Author Topic: '78 K float level  (Read 840 times)
Offline KeithB
'78 K float level
« on: May 25, 2008, 08:05:52 AM »
Before I open the carbs AGAIN, has anyone found a good level for the floats on a '78K?
They run a bit lean and I want to richen it up a bit.
Nanahan Man
eldar
Re: '78 K float level
« Reply #1 on: May 25, 2008, 10:05:48 AM »
Well float height should be about 14.5mm or between 14 - 15mm. What is the reason for wanting to run richer?
Offline KeithB
« Reply #2 on: May 26, 2008, 04:01:42 AM »
I checked the plugs and they are light grey so I'm thinking that's a tad lean.
Nanahan Man
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #3 on: May 26, 2008, 05:54:45 AM »
Fuel mixture is controlled by many things on a carb,one of them being float height. If the float is set to spec correctly, no other adjustment is needed to change mixture. If you want to change enrichment, look at jet size or needle setting first.
Just my .02
.........Paul
