them into your trees as they are both 35mm tubes.  You would then use K type calipers but this would be a significant retrograde move IMO.  My experience is that the Fs dual caliper setup offers much better braking than dual disc setups using K type calipers.  The K equipment is significantly heavier also. I have seen a few go through the machining process to get the K rotors sized and offset correctly to line up with the F2/F3 calipers but this is a good bit of work.
« Last Edit: March 15, 2008, 06:28:04 PM by eurban »
Offline Head
    • My Bikes
Re: Wheel swaps???
« Reply #2 on: March 16, 2008, 10:05:33 AM »
Thanks for the insight, With out having the parts on hand to do comparisons it is good to be able to get the answers!   Head
