SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
1976 cb750 popping at idle
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1976 cb750 popping at idle (Read 2625 times)
muddykart04
Guest
on:
April 26, 2008, 06:59:55 PM »
hi, my 76' cb750 is popping at idle only im wondering if it is running lean on the pilot circuit. everything has been cleaned many times on the carbs and synced. bike runs perfect besides that. i also have the kerker 4 in 1 exhaust on the bike ( the carbs are all stock jets ) my air screw is out 1 3/4 turns. any suggestions??? exhaust header leaks???
Logged
scondon
No way my run was THAT slow, must be an
Old Timer
Mmmm......tasty bugs
Re: 1976 cb750 popping at idle
Reply #1 on:
April 26, 2008, 09:15:30 PM »
Enter "exhaust popping" in the search bar and you should find no less than thirty threads to help give you some ideas
Logged
JAG
Expert
'74 CB750K, '72 CB500, '76 550K
Reply #2 on:
April 27, 2008, 08:24:17 PM »
very true.. But had the same problems, try to tighten all your connections from the mufflers all the way to the headers, mine was doing it and it is usually caused by air escaping somewhere.
good luck with it!
Logged
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
