Author Topic: K0 Mudguard bracket help  (Read 3077 times)
Offline lordmoonpie
    • Moonpie
« on: March 28, 2008, 10:52:40 AM »
I need to make a one off bracket to fit a front race type fender to my 750. The caliper mounts are the original K0 type so I figure that all I need to do is make a mirror pair of brackets the same as the original K0 fender. Easiest way to do this would be to get a tracing of a single side bracket from a helpful 750 fan with a fender off the bike or in a parts store somewhere. Can anyone help?!?
It has to be a K0 type bracket as the size and mounts differ in the later K models sadly...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Online Terry in Australia
Re: K0 Mudguard bracket help
« Reply #1 on: March 29, 2008, 04:31:05 AM »
And if your K0 fender is too nice to chop up just for the bracket, just use one from a K1 or K2, they all use the same bracket. Cheers, Terry. ;D
Offline lordmoonpie
    • Moonpie
« Reply #2 on: March 29, 2008, 08:42:31 AM »
I guess K0-K2 fenders are more common on the other side of the pond to here in the UK, even Fleabay isn't showing anything....I'll keep looking >trudge<, >trudge<  :-\
1994 Ducati 888 SP5
« Reply #3 on: March 29, 2008, 04:15:48 PM »
If I had one to send you I would mate, but there are plenty in the US, one guy here was even trying to see a bracket that he just painted black and called a "fork brace" a year or two ago............ Just post a "Fender brace wanted" thread, and you'll get one. Cheers, Terry. ;D
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: March 31, 2008, 01:16:31 AM »
Here's a couple of rough tracings of the K0-K2 fender bracket, with dimensions.  Hope this helps.
mystic_1
- John Augustus Shedd
« Reply #5 on: March 31, 2008, 03:48:28 AM »
How good's that! Well done Mr Mystic, I might copy that with some thicker steel plate and make a real fork brace! ;D
Offline lordmoonpie
    • Moonpie
« Reply #6 on: March 31, 2008, 05:06:23 AM »
Superb! Thank you Mr Mystic, that's a massive help. I'll knock one out in card first and then work up from there.
being mr Hasty, I already had one go in 3mm stainless and it didn't quite work out! Man that stainless is hard to work though....
Much appreciated - let me know if I can return the favour with a sticker or two!?
1994 Ducati 888 SP5
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: March 31, 2008, 07:54:24 AM »
Sorry about the SAE measurements in the drawing, btw, I kept thinking I should be doing it all in metric but you know the story with the USA and the Metric System lol.  All my measuring devices are SAE.
I tried to be as accurate as possible but it was a bit tough without actually flattening out my bracket.  The tracing is reasonably accurate but I'm planning on double-checking all the measurements later tonight.  Also want to do a better front view diagram with better measurements.  I also was thinking I'll update the drawing to show more how the bracket is dished to clear the fork legs.
If you guys see any measurements or views I should add, just let me know.
Cheers
mystic_1
« Reply #8 on: March 31, 2008, 09:07:22 AM »
If you make them out of thicker it gets much more difficult.
I did make one out of 1/4 alum for a HD FXWG fender, but it took a long time.
If you want to really stiffen the fork, I started a post on how to easily make one.. can be made in a few hrs & works very well.
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: March 31, 2008, 03:06:38 PM »
OK, double-checked measurements, made some minor corrections for typos and added a few more dimensions.  Stock thickness is approximately 3/16".
Also added some shading for contrast.
mystic_1
« Reply #10 on: March 31, 2008, 07:04:52 PM »
I am thinking stock is more like 2.5 or 3mm..
Offline mystic_1
  • 1970 CB750K
« Reply #11 on: March 31, 2008, 08:29:27 PM »
Geeze I must be dyslexic today or something.  Meant 3/32.
mystic_1
Offline lordmoonpie
    • Moonpie
« Reply #12 on: April 01, 2008, 05:29:21 AM »
Thanks Mystic - looks perfect for what I need to do. I'll print it out and start the cardboard version today!  :)
1994 Ducati 888 SP5
