Author Topic: 400 f tensioner question  (Read 3164 times)
bbinovations@yahoo.com
« on: March 27, 2008, 10:33:48 PM »
I have looked through the FAQs and haven seen anything related.
I was going through my parts and found that the tensioner push rod the one that actually has the springs around it HAD a rubber piece bonded to it and is no longer bonded, honda doesn have this part anymore and was wondering if anyone had an alternative? or do I need to search for a used one?
jjwaller
Re: 400 f tensioner question
« Reply #1 on: March 28, 2008, 12:15:11 AM »
I've been through the honda parts manual and several online
parts fiches, and I can't find any reference to a rubber piece on the
tensioner push rod.  Previous mod perhaps?
Can't imagine why though.  There are 2 springs however.
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #2 on: March 28, 2008, 05:43:55 AM »
Yes the push rod is supposed to have the rubber piece bonded to it, if it's missing you will need to replace the push rod.
Also you won't find a part # for the rubber piece as it's part of the push rod.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #3 on: March 28, 2008, 11:49:53 AM »
I have just been through this on my 350F  :D
The replacement part is an upgraded design.... might have to search for one, I got mine from westernhillshondayamaha.com had one for about $25. Had it in their old stock. local dealer says it's discontinued:
 Matt.
Gallery at:
Offline ttr400
« Reply #4 on: March 28, 2008, 12:05:02 PM »
Hey Matt, thanks for posting that info. I have never seen that replacement part..do you have a part #. looks like I should make some of those if they are no longer available.
Kevin
www.ttr400.com
« Reply #5 on: March 28, 2008, 05:02:56 PM »
I know its not a sperate piece guys its bonded during assy I was just wondering if anyone had run into or found a workable replacement, I am going to have to search for some NOS, the 350 is the same good to know. I will give that honda place a yell on monday. worst case I will bond a new piece on there, todays adhesive tech is much better than back then.
thanks for the responses guys.... this is my first small motor street bike with valves so theres a lot more stuff to find.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #6 on: March 28, 2008, 06:37:52 PM »
Here's the part #
1974 CB350F is:
BAR
14550-369-020  (replaces 14550-369-010)
The 400F part # is different, so see if you can get the right one for your machine first, and if not, see if you can get this one. I'm pretty sure they're the same part.
Just go through the parts finder at their website to get the numbers:
http://www.westernhillshondayamaha.com/fiche_select.asp
That plastic piece you're talking about BBIN only came off on mine after I took it apart. I had to remove the adjustment bolt that had been broken off by the PO and it got broken in the process. I would'nt try gluing it it you can find one. If it comes apart later it's not easy to get at which you already know  ;)
 Matt.
Gallery at:
Offline heffay
« Reply #7 on: March 28, 2008, 06:48:28 PM »
do you have the part number for the 400?
i need one for each.   ;D  yes, they call me special... what's it to you?   :P
 ;D
Offline heffay
« Reply #8 on: March 28, 2008, 06:51:25 PM »
pretty sure i found it for the 400f...
BAR
14550-333-000
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #9 on: March 28, 2008, 06:52:41 PM »
 ;D
...you beat me  :P
1977 400F is:
BAR
14550-333-000
...there's gonna be a race to find these things. Glad I already have mine  ;D
Gallery at:
Offline ttr400
« Reply #10 on: March 28, 2008, 10:09:49 PM »
The same part will work in both bikes. good to know about the different part #'s.
Kevin
www.ttr400.com
charlevoix418
« Reply #11 on: March 29, 2008, 06:50:15 AM »
Here's the part #
1974 CB350F is:
BAR
 Matt.
Matt,
I have the Part List from Honda4Fun and I don't see the number you are giving (14550-369-020).
I only found 14550-333-000 (Bar, cam chain tensioner push):  is it the item you are talking about???
Raynald
Offline heffay
« Reply #12 on: March 29, 2008, 09:29:40 AM »
since its fairly agreed that the 350f and 400f part is the same... they may only carry the one.
Offline ttr400
« Reply #13 on: March 29, 2008, 10:16:15 AM »
Did a bit of digging around and found out that part # 14550-369-020 is a CB360 part. now I do know the 360 uses the same tensioner set up as the 350/400F. plus I see it was superceded from 369-000 and 369-010.
Plus the 369-020 is listed as a superceded part for the 350F but not for the 400F. It still lists the 333 # for the 400F, now which part came first?
What year did the CB360 come out?
I have a 350F motor and various 400F motors here and that part for both motors is identical.
Maybe some one else has some more info..?
Kevin
www.ttr400.com
charlevoix418
« Reply #14 on: March 29, 2008, 11:02:19 AM »
To Hondaman or other:
Quote:  "IIRC, the shorter one on the right was the ones used in the retrofitted tensioner's bodies. The longer one on the left came out the following year, when a fully redesigned tensioner with adjusting bolt was fitted to the second model year of the bike. I think that's the same ones that ended up on the 400F, but I didn't work on enough of those to remember...  ".
Question:  does it mean that to do a proper job, not only I would have to buy p/n 14550-369-020 (Bar), but also the "Fully redesigned tensioner with adjusting bolt"
What would be the Part Numbers required?
My bike is a CB350F 1973 No. CB350F1053779.
Raynald from Canada
Offline heffay
« Reply #15 on: March 29, 2008, 11:05:19 AM »
charle... just curious why you're talking to hondaman.   ???
also, where is that quote from?
Offline ttr400
« Reply #16 on: March 29, 2008, 12:19:52 PM »
You only have to find the push bar. no other parts need to be changed as the lock bolt and tensioner horseshoe shaped bracket are the same on all models. nothing changed in the design.
Kevin
www.ttr400.com
charlevoix418
« Reply #17 on: March 29, 2008, 03:18:31 PM »
All,
thank you for the info:  I ordered the part from Westernhill, about 18$.
 Humm...  Another question:  is that bar an item that will wear rapidly?  Should I keep another one as spare?
I put the name Hondaman on that thread because there is another thread on the site about the same topic.
Raynald from Canada
« Reply #18 on: March 29, 2008, 05:12:23 PM »
Order of production to the best of my knowledge CB350 four; CB 360 twin; CB400 four
« Reply #19 on: March 29, 2008, 09:55:48 PM »
hey guys I started this and after reading everything and a head full of PNs, I have checked with my Honda parts source and theyre showing it as no longer available?? western hills honda shows the PN and a price but I checked some other known not avalable parts and there site shows a price, I dont think there site is interactive with available stock or am I missing something. I am curious if anyone is getting a call that its not available. I'm thinking I may have to get one made or find a doner bike.
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #20 on: March 30, 2008, 07:26:17 AM »
Just wondering, if that small rubber piece is missing from the push rod, would I be getting some kind of an ticking or rattling noise?
 I know the 400f springs for the tensioner are always shot, but besides the poorly tighten cam chain and it's problem of
waring out fast, could this be causing the metallic rattle noise?
Just a theory!  ;D
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
