Author Topic: Carb Jetting on a 550?  (Read 1109 times)
Reavis_99
« on: July 05, 2008, 08:17:06 PM »
I am currently putting my 1976 CB550F together I am running Emgo 35mm short stacks with the stock 4 into 1 header through a Emgo megaphone with removable baffle.  I live in  Southern Illinois so this will give everyone an altitude idea  Can anyone help me on what I will need to do to get it running correctly? Jetting??
Reavis_99
Re: Carb Jetting on a 550?
« Reply #1 on: July 05, 2008, 08:21:03 PM »
"Yeah - you got to tear them apart to get to the needles to change the clip setting."  I read this earlier with someone jetting their carbs are they meaning needle jets?  I am new to this terminology. What are they meaning?
Offline Pawsoff
« Reply #2 on: July 05, 2008, 09:03:36 PM »
your in luck Reavis, I just tore apart my carbs (1976 CB550K) and am rebuilding them today / tomarrow, so I have pics :)
When they refer to the clip position they are refering to this piece
Which sits inside the throttle valve here (on the right side of pic)
The forth clip (notch) position from the top of the needle is the standard position for 550 carbs.
I am no expert / old timer  or guru for tuning so I will let someone else suggest settings for your situation, good luck
Pawsoff
1977 CB550F
On the road, slowly improving the bike :)
Offline buffalogt750
« Reply #3 on: July 13, 2008, 08:00:37 PM »
115 main jets. All other carb settings stock. This should be real close. Make sure float levels, idle mixture and synchronization are all correct. Also make sure point gap, ignition timing, valve clearance and cam chain are all adjusted properly.
1976 Honda CB550K   SOLD
1993 Ducati 750 SS
2000 Suzuki Bandit 1200
Offline mmtsquid
« Reply #4 on: July 15, 2008, 05:51:35 AM »
Is that clip position also true for 77/78 carbs?
77 CB550K4
