Author Topic: 93 Jeep XJ lost a driveshaft and more  (Read 1497 times)
Offline 78 k550
« on: May 07, 2008, 03:25:56 PM »
Hey All,
Well just out of nowhere I lost my rear driveshaft doing about 50. It also took out the rear yoke also. Got the rear yoke reaplace the rear tailcone housing took it out also. Well I couldn't just slip the new/used driveline on the rear output shaft of the t-case without loosinging the housing. I knew something was wrong then. Took off the housing and examined the shaft while running. Sure enough output shaft on the 231 t-case is bent. Go to my favorite yard and get a outputshaft I pulled myself. cost me 6.00
? is would you mess with my t-case with 246,000 miles or just score another that doesn't leak or is in good condition for 60.00 and do the swap.
Im thinking the latter since you have to split the cases to swap the output shaft.
93 Jeep XJ 3.5 RE superflex kit. running 31x10.5x15's
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
fuzzybutt
Re: 93 Jeep XJ lost a driveshaft and more
« Reply #1 on: May 07, 2008, 03:37:42 PM »
get a lower mileage less leaky unit is what i would do, i tried patching up the transfer case in an old f150 4x4 and every time i fixed one thing, something else would break.
Offline mrblasty
  • Expertly
« Reply #2 on: May 07, 2008, 08:58:51 PM »
I would go for the swap out, thats a lot of mileage.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline 74cb750
« Reply #3 on: May 08, 2008, 03:06:27 AM »
Is this a common problem, as a guy I worked w also had the same problem, but w more damage than what you describe as he was going faster on the highway.
michel
Laugh at least once a day.
Life  $ucks, then you die.
Offline 78 k550
« Reply #4 on: May 08, 2008, 06:13:06 AM »
Thanks all,
I'm going for the swap.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline hahnda
  • lskdfhs;dljksa;
« Reply #5 on: May 08, 2008, 06:18:28 AM »
How hard is is to change the CV joints on these? My '95 with 150k is popping alot in the joints. Then again I'm not sure I want to keep it. I have no floor left. The rest of the Jeep is fine but the floor is gone. If it wasn't for the carpet I could see the road.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline 333
  • Time for change
« Reply #6 on: May 08, 2008, 06:53:25 AM »
Flintstone brakes?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline 78 k550
« Reply #7 on: May 08, 2008, 04:20:43 PM »
Picked up one today. Look's like the swap is easyier.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline rugger81
« Reply #8 on: May 08, 2008, 10:21:19 PM »
I don't know xj's, but you might be able to get some help here: www.jeepforum.com  Just check the xj tech section.
'77 CB750K - Rebuild Project Page
'15 Moto Guzzi Griso
Offline 78 k550
« Reply #9 on: May 08, 2008, 11:21:37 PM »
If your floorboard are shot and you don't plan on putting a ton of work into it I would ditch it.
I will check it out thank's.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #10 on: May 08, 2008, 11:29:14 PM »
Don't know which jeep you have.  But, shouldn't be too hard to weld a new floor in.
http://www.jcwhitney.com/Floor-%28Passenger-Area%29/600015314.jcw
Offline hahnda
  • lskdfhs;dljksa;
« Reply #11 on: May 09, 2008, 06:24:54 AM »
I don't see any for a '95 XJ.
They salt the crap out of our roads here in WI. I think I'm just going to ditch it as it needs new shocks, new exhaust, new brakes, new u-joints and you can see through the floor. Still runs great though and starts easy at -30.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
