Author Topic: Modern Parts on Classic Bikes? See here!  (Read 22920 times)
Offline bradweingartner
  • 74 CB 550 x2
« on: August 11, 2008, 09:59:56 PM »
So, like many of you, I've been doing the homework to swap some modern parts on my old 74 550. Problem is, finding hard specs on lots of the parts is nearly impossible. Want to know the axle diameter and width of a 2005 What-cha-makallit Crotch Rocket? Good luck. Guys who work on them apparently don't spend their time online...  ;D
I'm hoping to change that.
I'm in the starting stages of a website that will be a repository for all the hard dimensions of as many motorcycles as I can manage. I'm starting to amass a bit of a collection of parts already and I intend to measure everything. When you're trying to miss-match parts from different years, different makes, different centuries it will become an invaluable resource.
I'm also looking for help from everybody as it will be mostly user generated data. I will define basic parameters to keep the data consistent, and all you need to do is supply the actual measurement. Tape Measures need not apply. Looking for accuracy to the sub-mm for many of these parts. My dream is for a machinist to take a look at this site and say, "Okay, to make this widget work with this doohickey I need to make a bushing spacer of X width and Y height." - Without having to buy a bunch of parts and test it all out.
Let me know what you think, if you have suggestions, etc. I'm hoping some of you can help me with measurements from the SOHC era!
Oh, and if anybody knows of a place already like this let me know so I don't have to waste my time!!!  8)
Offline ekim98
Re: Modern Parts on Classic Bikes? See here!
« Reply #1 on: August 11, 2008, 10:08:01 PM »
Excellent idea.  ;D ;D ;D I hope everybody will pitch in on this one, and I'm sure the responce from the forum will be great. I'm a retired machinist,but I sold my tools when I got out of the trade. The best I can do now is with a dial venier caliper. :-\
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
« Reply #2 on: August 11, 2008, 10:27:18 PM »
I am not seeing it.. When you try to mate a later front end, you will be trying to put a fork with little offset(stemto tubes), onto a bike that had lots more, which then hits your tank etc.. differents stops, and on it goes..
Good if you can get the measurements, but you will probably actually have to have it on the bike to check everything..
 I can see some folks having a bit of a time, measuring things like stem  offset, rotor and caliper offsets, or making a drawing showing caliper mounting holes in relation to the fork legs.... to any degree of accuracy..
 Hopefully it will work..
  • 74 CB 550 x2
« Reply #3 on: August 12, 2008, 08:33:17 AM »
You have a real good point there 754, and I'm realistic in not expecting detailed drawings for lots of these peices. But most people can take a few points of data and get a much better idea of what they are working with, rather than spending hundreds on a 'maybe' part... <- Thats me... Got a set of GSXR and R6 Forks sitting back in Michigan waiting to be measured and test fit!
Luckily I know they will work out with the right bearings, but at this point I don't know exactly what wheels will work with either fork except of course the exact year/make/model that the forks came from. Which narrows down my options significantly... Or calipers. Or rotors. So these are the kinds of things I'd love to have in one place!
Even between the CB SOHC family there are lots of scattered data. I'm looking at late-model SOHC 750 swingarms in lieu of a modern swingarm to fit a fatter rear end in. I've heard it's a bolt up swap with a 750, but that's just passing knowledge on this board. I'd love to have a bushing-bushing measurement for both.
Maybe in the future, maybe the database will allow a simple search function. You click on what part you have (forks) and it will tell you what will replace it. Or what other parts are compatible with it (wheels, calipers, triple trees, etc). I'm a lot rusty on MySQL but this sounds like a fun project.
I guess I just hope it makes brainstorming easier and allows me to sleep at night... Rather than laying in bed wondering if something will fit or not  ;D
Offline eurban
« Reply #4 on: August 12, 2008, 12:03:16 PM »
A "what has been tried and found to work database" would certainly be helpful as long as good and accurate description was included.  Having measurements from all sorts of bikes would be nice but it might be pretty hard to put together something that is comprehensive; getting people interested in measuring (and doing it accurately) what they have might be like pulling teeth.  On the other hand, people like to talk about their projects and what work went into them.
Offline sinister902
    • Anger Street Kustoms
« Reply #5 on: August 12, 2008, 12:21:02 PM »
for what it's worth, I just completed a 750 rear end swap onto a cb550....the only trouble i ran into is the sprockets are totally different, and 11 teeth different for that matter....which was easily remedied by purchasing a 39tooth sprocket meant for a 750 wheel, which gave me +2 over the stock 37 tooth 550 rear, and it is -9 teeth from stock 750 rear sprocket. the swingarm mounting location is the same, yet the swingarm itself is more "boxy" rather than tapered, with a wider wheel....allowing a wider tire while also accomplishing a disc brake swap.
  • 74 CB 550 x2
« Reply #6 on: August 12, 2008, 12:40:30 PM »
eurban: I have the same thought. I'm hoping once I get some information to start with, I'll be able to compile more data based on that. Like, if Swingarm A. Fits where Swingarm B Originally sat, without modifications, you can make some assumptions about those dimensions. Allows some interpolation of data I hope.
But I'm definitely down to hear about all combinations that work regarding the SOHC community and others.
sinister902: That's great news. What model did 750 was the arm from? The later wider/longer or the early arm? I hear they are the same at the pivot. I intend on using a sportbike mag on the rear so I'll be doing something custom with the chain centerline anyway. Thanks for the contribution.
