Author Topic: ARRRRGHHHHH!!!!! Broke my clutch lifter plate!!! K2 750  (Read 9443 times)
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« on: July 11, 2008, 05:01:50 PM »
Got home from work, drained the oil, and popped the clutch apart enough to get at the springs.  Slid the new Barnett springs in and started taking it back down, keeping everything as even as I could.  Thought it was going together fine, and I was just starting to get the bolts snug, TICK!!!  I know that sound :(  Breaking aluminimum. Dammit. Dammit dammit dammit!!!!!!!
Do any of you gurus here ;) know where a guy could get a lifter plate?  All of the other 750s in town are running, so I doubt the owners would want to part with theirs.
What a way to start the weekend >:(
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
jsaab2748
Re: ARRRRGHHHHH!!!!! Broke my clutch lifter plate!!! K2 750
« Reply #1 on: July 11, 2008, 05:33:15 PM »
Plan on being down for a week or two and bid wisely on e bay.
Shouldn't be too hard to find. Been there and done that. Sorry
bout the back luck. Check the "buy it now" only auctions as well.
You might get lucky. May be available new also, dealer, service Honda, etc....
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #2 on: July 11, 2008, 05:46:40 PM »
This part is still available from Honda.  Part# 22360-300-010. About $50.00.  Outrageous, I know for an $8.00 part.  But its one of those parts that everyone seems to love breaking.
« Reply #3 on: July 11, 2008, 05:53:35 PM »
I PM'd you.
Offline kpier883
  • is quite the
« Reply #4 on: July 11, 2008, 07:03:10 PM »
... Thought it was going together fine, and I was just starting to get the bolts snug, TICK!!!  I know that sound :(  Breaking aluminimum. Dammit. Dammit dammit dammit!!!!!!!
I broke mine about 2 years ago too.  I was so lucky because an auction was ending for the part I needed that same day.  I bought it and received it the next week.  I also bought an inch-pound style torque wrench.  You better believe that I used that wrench to tighten the new one!
Two tips - tighten every bolt one turn in succession until they start to tighten, then switch to 1/4 turn each time until you get them all torqued.
Use the published values for the torque.
I had no problems when I used that method.
Maybe you will be as lucky as I was.
Kirk Pierce
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline UJM
  • Slower and safer....
  • Northwest Missouri
« Reply #5 on: July 18, 2009, 01:15:15 PM »
I've joined the club -
Snapped mine this PM -
Ordered a complete assembly with what appears to be an aftermarket machined plate -
I'd love the torque specs if anyone has them, please.
Thank you
« Last Edit: July 18, 2009, 01:17:08 PM by UJM »
Steve
Offline pg13
  • cb750K4
« Reply #6 on: July 18, 2009, 01:39:08 PM »
clymer manual says 6-7ft.-lb.(8-10N.m)
i may be a newb but i know the clutch section inside and out... wish i didnt
"what kind of man is a man who does not try to make the world a better place"
Offline eurban
« Reply #7 on: July 18, 2009, 01:55:40 PM »
One thing to keep in mind is that the clutch center and the pressure plate must mesh properly.  When you loosen up the bolts / springs there is no longer force pulling the towers on the pressure plate assembly outwards alowing it to fall back a bit towards the engine.  It won't necessarily pull forward and remesh properly if you simply tighten down the bolts after spring replacement.  If the teeth aren't meshed the lifter plate will never be able to seat on the towers and you will easily break the assembly.  You should pull the towers towards you feeling the pressure plate mesh with the clutch center and then keep some tension until you hand tighten the bolts enough that the springs are keeping the pressure plate meshed.  Then tighten each one a little bit at a time until the lifter seats on the towers.  Once seated then torque to factory spec.  . . .If you have completely disassembled the clutch it is also possible to install the pressure plate 90 degrees out where its teeth will not mesh with the clutch center at all.  Tightening things down in this orientation is sure to crack the lifter plate.  Factory manual suggests marking the original orientation upon dissassembly. Good luck with the next one!
