Kitsune, our 80 model customs should have 19 front single disc and 16 rear. heffy, the slow jets are pressed in and according to honda are not removable, but they can (and should ) be removed with a pair of pliers by pulling straight up and twisting slightly. one of the small o-rings, the small washer, and the spring go on the idle screw. one of the o-rings (medium one i think) goes between the carb body and the float bowl at the passage where gas goes from the acc pump to the 4 squirters in the carbs.(believe me you need this o-ring , dont ask me how i know.)
