Poll
Especially since gas has gotten so expensive, do you use...
Regular
Mid-grade
Premium
Straight bourbon liquor
Spit n' piss
Author Topic: What grade of gasoline do you use?  (Read 13145 times)
Offline DammitDan
  • Prodigal Son
  • It lives!
« on: September 06, 2005, 07:54:26 PM »
I've found that premium seems to help the old beast to run smoother.  Maybe it's just my imagination though...
CB750K4
Offline ofreen
Re: What grade of gasoline do you use?
« Reply #1 on: September 06, 2005, 09:51:27 PM »
I use regular, which is 87 octane around here - southwestern Idaho.  Works fine, no pinging.
Greg
'75 CB750F
Greg
'75 CB750F
Hop on a Honda
« Reply #2 on: September 06, 2005, 11:53:04 PM »
Fuel / Gas.
I would use 100 Octane avgas in every tankfull IF I could
There is no comparrison and it CLEANS the innards of every thing concerned.
Also it gets more MPG using the same throttle settings and has no gunk in the goo.
Our local fuel is terrible in the fact that its full of ???/ and coats every thing in like burnt honey
I wondered how LPG would work?
Dave Australia.
Offline kghost
« Reply #3 on: September 06, 2005, 11:55:05 PM »
Well, it really works better at a 50/50 mix.
Too much lead in the old 100 LL. About 5.5 parts per million.
Stranger in a strange land
Offline heffay
« Reply #4 on: September 07, 2005, 12:03:57 AM »
your asking a loaded question dammit... dan... he hee....
too many vehicles to chose one octane...
cb350f- premium: the more preignition the better!
zx7r- midgrade: pings too much with premium
scooter- whatever i want... it runs on gas and oil does grade really matter?
74 j20 jeep- believe it or not manual calls for 91 octane!
Offline kghost
« Reply #5 on: September 07, 2005, 12:06:55 AM »
Pings too  much with premium? WTF Hef?
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #6 on: September 07, 2005, 12:59:47 AM »
We should get Lloyd (TwoTired) to comment on the various Old Wives' Tales about premium vs regular fuel...
Any chemists out there tell me what they put in Premium that actually cleans the engine and gives more mpg?
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline heffay
« Reply #7 on: September 07, 2005, 06:10:08 AM »
well- high grade gas explodes a lot quicker... with a bike that is soooo far advanced in timing already any more advancement tends to make it ping.
i forget at what rpm but its max advance is somethin like 45 or 48 degrees btdc   :o
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #8 on: September 07, 2005, 06:24:27 AM »
Because of the fairly low compression ratio I run regular in my SOHC4s.
Hey Hef
Actually the high grade gas burns slower.
 All about gasoline here:
 http://motorcycleinfo.calsci.com/Gasoline.html
« Last Edit: September 07, 2005, 06:27:10 AM by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: September 07, 2005, 07:02:04 AM »
Oh man, someone opened up a can of worms here! :o  I won't get too into it since I've already quoted most of my research in several past discussions, but I'll condense it here:
The only engines that will benefit from high octane fuel are the ones designed to use it, and the ones with artificially high compression due to excess carbon build-up.  Adding octane to gas allows for higher compression ratios because it prevents the fuel from pre-igniting or pinging, but high octane gas actually has slightly less energy per volume than regular gas does.  If a non high-compression engine runs better on premium, it's time to clean out the combustion chamber.
Heffay, the reason your Jeep manual calls for 91 octane is because that was going by the old system of octane rating.  Translating to todays system that number would be 87 (regular).  And since we're up here at altitude, 85 is our regular.
    • TVAM
« Reply #10 on: September 07, 2005, 07:05:19 AM »
Can you point me at these threads Gordon?
I'll write up a FAQ.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: September 07, 2005, 07:25:18 AM »
There was one thread in particular that I remember really getting into it, but it was back on the old Greenspun forums.  If those are archived, it may still be around.
But there's something I've discovered about this topic through discussions in this group and many face-to-face conversations:  Most of the time, if someone has convinced themselves that using premium in their non-premium designed engine makes it run better/faster/stronger/cleaner, no amount of facts or physics will change their mind.  If it makes you feel better, and you have the extra cash to burn, then buy the premium.
    • TVAM
« Reply #12 on: September 07, 2005, 07:40:48 AM »
I've run a quick search on the archives:
http://www.glennstauffer.com/smf/
but can't find anything specific.
You're right about people though - if it makes you feel that you're getting value for money - then you're getting value for money!
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline Harry
    • CB500F
« Reply #13 on: September 07, 2005, 08:02:15 AM »
Gentlemen, I refer you to http://www.sohc4.us/forums/index.php?topic=264.0
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
    • TVAM
« Reply #14 on: September 07, 2005, 08:15:42 AM »
Hmm.
Hoist by my own (FAQ) petard ??
Gordon - do you concur with what Harry has written in the FAQ?  If so, let's leave it at that and point all newbie questions there.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: September 07, 2005, 08:28:44 AM »
I can't argue with the facts!  Thanks Harry.
Offline Harry
    • CB500F
« Reply #16 on: September 07, 2005, 10:17:05 AM »
(Blushes and clears his throat while looking at his feet)
Offline Gordon
  • 750K1, 550K2
eldar
« Reply #18 on: September 07, 2005, 05:18:39 PM »
OH OH I got one!! Which side do you fill from????  ;D
Offline Gordon
  • 750K1, 550K2
« Reply #19 on: September 07, 2005, 05:26:05 PM »
The outside, of course!
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #20 on: September 07, 2005, 11:50:02 PM »
well i sorta go by what the owners manuel says from 1973 says 95 leaded  which of coruse they  make here in the US anymore so i use 93 unleaded with a little bit of lead subitute every once in a while
 Dose that sound good? hehe
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline heffay
« Reply #21 on: September 08, 2005, 05:19:09 PM »
soooo... i feel like this entire thread is on here just to prove my stupidity.
but, in my defense... ummm... ok, yeah, i'm in buffo's boat.
i am going to do some experimenting with grades of gas... although i have been so i thought i was right... but, everything that is being said contradicts.  i will let you know... if there are any findings whatsoever.  it's so hard to tell in a situation like this... you know, things exploding, engines containing those explosions, somethings gotta give and most likely... it won't be pretty!
Hop on a Honda
« Reply #22 on: September 13, 2005, 12:01:02 AM »
It would be interresting to match the variations gasoline as you call it BUT which fuel actually helps make the CB SOHC run to its maximum capacity.
The Unleaded Fuel in Australia would make a volvo ping! and it seems to have lots of goo in the mix. The SHELLL Optimax seems to have the advantage.
I still say use the best HEIU you can
HEIU =  High Energy Ignition  Unit
Use NGK IRRIDIUM spark plugs.
Dave Australia.
Gibson
« Reply #23 on: January 17, 2006, 07:11:36 PM »
I use regular since gas cost's so mutch. Annything better cut's into my Beer and project bike money too hard.
Offline mrbreeze
  • Not your average
« Reply #24 on: January 17, 2006, 08:30:24 PM »
Hey Heffay in Colorado,I thought you went to a fancy school for bike mechanics.Where did you hear that high octane gas burnt quicker than low octane gas ?You got your wires crossed dude!!! If you are runnin' an engine (Any engine!) that pings on hi octane fuel,then your ignition timing is too far advanced.Sorry but thats the way it is.
MEMBER # 257