Offline hahnda
  • lskdfhs;dljksa;
« Reply #7 on: August 12, 2008, 01:45:16 PM »
Rear Axle Diameters
(some bikes used a stepped axle, that’s why you see the “left” and “right” listed)
15
Honda CB250 Nighthawk 91-92, CM250 Custom 82-84, CMX250 85-86 & 96-97 Rebel (right), CX500 78-82, GL500 81-82, CB550 SC Nighthawk 83-84. KawasakI KX250 74, KZ550 A 80-81. Suzuki GS250 T 80-81 (right), RM250 76, DR370 78-79, RM370 76-77, SP370 78-79, SP400 80, TM400 71-75 (right), TS400 72-77 (right). Suzuki RM500 83 (left). TY250 77-78 & 84 & 91 (left), RZ350 84-89, TY350 Trials 85-86 (left), XV500 Virago 83-85, XV535 All 87-98, Honda CBX250 H 87, CMX250 85-86 & 96-97 (Left). Kawasaki KL250 80-81, KL250 82-84 (Right), KZ250 G 80-81 (Left), KZ250 82-83 & 85 (Left). Suzuki GN250 82 (Left), GS250 T 80-81, RG250 CH 87, RM250 79-83, RM400 79-80, RM465 81-82, RM500 83 (Right). Yamaha TDR250 89-90, TY250 77-78 & 84 & 91 (Right), TZR250 87-88, XV250 88-90 & 94-96, TY350 85-86 (Right)
17
Honda CN250 86-87 & 82-87 Helix (right), XL250 S 78-81, XR250 79-80 (left), XR250 R 81-82 & 84-85 (left), XR250 R 96-97 (left), CB360 74-76 (right), CB400 F 89-90, CM400 E/A/B 79-81 (right), XR400 R 96-97 (left), CB450 Nighthawk 82-85, CMX450 C Rebel 86 (left), CX500 Tc Turbo 82, FT500 Ascot 82 (right), VF500 C V30 Magna 84-85, VF500 F Interceptor 84-86, VT500 C Shadow 83-84 (left), VT500 FT 83-84 (left), XL500 S 79-81 (left), XR500 79-80 (left), CBX550 FD 83, CBR600 Hurricane 87-90, VT600 Shadow 88-97, CB650 SC 82-85, CX650 T/E 83-84, GL650 I 83, XR650 L 93-97 (left), CB750 SC 91-93 & 95-97, VF750 C Magna 82-84, VF750 S Sabre 82-85, VT750 Shadow 83-85, Honda NX250 88-90, VTR250 90, XL250 R 82-83 (Right), XL250 R 84-87, XL250 S 78-81 (Right), XR250 79-80 (Right), XR250 L 91-96, XR250 R 81-82 & 84-97 (Right), NS400 RG 86, XR400 R 96-97 (Right), CMX450 C 86 (Right), VT500 C 83-84 (Right), VT500 FT 83-84 (Right), XL500 R 82 (Right), XL500 S 79-81 (Right), XR500 79-80 (Right), XR500 R 81-84 (Right), XL600 R 83-87 (Right), XR600 R 85-97 (Right), XR650 L 93-97 (Right). Kawasaki EL250 88-94 (Left), EX250 86-90 & 92-97 (Left), KDX250 82-84 (Left), KX250 82-84 (Left), EX500 D1-D4 94-97 (Left), KX500 A 83-84 (Left), ZX550 A 84-86 (Left). Suzuki DR250 82-84, GT250 73-77 (Left), PE250 77-81, RM250 77-78, RM250 84-86 (Right), SP250 82-86, GS300 L 82-83 (Left), GT380 73-77 (Left), DR400 80 (Right), GN400 80-82 (Left), GS400 B/C 77-78 (Left), GS400 N/EN 79 (Left), GS400 ET/ST/EX/SX 80-81 (Left), GS400 T X/Z 81-82 (Left), GS400 EZ/ED (Left), GS400 EE/SE/SF/SG (Left), GS400 L T/X/Z 80-82 (Left), PE400 80-81, RM400 78, GS425 N/EN/LN 79 (Left), GS450 82-83 (Left), DR500 81-83 (Right), GT500 76-77 (Left), RG500 G/G1 86, RM500 84 (Right), SP500 81-83 (Right), GS550 E 77-79 (Left), GS550 B/C/EC/N/EN/ET/T 77-80 (Left), GS550 ED/ESD/EE/EFE/EFf 83-85 (Left), GS550 EG/ESG 86 (Left), GS550 L 83 (Left), GT550 73-77 (Left), DR600 85-88, GSX600 F 88 (Left), GV700 GLF 85 (Right), VS750 85-91 (Right), VS800 92-97 (Right). Yamaha DT250 74-79, IT250 77-81, MX250 73-75, SR250 80-82, TT250 80-83, XT250 80-84, YZ250 75-80, BW350 86-87, XT350 85-87 & 92 & 94 & 96, DT360 74, MX360 73-74, YZ360 74-75, DT400 75-78, FZR400 88-89 (Left), IT400 77-79, MX400 75, XS400 82-83 (Left), YZ400 76-79, IT425 80, SC500 73, SR500 78-79 (Left), TT500 77-78, XT500 76-81, XJ550 R 81-83 (Left), XT550 82-83, XZ550 82-83 (Left), FJ600 84-85 & 89 (Left), FZ600 86-88 (Left), FZR600 R 89-95 (Left), SRX600 C 86 (Left), XJ600 S 92-96 (Left), XT600 84-95, YX600 86-90 (Left), XJ650 80-83 (Left), XJ700 85-86 (Left), FZ750 85-88 (Left), FZX750 86-87 (Left), XJ750 81-84 (Left), XV750 81-87 & 90-98 (Left), TDM850 92-93 (Left), XJ900 R 83 (Left), XV920 81 (Left), XV1000 84-85 (Left), XV1100 86-98 (Left), Kawasaki KDX250 80-84 (Right), KL250 