SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
Proven Tricks & Tips / How To's - NOT for Quesions
Electrical
(Moderator:
Gordon
Topic:
Wiring harness
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Wiring harness (Read 5092 times)
holdfastgreg
Guest
Wiring harness
on:
June 26, 2008, 09:12:18 PM »
Well I finally finished wiring my buddies k1 cb750. I suppose the next step is to figure out how to A) get a new harness or B) make a custom harness. Any suggestions or comments? I thought about using a painless wiring block like I've done on my SCCA cars. I'm open to ideas and suggestions......
Logged
troppo
Guest
Re: Wiring harness
Reply #1 on:
June 27, 2008, 03:14:47 AM »
sounds like you know your way around the wires, i dont see why you cant build your own harness. Get a wiring diagram and you should be able to lay one up on a bike easy enough....
You`d only need coloured wires (make sure you label the colours and what they are for lol) plenty of connectors (buy a kit) and plenty of beers
Logged
holdfastgreg
Guest
Re: Wiring harness
Reply #2 on:
June 27, 2008, 09:53:34 AM »
Yeah, thats gotta be the hardest part because some parts have wirings built into them. I was hoping someone knew of a custom harness that already had the fuse block and relays wired in sorta like Painless.
Logged
eastoak
Full Member
Re: Wiring harness
Reply #3 on:
June 27, 2008, 10:05:45 PM »
i just ordered new wiring from here.
https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=electrical
Logged
David
Full Member
Re: Wiring harness
Reply #4 on:
July 08, 2008, 08:06:30 AM »
I am working on my CB750 K4 and need to disconnect some of the wires leading to the rear end. Is there an easy way to disconnect these wires at the connectors where it joins to the harness? It feels like I will break the wires if I try to pull the connectors apart.
David
Logged
74 CB750
fuzzybutt
Guest
Re: Wiring harness
Reply #5 on:
July 08, 2008, 06:12:22 PM »
you can get a NEW oem harness from david silver spares for that 71
http://www.davidsilverspares.co.uk/parts/genuine-spares/part_7761/
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Electrical
(Moderator:
Gordon
Topic:
Wiring harness
