Last night, I was doing about 90 on the freeway with my 1976 CB550. That was the very first time I had taking her that fast. This morning on my communte to work, I hear this loud rattling, and an odd smell when I stopped. Since I was midway in my commute, I didn't know where it was coming from. And previously, I knew of the common clutch rattle issue. But this was much louder.
On my commute back home, suspecting it was more of the clutch related problem, I took the freeway back (less gear changing). So, I'm doing 65 on my commute, and the performance was the same as any other day. When I am at the stop light, I still hear that odd rattle, regardless of engagement of the clutch. I finally get back home, and pull into the garage. Smoke is streaming out of the breather hose. The smell is sharp, more like a clutch burning than oil. But it is coming out of the breather hose.
Performance is as expected. Clutch and gear engagement is as expected.
What do you guys think? Lost a ring land? Piston? Cutch?
My course of action would be a compression test. But I don't have the odd spark plug tool yet. Anything esle I can check in leu of that?