D 85-97, KX250 82-84, KL600 84-86, KL650 87-97, Kawasaki EL250 88-94 (right), EX250 Ninja 86-87 (right), KL250 78-79, KX250 75-77, KZ250 78-79 (left), EX305 B1-B3 83-85, KZ305 C1/D1 81-82, KZ305 B2/B3 LTD 87-88, KX400 A1/A2 75-76, KZ400 A/D/S 74-78, KZ400 B 78-79, KZ400 C1/H1 78-79, KZ400 C2 81, KZ440 80-83, KZ440 D6 84, EN450 LTD454 85-90, EN500 Vulcan 90-96, EN500 C 96-97, EX500 A1-A7 Ninja 87-93, EX500 D1-D4 Ninja 94-97 (right), KZ550 A 82-83, KZ550 C LTD 80-83, KZ550 D GPZ 81, KZ550 F1/F2 82-83, KZ550 H1/H2 82-83, KZ550 M1 83, ZR550 B1-B4 90-93, ZX550 S 84-86 (right), ZL600 Eliminator A1/A2 86-87, ZL600 B2/B3 96-97, ZX600 A1-A3 Ninja 85-87, ZX600 C1-C4 88-91, ZX600 C8-C10 95-97, ZX600 D ZX-6 Ninja 90-92, KZ650 B 77-79, KZ650 D 78-79, KZ650 H1-H3 CSR 81-83, KZ750 E 80-82, KZ750 F1 83, KZ750 H1/H4 80-83, KZ750 K1/K2 83-84, KZ750 L Supersport 83-84, KZ750 N Spectre 82-83, KZ750 R GPZ 82, KZ750 S1 82, VN750 Vulcan 86-97, ZX750 A1-A3 83-85, ZX750 Turbo E1/E2 84-85, ZR750 Zephyr 91-93, VN800 Vulcan /Vulcan Classic 95-97, ZX900 A1-A3 Ninja 84-86, Suzuki RM250 84-86 (left), GS300 L 82-83 (right), GT380 73-77 (right), DR400 80 (left), GN400 80-82 (right), GS400 N/EN 79 (right), GS400 ET/ST/EX/SX 80-81 (right), GS400 T X/Z 81-82 (right), GS400 EZ/ED 82-83 (right), GS400 EE/SE/SF/SG (right), GS400 L T/X/Z 80-82 (right), GSF400 Bandit 91-93, GS425 N/EN/LN 79 (right), GS450 82-83 (right), DR500 81-83 (left), GS500 89-97, GT500 76-77 (right), RM500 84 (left), SP500 81-83 (left), GS550 E 77-79 (right), GS550 B/C/EC/N/EN/ET/T 77-80 (right), GS550 E (with mag wheels) 80, GS550 ED/ESD/EE/EFE/EFF 83-85 (right), GS550 EG/ESG 86 (right), GS550 L 79-81, GS550 L 82 (right), GS500 L D-F 83-85, GS550 TX/MZ Katana 81-82, GT550 73-77 (right), DR600 89, GSX600 F 88 (right), GSX600 F 89-97, DR650 S 90-95, GR650 D/XD/E/F Tempter 83-85, GS650 G/GL 81-83, GS650 EX/EZ 81-82, GS650 M 83, LS650 P T/V 96-97 (left), LS650 Savage 86-88, GV700 GLF Madura 85 (left), DR750 S 88-89, GS750 ED/ESD/EE/EFE 83-84, GS750 EFF/ESG 85-86, GS750 SE-SG 82-86, GSX750 F Katana 89-97, VS750 Intruder 85-91 (left), DR800 S 90, VS800 92-97 (left), VX800 90-93, VZ800 Marauder 97-98, GS850 G/GL 79-83, GS1000 G/GL 80-81, GV1200 Madura 85-86, VS1400 GL P/F 84-87 & 96-97, Yamaha RD250 73-75, RD350 73-75, XS360 76-77 (right), FZR400 88-89 (right), RD400 76-79 (right), XS400 77-81 (right), XS400 Maxim/Seca 82-83 (right), XS400 S Special 80-82 (right), SR500 78-79 (right), XS500 76-78 (left), XJ550 R 81-83 (right), XZ550 Vision 82-83 (right), FJ600 84-85 & 89 (right), FZ600 86-88 (right), FZR600 R 89-95 (right), SRX600 C86 (right), XJ600 S Seca 92-96 (right), YX600 Radian 86-90 (right), XJ650 80-83 (right), XJ700 Maxim X 85-86 (right), FZ750 85-88 (right), FZR750 87-88, FZX750 Fazer 86-87 (right), XJ750 81-84 (right), XV750 Virago 81-87 (right), XV750 90-98 (right), TDM850 92-93 (right), XJ900 R Seca 83, XV920 Virago 81 (right), FZR1000 87-88, XV1000 84-85 (right), XV1100 86-98 Virago (right)
20
Honda CR250 M 73-76 (Left), CR250 R 78-80 (Right), CR250 R 81 (Left), MT250 74-76 (Left), XL250 72-76 (Left), CB360 74-7 (Left), CB400 75-81 (Left), CM400 E/A/B 79-81 (Left), CB450 65-74 (Right), CB450 Tc 82 (Left), CM450 A/C/E 82-84 (Left), CR450 81 (Right), CR450 R 82 (Right), CB500 71-76 (Right), CB550 F 75-77 (Right), CB550 K ALL (Right), CB650 C 79-82, CB750 A 76-78, CB750 C Custom 80-82, CB750 F 75-78, CB750 F/K/L 79-82, CB750 K 69-78, CB750 SC 80-83, VF750 C/C2 94-98 (Left), VF750 D 94-97 (Left), VF750 F 83-85, VRF750 F (Left), PC800 89-90 (Left), CB900 C 80-82 (Left), CB900 F 81-82, CB1000 C 83 (Left), CBR1000 F 87-88 (Right), CBR1000 F 90-91 & 93-96, GL1000 L 75-79 (Left), VF1000 F 84-85 (Right), CBX1050 79-82, CB1100 F 83, CBR1100 XX 97 (Left), GL1100 A/I 80-83 (Left), VF1100 