« Last Edit: July 18, 2009, 01:57:42 PM by eurban »
« Reply #8 on: July 18, 2009, 03:13:20 PM »
Another thing to keep in mind is that you use correct replacement springs. That was the last straw with the kid behind the local Honda counter. Sold me springs for the DOHC 750. Too long. I got pretty smart when I snapped the 2nd one even with correct torque. I put the old springs back in.
Offline UJM
« Reply #9 on: July 18, 2009, 04:28:40 PM »
Wow, great information!
And I experienced the pressure plate mesh with the clutch center issue, it did take two tries for me to get it "right" - the first time, I knew something what whacked as I could sping the inner hub when it was all together, then, admittedly, I reinstalled the spring bolts unevenly.......
Using stiffer springs too, probably the combination caused the failure.
I'm interested in the replacement, it appears to be aftermarket, we'll see.
Any tips on where to buy the proper tool to remove the center bolt - I used a drift to get it on and off.
Also, a replacement lock washer plate - already found the nut locally and it is still in the package......
Thank you all!
Steve
Offline KB02
« Reply #10 on: July 19, 2009, 09:01:54 AM »
When putting my F1 engine back together, I broke the same part. I ordered a new from Honda, and broke that, too.  >:(  My dad, the machinist, made up a jig to hold the pieces together and had it welded back together. It held and I rode it that way. He welded both peices and I still have the second still sitting in the jig.
You can believe that I will be VERY careful putting the clutch together on my K8.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Bill/BentON Racing
    • BentON Racing
« Reply #11 on: July 19, 2009, 12:41:14 PM »
Eurban,Well written and correct,probably the biggest problem for people experiencing clutch work for the first time.As a former Sv mgr this had to be #1 problem if customer went inside and also broken plate.Bill
BentON Racing Website
BentON Racing Facebook
Offline ev0lve
« Reply #12 on: July 19, 2009, 01:42:50 PM »
http://www.z1enterprises.com/detail.aspx?ID=2867
Offline Achmed
« Reply #13 on: July 19, 2009, 02:30:40 PM »
I also broke two of those things myself on the F1, if it's the part with the bolt castings on it. I think we figured we might have an extra friction disc in there, too, so I have an extra one. It simply wouldn't go on with the number of discs in the Clymer picture. Maybe I didn't make sure it was meshed right? Is there any difference in the number of discs on different models? Looking at the Honda shop manual it is pretty explicit about the assembly so I will make sure to use that next time. Expensive mistake(s)(s)(s)(s)...
It's been working fine in limited use over the last few years but I am left wondering if I have all the discs in there.
Offline lordmoonpie
    • Moonpie
« Reply #14 on: July 20, 2009, 05:07:12 AM »
the correct tool is still available as a honda part - double ended castellated nut socket with two sizes. The part number I got from an RS250 Honda manual years back and it's been totally invaluable since.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
    • BentON Racing
« Reply #15 on: July 20, 2009, 07:53:08 AM »
Lord Moonpie nailed it. If you work on bikes might as well have both sides Honda oem # 07716-0020100.Don't know the cost.Bill
Offline ron.cieri.313
« Reply #16 on: July 20, 2009, 10:37:09 AM »
Fyi...the "special socket" to remove this locknut (on a CB750 clutch) will also work perfectly for the locknut on the 450 oil filter...in case you have both machines which I do.
Making the world a better place, one motorcycle at a time.
Offline KB02
« Reply #17 on: July 20, 2009, 06:58:59 PM »
I got my Heavy Duty clutch kit from APE in the mail today, with the extra disks. I just had to put them in tonight. That was pretty much the only thing keeping the engine from being completely buttoned up. You better believe the WHOLE time this tread was running through my head. I was sitting there with vernier calipers measuring to make sure that I was keeping everything even. I got butterflies in my stomach when the bolts started tightening up near the end. The torque wrench clicked on the first bolt and then everything around me became very still as I had stopped breathing. They all clicked, right in sequence, and the clutch is together.    8)
I figured that was good for one night. I went in and had a scotch.  ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline hapakev
  • Your Standard
« Reply #18 on: July 20, 2009, 07:10:44 PM »
It looks stock, but they put the plate on backwards.
