Author Topic: Ignition setup- did I do it wrong?  (Read 925 times)
dudeman750
« on: March 24, 2008, 09:32:44 AM »
Hello gurus,
Does this setup sound ok on my 82 CB650SC?
Dyna 2.2ohm coils (grey) about 10 yrs old came on the bike
Copper core wires from napa new connectors
5k NGK caps new
DR8ESL plugs new
Im having probs with 1 firing weak and 4 not at all. Im thinking the coil is bad. Just ordered another Dyna 2.2ohm coil, but I can pick up a stock set of coils and wires on the cheap from ebay.
The PO put the dyna's on it. I have read a ton of posts about these ignitions. Mine is the electronic set up with CDI and no points.
Should this work well? I was just worried about resistor plugs and caps together.
Please drop me a line some guru!