C 83-86 (Right), VF1100 S 84-85 (Right). Kawasaki GL1200 A/I/L/SE 84-87 (Left), KZ750 B1/B2 76-77, KZ750 B3/B4 78-79, KZ750 G 80, ZX750 89-90, KZ900 76-77, ZL900 A1/A2 85-86, Z1 900 73-75, KZ1000 A/B/G 77-80, KZ1000 C 78-81, KZ1000 E 79-80, KZ1000 J1-J3, KZ1000 K 81-82, KZ1000 M1 81, KZ1000 P 82-97, KZ1000 R 83, KZ1000 D Z1/R 78 & 80, ZG1000 86-93, ZG1000 94-97, ZL1000 A1 87, ZX1000 A 86-87, ZX1000 B 88-89, KZ1100 A1-A3, KZ1100 B1/B2 81-82, KZ1100 L1/R1 83, KZ1100 R1 84, ZN1100 B1/B2 84-85, ZR1100 A1-A5 92-95, ZX1100 A1/A2 83-84, ZX1100 E1-E3 95-97, ZX1100 C 90-92, ZX1100 D 93-97, ZG1200 86-97, KZ1300 79-82, ZN1300 83-88, VN1500 87-97, VN1500 D 96-97, VN1500 B 87-90. Suzuki TM250 72-75 (Left), TS250 71-81 (Left), TM400 71-75 (Left), TS400 72-77 (Left), RE5 75-76 (Right), GT750 73-77 (Right), GV1400 86-88 (Right). Yamaha XS360 76-77 (Left), RD400 76-79 (Left), XS400 77-81 (Left), XS400 S 80-82 (Left), XS500 76-78 (Right), TX650 74 (Right), XS750 77-79 (Right), XS850 80-81 (Right), FZR1000 89-93 & 94-95, GTS1000 93-94, FJ1100 84-85, XJ1100 82-83 (Right), XS1100 78-79 (Right), XS1100 G/H 80-81 (Right), XS1100 79-91 (Right), FJ1200 86-93, VMX12 85-97 (Right), XVZ12 83-85 (Right), XVZ13 86-93 (Right), XVZ13 (Right), Honda CR250 M 73-76 (Right), CR250 R 78-80 & 87 (Left), CR250 R 81-82 (Right), CR250 88-89 (Left), MT250 74-76 (Right), XL250 72-76 (Right), XL250 R 82-83 (Left), XR250 R 86-95 (Left), CR450 81 (Left), CR480 R 82 (Left), CR500 R 87-89 (Left), FT500 82 (Left), XL500 R 82 (Left), CBR600 F 91-96, CBR600 96, XL600 R 83-87 (Left), XR600 R 85-97 (Left), CB750 SC 84-85, VF750 C 85-88, VF750 C/C2/D 94-97 (Right), VF750 C/C2 98 (Right), VFR750 86 (Right), VT750 C 86, PC800 89-90 (Right), VT800 88, CB900 C 80-82 (Right), CBR900 RR 93-97, CB1000 C 83 (Right), CBR1000 F 87-88 (Left), GL1000 L 75-79 (Right), VF1000 F 84-85 (Left), VF1000 R 84-85 (Left), CBR1100 XX 97 (Right), GL1100 A/I 80-83 (Right), ST1100 A 91-96 (Left), VF1100 C 83-86 (Left), VF1100 S 84-85 (Left), VT1100 C 85-96, VT1100 C2 95-97 (Right), GL1200 A/I/L/SE 84-87 (Right), GL1500 (Goldwing) 88-97 (Left), GL1500 (Valkyrie) 96-97 (Left). Kawasaki KDX/KX420 80-81 (Left), ZX600 E 93-98, ZX600 F 95-97, KL650 87-97 (Right), ZX750 H1/H2 87-90. Suzuki RM250 87 & 90-91, RM250 88-89 (Right), RMX250 89-96 (Right), DR350 90-97 (Left), DR350 S 90-96, RE5 75-76 (Left), GSF600 96-97, RF600 R 93-95, DR650 SE 96-97, XN85 83, GS750 B/C/EC/N/EN 77-79, GS750 LN/LT/LX 79-81, GS750 ET/EX/EZ 80-82, GS750 TZ/TD 82-83, GSX750 SZ 82, GS750 SD 83, GSX-R750 88-92, GT750 73-77 (Left), RF900 R 94-97, GS1000 C/EC/N/EN/ET/ST 78-80, GS1000 LN/LT 79, GS1100 E/ES 80-83, GS1100 SZ/SD 82-83, GS1100 G/GK/GL 82-84, GSX1100 F 88-93, GSX1100 G 91-93, GSX-R1100 88-92, GSX-R1100 W 93-97, GS1150 84-86, GSF1200 S 96-97. Yamaha YZF600 RG 95, YZF600 96-98, XS750 77-79 (Left), Honda CR250 R 82 (Left), CR250 R 83-86, CR250 R 87 (Right), CR250 88-89 (Right), CR250 90-97, CR480 R 83, CR500 R 84-86 & 90-97, CR500 R 87-89 (Right). Kawasaki KDX250 D 91-94, KL250 82-84 (Left), KLX250 R 94-96, KX250 85 (Left), KX250 86-97, KLX300 97, KX500 B1 85 (Left), KX500 86-93, KX500 E6 94-96, KX500 E9 97, KLX650 C1-C4 93-96 (Right), KLX650 A1-A3 93-96. SUZUKI RM250 88-89 (Left), RM250 92-97, RMX250 89-96 (Left), DR350 90-97 (Right), DR350 S 97. GSX-R750 85-86. GSX-R750 87, GSX-R1100 86-87. YAMAHA IT250 82-83, WR250 Z 91-98, YZ250 81-98, YZ250 WR 89-90, TT350 85, IT465 81-82, YZ465 80-81, IT490 83-84, YZ490 82-90, TT600 83-86, Kawasaki KLX650 C1-C4 93-96 (Left)
25
Honda CB450 65-74 (Left), CB550 F 75-77 (Left), CB550 K ALL (Left). Suzuki LS650 P T/V 96-97 (Right). Yamaha TX650 74 (Left), Honda VF1000 R 84-85 (Right). Kawasaki KZ650 C 77-79, ZX750 (ZX-7, ZX-7R, ZX-7RR) 91-96, ZX900 B 94-97. Yamaha YZF750 R 94-97
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline hahnda
  • lskdfhs;dljksa;
« Reply #8 on: August 12, 2008, 01:46:01 PM »
Fork Diameter   Make   Model and Year
27   Honda   MB5 (82)
27   Honda   CR-60R (83)
27   Honda   XR-70R (97-03)
27   Honda   XL-70K (74-76), XL-75 (77-79), XR-75 (72- 74-78)
27   Honda   XL-80 (80-85)
27   Honda   XR-80 (83-84)
27   Honda   XR-80R (85-91, 93-03)
27   Honda   CL90 (67)
27   Honda   S90
27   Honda   EZ-90 (91-95)
27   Honda   ST-90 (73-75)
27   Honda   CB-100K2 "Super Sport 100" (70-72)
27   Honda   CL-100K2 "Scrambler 100" (72)
27   Honda   CL-100S2.S3 "Scrambler 100 5HP (72-73)
27   Honda   XL-100S (81-85)
27   Honda   XR-100R (85-03)
27   Honda   CT-110 (80-86)
27   Honda   CB-125S (73-75)
27   Honda   CB-125S (76-82)
27   Honda   CB-125S (84-85)
27   Kawasaki   KD-80A (75-76)
27   Suzuki   TS-50L (78)
27   Suzuki   TM-75 L/M/A (74-76)
27   Suzuki   TS-75 M/A/B "Colt" (75-77)
27   Suzuki   RM-80 B (77)
27   Suzuki   RM-80 C (78)
27   Suzuki   RV-90 L/M/A/B "Rover" (74-77)
27   Suzuki   DS-100 C/N/T/X (78-81)
27   Suzuki   TS-100 C/N (78-79)
27   Yamaha   YSR-50 T/U/W/A/B/D (87-92)
27   Yamaha   YZ-80 A/B/C/D/E/F (74-79)
27   Yamaha   DT-100 D/E/F/G/H/J/K (77-83)
27   Yamaha   MX-100 F/G/H/J/K (79-83)
27   Yamaha   RT-100 A/D/E/F/G/H/J/K/L/M (90, 92-00)
30   Honda   CR-60R (84)
30   Honda   CR-80R (80-81)
30   Kawasaki   KX-60A1/A2 (83-84),
30   Kawasaki   KDX-80A1-A2/B2-B3/C1-C5 (80-88)
30   Kawasaki   KX-80 A1/A2/C1 (79-81)
30   Kawasaki   KE-100A5-A10 (76-81)
30   Kawasaki   KE-100B1-B20 (82-01)
30   Kawasaki   KLT-110A2 (85)
30   Kawasaki   KLT-160A1 (85)
30   Suzuki   RM-60 K3 (03)
30   Suzuki   RM-80 N/T/X (79-81)
30   Suzuki   RM-80 Z/D/E/F (82-85)
30   Suzuki   TC-90 J
30   Suzuki   B-100 P
30   Suzuki   DR-100 D/E/F/G/H/J/K/L (83-90)
30   Suzuki   RM-100 A/B (76-77)
30   Suzuki   RM-100 C (78)
30   Suzuki   TC-100 K/L/M/A/B "Blazer" (73-77)
30   Suzuki   TS-100 K/L/M/A/B "Honcho" (73-77)
30   Suzuki   TS-100 T/X (80-81)
30   Suzuki   DR-Z110 K3/K4 (03-04)
30   Suzuki   DR-Z125 L K3/K4 (03-04)
30   Suzuki   DS-125 N/X/T (79-81)
30   Suzuki   RV-125 K/L/M/A/B "Tracker" (73-77)
30   Suzuki   TC-125 K/L/M/A/B "Prospector" (73-77)
30   Suzuki   TM-125 K/L/M "Challenger" (73-75)
30   Suzuki   TS-125 R/J/K/L/M/A/B "Duster" (71-77)
30   Suzuki   TS-125 C/N (78-79)
30   Suzuki   DS-185 C (78)
30   Suzuki   GT-185 K/L "Adventurer" (73-74)
30   Suzuki   GT-185 M/A/B "Adventurer" (75-77)
30   Suzuki   TS-185 R/J/K/L/M/A/B "Sierra" (71-77)
30   Suzuki   TS-185 C (78)
30   Suzuki   T 200
30   Yamaha   DT-50 U/W/A DTL/C (88-90)
30   Yamaha   YZ-80 G/H/J (80-82)
30   Yamaha   DT-100 A/B/C (74-76)
30   Yamaha   MX-100 A/B (74-75)
30   Yamaha   DT-125 A/B/C (74-76)
30   Yamaha   MX-125 A/B (74-75)
30   Yamaha   TT-125 RM/RMC (00)
30   Yamaha   TTR-125N/LN/P/LPC/R/LR/S/LS/E/LES (01-04), TZ-125 G (80)
30   Yamaha   YZ-125 A/B (74-75)
30   Yamaha   DT-175 A/B/C (74-76)
30   Yamaha   MX-175 A/B (74-75)
30   Yamaha   TY-175 B/C (75-76)
30   Yamaha   YT-175 J/K (82-83)
30   Yamaha   SR-185 H/J "Exciter" (81-82)
30   Yamaha   RD-200A/B/C (74-76)
31   Honda   CR-80R (82)
31   Honda   CR-80R (83)
31   Honda   SL-100 K (69-70)
31   Honda   XL-100 (74-78)
31   Honda   XL-100S (80 From 5103464)
31   Honda   CB-125TT (90)
31   Honda   CR-125M/M1 "Elsinore" (74-75)
31   Honda   MT-125K (74-76)
31   Honda   SL-125 "Motosport 125" (72-73)
31   Honda   TL-125K "Trials 125" (73-75)
31   Honda   XL-125K/K1 (74-78)
31   Honda   XL-125S (80 From 5005876- 82, 84)
31   Honda   XL-125S (85)
31   Honda   CB-175K3-K7 (69-73)
31   Honda   MR-175 "Elsinore" (76-77)
31   Honda   SL-175K1 (71)
31   Honda   CM-185T "Twinstar" (78-79 To 2111990)
31   Honda   CM-185T "Twinstar" (79 From 2111991)
31   Honda   XL-185S (79-80 To 5006890)
