Author Topic: mystery hole in head  (Read 1243 times)
Tim
« on: August 15, 2005, 09:32:03 AM »
OK, it's all back together now without too many left over parts, and it runs good, but there must be at least one part I left out.  There is about a 1/4 in. dia hole in the head (CB500F), between the two inlet ports for the two middle carbs.  It does not appear to be threaded.  It opens into the timing chain space, I believe.  Should it be plugged?  Vented to somewhere?  Oil spits out this hole when the engine is running.
Thanks
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: mystery hole in head
« Reply #1 on: August 15, 2005, 09:46:15 AM »
That is the hole for the bolt that secures the top of your camchain tensioner. ( see pic )
« Last Edit: August 15, 2005, 09:50:03 AM by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: August 15, 2005, 10:37:21 AM »
If there's nothing in that hole, you might not have a tensioner in place  :o
Anything that looks like a green banana laying around?
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