Smoking Jack
1978 CB750F(ish)
Offline UJM
« Reply #19 on: July 21, 2009, 07:44:48 PM »
LMAO - I feel stupid for not catching that!
Good, no - great catch, thank you!
Steve
Offline Count_chockula
« Reply #20 on: July 26, 2009, 04:16:34 PM »
I too just join the ranks of breaking this piece!  >:( I know how this happened to... as I was tightening the screws down the plate got hung up on the tower and I didn't catch it until it was WAY to late... guess that I will be ordering one tomorrow...
Also, as eurban stated...
When you loosen up the bolts / springs there is no longer force pulling the towers on the pressure plate assembly out wards allowing it to fall back a bit towards the engine.  It won't necessarily pull forward and remesh properly if you simply tighten down the bolts after spring replacement.
Well I figured out how to get around this for people in the future. When you go to put the plate back on use one of the "longer" bolts/screws from the cover to allow you to "pull" the outer clutch in place. Place the screw into the plate, while holding one of the towers, and then start one or two of the "real" bolts. This should allow you get the lifter plate back in place without losing the alignment of the outer/inner clutches.
Offline CB_Jeff
« Reply #21 on: April 05, 2012, 05:18:10 PM »
I now have a broken lifter plate as well, anyone have a spare they would like to part with?
« Reply #22 on: April 05, 2012, 06:08:45 PM »
Just put mine together. No problem this round but I have broken 2 in the past.
This was my approach: Got all 4 bolts started. Tightened the first 2 opposing bolts a couple quarter turns. As these screwed in it loosens up the other 2 opposing bolts. Gave these other 2 a couple quarter turns until they snugged up. Made measurements of my downward progress on all 4. Evened them out.  I then took this 2nd set down another couple quater turns. I repeated this until they got close to bottoming out. Kept measuring. At this point as they started tightening I noticed that one ear was "off" measurement. I inserted my dental mirror inside and took a peek. I had 3 springs seated correctly and one was cock-eyed. Backed them all off until I could reseat that one spring and started over. Kept measuring as I went. When they started bottoming I got out my torque wrench and again did opposing sets. Started off at ~ 6lb on all, then 8lb then stopped at 10lb.
The earlier clutches and later clutches are different and then there is the "factory fix" that creates a hybrid clutch pack to minimize rattle. I'm planning on doing an article on this once I "update"/modify the older style cover I powder coated by mistake  :o Should be withiin the next week. Stay tuned. It will explain all that I mention and how to ID which you have.
« Last Edit: April 05, 2012, 08:06:03 PM by Jerry Rxman Griffin »
« Reply #23 on: April 05, 2012, 06:44:18 PM »
Hey Jerry, when you modify the boss on the cover, only remove enough for adequate clearance. The depth of the hole is at least 1/8" more on the K1 cover than the K7, so there might not be as much meat there as it looks?
Offline nikcorg
    • My blog
« Reply #24 on: August 30, 2012, 10:08:38 PM »
My clutch on my CB750K7 yesterday said "snap", getting stuck in disengaged position and wouldn't return without helping by hand. From discussions on another forum, I'm thinking it has to do with the clutch lifter assy, or specifically the clutch lifter cam.
Can you elaborate on how the earlier and later clutches differ?
I found a used clutch lifter assy set, but I'm a bit concerned since it's being offered to fit any 750K. However, the parts list on CMSNL says the some parts that I need are only upto #2731486. As far as I can tell (I'm quite the newb) those parts look identical to their successors. Why this concerns me, is because I would need the earlier parts (my bike is #272...) but they're not available through CMSNL.
Honda CB750K7 '77