31   Honda   XL-185S (80 From 5006891 - 83)
31   Honda   CB-200T (75-76)
31   Honda   CM-200T "Twinstar" (80 To 2012204)
31   Honda   CM-200T "Twinstar" (80-82)
31   Honda   TR-200 "Fatcat" (86-87)
31   Honda   XR-200 (80-84)
31   Honda   CB-250 "Nighthawk" (91-04)
31   Honda   CM-250C "Custom" (82-83)
31   Kawasaki   KX-80 C2 (82)
31   Kawasaki   KX-125/ A1-A3 (74-77)
31   Kawasaki   KZ-200A1/A2 (78-79)
31   Kawasaki   KZ-250D1/D2 (80-81)
31   Kawasaki   KZ-250L1 "CSR" (82)
31   Kawasaki   EX-305B1 "GP" (83)
31   Suzuki   SP-100 D (83)
31   Yamaha   DT-125 E (78)
31   Yamaha   DT-175 E (78)
32   Kawasaki   KE-175B1-B3 (76-78)
32   Suzuki   DR-125 Z/D/E (82-84)
32   Suzuki   GN-125 Z/D (82-83)
32   Suzuki   GN-125 EM/EN/EP/ER/ES/ET/EV (91-97)
32   Suzuki   SP-125 Z/D (82-83)
32   Suzuki   TS-125 T/X (80-81)
32   Suzuki   DS-185 N (79)
32   Suzuki   DS-185 T (80)
32   Suzuki   TS-185 N (79)
32   Suzuki   TS-185 T/X (80-81)
32   Yamaha   YZ-100 D/E/F (77-79)
32   Yamaha   DT-125 F/G/H (79-81)
32   Yamaha   IT-125 G (80)
32   Yamaha   DT-175 F/G/H (79-81)
32   Yamaha   MX-175 F/G/H (79-81)
32   Yamaha   SR-250 G/H/J/TH "Exciter" (80-82)
33   Honda   CR-80R (84)
33   Honda   CR-80R (85-86)
33   Honda   TLR-200 (86-87) "Reflex"
33   Honda   XL-200R (83-84)
33   Honda   CMX-250C (85-87, 96-04)
33   Honda   CMX-250C2 (99-00)
33   Honda   TL-250K "Trials 250" (75-76)
33   Honda   CB-350F/F1/G (72-74)
33   Honda   CL-350 "Scrambler 350" (72-73)
33   Honda   CB-360/T (75-76), CL-360K (74), CJ-360T (76-77)
33   Honda   CJ-360T (76-77)
33   Honda   CB-400A "Hondamatic" (78)
33   Honda   CB-400T I & T II "Hawk" (78-79)
33   Honda   CB-400T (80 From 2004662 - 81)
33   Honda   CB-400T (80 To 2004661)
33   Honda   CM-400A "Hondamatic" (79-81)
33   Honda   CM-400T (79-81)
33   Honda   CM-400E (80-81)
33   Honda   CM-400T (79-80 To 2114344)
33   Honda   CB-450SC (82-86)
33   Honda   CM-450A/E (82-83)
33   Honda   CX-500 (78-79), CX-500C (79), CX-500D (79)
33   Honda   CX-500C "Custom" (80)
33   Kawasaki   KX-65A1-A5 (00-04)
33   Kawasaki   KX-80E1 (83)
33   Kawasaki   KX-80E2/E3 (84-85)
33   Kawasaki   KZ-305A1/A2 "CSR" (81-82)
33   Kawasaki   KZ-400A1/A2 "Deluxe" (77-78)
33   Kawasaki   KZ-400C1 (78)
33   Kawasaki   KZ-400H1 "Ltd" (79)
33   Kawasaki   KZ-440A1 "Ltd" (80)
33   Kawasaki   KZ-440A2-A4 "Ltd" (81-83)
33   Kawasaki   KZ-440D1 "Ltd" (80)
33   Kawasaki   KZ-440D2-D4 "Ltd" (81-83)
33   Suzuki   RM-65K3/K4 (03-04)
33   Suzuki   RM-80 G/H/J (86-88)
33   Suzuki   GN-250 Z/D (82-83)
33   Suzuki   GS-250 TT/TX (80-81)
33   Suzuki   GT-250 K/L/M/A/B "Hustler" (73-77)
33   Suzuki   GS-300 LZ/LD (82-83)
33   Suzuki   GT-380 J/K "Sebring" (72-73)
33   Suzuki   GT-380 L/M/A/B "Sebring" (74-77)
33   Suzuki   GS-400 B/XB (77)
33   Suzuki   GS-400 C/XC (78)
33   Suzuki   GS-425 N/EN (79)
33   Suzuki   GS-450 ET/ST/EX/SX/EZ/ED (80-83)
33   Suzuki   GS-450 GAZ/GAD (82-83)
33   Suzuki   GS-450 LT/LX/LZ (80-82)
33   Suzuki   GS-450 TX/TZ/TXZ/TXD(81-83)
33   Yamaha   YZ-80 K/L/N/S/T/U/W/A/B/D (83-92)
33   Yamaha   BW-200 ES/ET/EU (86-88)
33   Yamaha   TW-200 T/TC/U/UC/W/WC/A/AC/B/BC/D/DC/E/EC "Trailway" (87-93)
33   Yamaha   TW-200 F/FC/G/GC/H/HC/J/JC/EK/EKC "Trailway" (94-98)
33   Yamaha   TW-200 L/LC/M/MC/N/NC/P/PC/R/RC/S/SC (99-04)
33   Yamaha   SRX-250 T/TC (87)
33   Yamaha   XV-250 U/UC/W/WC/A/AC (88-90)
33   Yamaha   XV-250 G/GC/H/HC/J/JC/K/KC/L/LC (95-99)
33   Yamaha   BW-350 U (88)
33   Yamaha   XS-360 C/D/2D (76-77)
33   Yamaha   XS-400 D/E/2E/F/2F/G/H (77-81)
33   Yamaha   XS-400 SG/SH (80-81)
34   Suzuki   T 250
34   Suzuki   T-250 II
34   Suzuki   TM-250 J/K (72-73)
34   Suzuki   TS-250 R/J/K/L/M/A "Savage" (71-76)
34   Suzuki   TC-305
34   Suzuki   T-350 1 / 2
34   Suzuki   TM-400 R "Cyclone" (71)
34   Suzuki   TM-400 J "Cyclone" (72)
