Author Topic: 750F fuel line routing  (Read 1307 times)
Offline david 750f
  • 1976 CB750F
« on: September 06, 2005, 02:07:30 PM »
The T-line that feeds the carbs can be rotated from pointing straight up to straight down. Should the fuel line from the gas tank connect to the T-line above or below the carbs.
There is no clear picture in my manual and it has been a few years since the carbs were off the bike...in other words I cannot remember how the fuel line is routed!
Thx,
David
1976 CB 750F
Offline mcpuffett
Re: 750F fuel line routing
« Reply #1 on: September 06, 2005, 02:47:45 PM »
hi david, i have a 76' f1 and my fuel line goes down between 1 and 2 inlet rubbers through a fuel filter and over the top of number 1 inlet rubber and on to the t junction between 1and 2 carbs and then another pipe to 3 and 4 carb   ??? hope i have helped you and not baffled you  :D  mick.
eldar
« Reply #2 on: September 06, 2005, 03:48:37 PM »
Really as long as the tube does not loop back up, you should be fine.
bearcatamo
« Reply #3 on: September 12, 2005, 11:24:36 AM »
Actually, mine does loop and still works fine. Gravity will keep it flowing.
Barry