34   Suzuki   TS-400 J/K/L/M/A/B "Apache" (72-77)
34   Suzuki   T-500 1/2/3, T-500M (75)
34   Yamaha   YZ-100 C (76)
34   Yamaha   MX-125 C (76)
34   Yamaha   YZ-125 C (76)
34   Yamaha   DT-250 A/B/C (74-76)
34   Yamaha   DT-250 D/E (77-78)
34   Yamaha   DT1/1B/1S/1C/1C-MX (68-70)
34   Yamaha   DT1E/1MX (71)
34   Yamaha   MX-250/A/B (73-75)
34   Yamaha   TY-250 A/C/D (74, 76-77)
34   Yamaha   RD-350/A/B (73-75)
34   Yamaha   DT-360 A (74)
34   Yamaha   YZ-360 A/B (74-75)
34   Yamaha   DT-400 B/C/D/E (75-78)
34   Yamaha   MX-400 B (75)
34   Yamaha   SC-500/A (73-74)
34   Yamaha   TX-500/A/ XS-500B (73-75)
34   Yamaha   XS1/1B/2/TX-650 (71-73)
34   Yamaha   XS1/1B/2/ TX-650 (70-73)
35   Honda   CR-80R (87-95)
35   Honda   CR-125M "Elsinore" (76)
35   Honda   CR-125M "Elsinore" (77-78)
35   Honda   NX-125 (88-90)
35   Honda   XR-200R (81-83)
35   Honda   CL72 "Scrambler 250"
35   Honda   CR-250M/M1 "Elsinore" (73, 75-76)
35   Honda   MR-250 "Elsinore" (76)
35   Honda   VTR-250 "Interceptor VTR" (88-90)
35   Honda   XL-250 "Motosport 250" (72, 74-76)
35   Honda   XL-250S (78-80 To 5204066)
35   Honda   XL-250S (80 From 5204067 - 81)
35   Honda   XR-250 (79-80)
35   Honda   CL77 "Scrambler 305"
35   Honda   SL-350 "Motosport 350" (72)
35   Honda   XL-350 (74-78)
35   Honda   CL-450 "Scrambler" (69-72)
35   Honda   CB-450 (70-74)
35   Honda   CB-500 "500 Four" (71-73)
35   Honda   CX-500C "Custom" (81-82)
35   Honda   GB-500 (89-90)
35   Honda   GL-500/I (81-82)
35   Honda   XL-500S (79-80 To 5104835)
35   Honda   XL-500S (80- 81)
35   Honda   CB-550 "550 Four K" (74-78)
35   Honda   CB-650 (79-80)
35   Honda   CB-650 (81-82)
35   Honda   CB-650C (80 To 2009951)
35   Honda   CB-750K (69)
35   Honda   CB-750 "750 Four" (70, 72)
35   Honda   CB-750A "750 Hondamatic" (76-78)
35   Honda   CB-750C "Custom" (80-82)
35   Honda   CB-750F "Super Sport" (75-78)
35   Honda   CB-750F (79-80)
35   Honda   CBX (79-80)
35   Kawasaki   KX-80 G1/G2 (86-87)
35   Kawasaki   KX-80 L1-L3/N1-N3 (88-90)
35   Kawasaki   KE-175D1-D4 (80-83)
35   Kawasaki   EX-250E1/E2 "Ninja" (86-87)
35   Kawasaki   KE-250B1-B3 (77-79)
35   Kawasaki   KZ-550H1/H2 "GP" (82-83)
35   Kawasaki   ZX-550A1-A3 "GPz" (84-86)
35   Suzuki   RM-80 K/L/M/N/P (89-93)
35   Suzuki   RM-80 R/S/T/V/W/X/Y/K1 (94-01)
35   Suzuki   RM-100 N/T/X (79-81)
35   Suzuki   DR-125 G/H/J (86-88)
35   Suzuki   DR-125 SER/SES/SET (94-96)
35   Suzuki   RM-125 M/A (75-76)
35   Suzuki   SP-125 G/H/J (86-88)
35   Suzuki   DR-200 G/H/J (86-88)
35   Suzuki   DR-200 SET/SEV/SEW/SEX/SEY/SEK1/SEK2/SK3 (96-03)
35   Suzuki   RL-250 L/M "Exacta" (74-75)
35   Suzuki   SP-250 Z/D/F (82-83, 85)
35   Suzuki   TS-250 1 "Savage" (69)
35   Suzuki   TS-250 B/C/N (77-79)
35   Suzuki   GN-400 T/XT/XX/TX/TZ (80-82)
35   Suzuki   TM-400 K/L/M "Cyclone" (73-75)
35   Suzuki   GS-450 LD (83)
35   Suzuki   GS-450 LF/LG/LH/LJ (85-88)
35   Suzuki   GT-500 A/B "Titan" (76-77)
35   Suzuki   RE-5M, A
35   Suzuki   GS-550 LX/ LZ (81-82)
35   Suzuki   GS-550 B/C/EC (77-78)
35   Suzuki   GS-550 LN/LT (79-80)
35   Suzuki   GS-550 LG (86)
35   Suzuki   GT-550 J/K "Indy" (72-73)
35   Suzuki   GT-550 K (KAYABA)/ L (73-74)
35   Suzuki   GR-650 D/XD "Tempter" (83)
35   Suzuki   GS-650 EX/EZ(81-82)
35   Suzuki   GS-650 GLX/GLZ/GLD(81-83)
35   Suzuki   GS-750 B/C/EC (77-78)
35   Suzuki   GS-750 EX/EZ (81-82)
35   Suzuki   GS-750 LT/LX (80-81)
35   Suzuki   GS-750 TZ/TD (82-83)
35   Suzuki   GT-750 J/K/L/M/A/B "Lemans" (72-77)
35   Yamaha   YZ-100 G/H (80-81)
35   Yamaha   IT-125 H (81)
35   Yamaha   RT-180A/B/C (90-93)
35   Yamaha   XT-200 J/K/KC (82-83)
35   Yamaha   XT-250 G/H/J/K/KC (80-83)
35   Yamaha   TZ-250 C/D/E (76-78)
35   Yamaha   TZ-250 F (79)
35   Yamaha   RZ-350 L/N/NC/NCII (84-85)
35   Yamaha   TZ-350 /C/D/E (72-78)
35   Yamaha   XS-400 J/K "Maxim" (82-83)
35   Yamaha   SR-500 E/F/G/H (78-81)
35   Yamaha   XS-500 C/D/E (76-78)
35   Yamaha   XJ-550 RH/RJ/RK "Seca" (81-83)
35   Yamaha   XZ-550 RJ/RK "Vision" (82-83)
35   Yamaha   XS-650 D/E/F/2F (77-79)
35   Yamaha   XS-650 SE/SF/SG/SH/SJ (78-82)
35   Yamaha   TX-750/A (73-74)
35   Yamaha   XS-750 D (77)
36   Honda   XR-200R (84-02)
36   Kawasaki   KX-80 T2-T4 (92-94)
36   Kawasaki   KX-85 A1-A4 (01-04)
36   Kawasaki   KX-100B5-B7 (95-97),
36   Kawasaki   KX-125 A4-A5 (78-79)
36   Kawasaki   EL-250B2/B3 (88-89)
36   Kawasaki   EX-250F2-F4, F6-F18 "Ninja 250R" (88-90, 92-04)
36   Kawasaki   KL-250A3-A5 (80-82)
36   Kawasaki   KL-250D2-D21 "KLR250" (85-04)
36   Kawasaki   KLX-250A1/A2 (79-80)
36   Kawasaki   KX-250 A/A1/A2 (74-76)
36   Kawasaki   KX-250 A3 (77)
36   Kawasaki   KX-250 A4 (78)
36   Kawasaki   KXT-250A1/A2 (84-85)
36   Kawasaki   KX-400 A1/A2 (75-76)
36   Kawasaki   EN-450A1-A6 "454 Ltd" (85-90)
36   Kawasaki   H1-B/D/E/F (72-75)
36   Kawasaki   EN-500A1-A7 "Vulcan 500" (90-96)
36   Kawasaki   KH-500A8 (76)
36   Kawasaki   KZ-550A1-A2 (80-81)
36   Kawasaki   KZ-550A3-A4 (82-83)
36   Kawasaki   KZ-550C2-C4 "Ltd" (81-83)
36   Kawasaki   KZ-550F1/F2 "Spectre/Ltd" (83-84)
36   Kawasaki   KZ-650B1-B3 (77-79)
36   Kawasaki   KZ-650D1-D2 "SR" (78-79)
36   Kawasaki   KZ-650F1 (80)
36   Kawasaki   KZ-650H1-H3 "CSR" (81-83)
36   Kawasaki   KZ-700A1 (84)
36   Kawasaki   KZ-750B1-B4 (76-79)
36   Kawasaki   KZ-750F1 "Ltd" (83)
36   Kawasaki   KZ-750E1 (80)
36   Kawasaki   KZ-750E2-E3 (81-82)
36   Kawasaki   KZ-750K1/K2 "Ltd" (83-84)
36   Kawasaki   KZ-750M1 "CSR" (82)
36   Kawasaki   KZ-750N1/N2 "Spectre" (82-83)
36   Kawasaki   Z1/A/B 900 (73-75)
36   Kawasaki   KZ-1000A1-A4 (77-80)
36   Kawasaki   KZ-1000D1/ D3 "Z1-R" (78, 80)
36   Suzuki   RM-100 K3 (03)
36   Suzuki   RM-125 B/C (77-78)
36   Suzuki   PE-175 C/N/T/X (78-81)
36   Suzuki   RS-175 T/X/Z (80-82)
36   Suzuki   DR-250 Z/D/E/F (82-85)
36   Suzuki   PE-250 B/C (77-78)
36   Suzuki   PE-250 N/T/X (79-81)
36   Suzuki   RS-250 T/X (80-81)
36   Suzuki   TS-250 T/X (80-81)
36   Suzuki   DR-370 C (78)
36   Suzuki   DR-370 N (79)
36   Suzuki   SP-370 C (78)
36   Suzuki   DR-400 T (80)
36   Suzuki   PE-400 T/X (80-81)
36   Suzuki   SP-400 T (80)
36   Suzuki   DR-500 X/Z/D (81-83)
36   Suzuki   SP-500 X/Z/D (81-83)
36   Yamaha   YZ-80 E1/F1/G1/H1/J1/K1/L1/M1/N1 (93-01)
36   Yamaha   YZ-85P-S (02-04)
36   Yamaha   YZ-100 J/K (82-83)
36   Yamaha   YZ-125 D/E/F/G (77-80)
36   Yamaha   IT-175 D/E/F (77-79)
36   Yamaha   IT-175 G/H (80-81)
36   Yamaha   TT-225 S/T (86-87)
36   Yamaha   TTR-225 L/LC, N/NC/P/PC/R/RC/S/SC (99, 01-04)
36   Yamaha   XT-225 D/DC-S/SC (92-04)
36   Yamaha   DT-250 F (79)
36   Yamaha   IT-250 D/E/F (77-79)
36   Yamaha   IT-250 G (80)
36   Yamaha   XT-250 L/LC (84)
36   Yamaha   TT-250 G/H/J (80-82)
36   Yamaha   TZ-250 G/H/J (80-82)
36   Yamaha   TY-350 N/S (85-86)
36   Yamaha   XT-350 L/LC/N/NC/S/SC/T/TC/U/UC/W/WC/A/AC/B/BC (84-91)
36   Yamaha   XT-350 D/DC/E/EC/F/FC/G/GC/H/HC/J/JC/K/KC (92-98)
36   Yamaha   XT-350 L/LC/M/MC (99-00)
36   Yamaha   IT-400 C/D/E/F (76-79)
36   Yamaha   IT-425 G (80)
36   Yamaha   TT-500 C/D/E (76-78)
36   Yamaha   TT-500 F/G/H (79-81)
36   Yamaha   XT-500 C/D/E/F/G/H (76-81)
36   Yamaha   XV-500K "Virago" (83)
36   Yamaha   XV-535 T/TC/U "Virago" (87-88)
36   Yamaha   XV-535 E/EC/F/FC/SF/SFC/G/GC/SG/SGC "Virago" (93-95)
36   Yamaha   XV-535 H/HC/SH/SHC/J/JC/SJ/SJC "Virago" (96-97)
36   Yamaha   XV-535 K/KC/L/LC "Virago" (98-99)
36   Yamaha   XJ-550 H/J/K "Maxim" (81-83)
36   Yamaha   FJ-600 L/LC/N/NC (84-85)
36   Yamaha   FZ-600 S/SC/T/TC/U/UC (86-88)
36   Yamaha   SRX-600 S/SC (86)
36   Yamaha   YX-600 S/SC/T/TC/U/UC/W/WC/A/AC "Radian" (86-90)
36   Yamaha   XJ-650 G/H "Maxim" (80-81)
36   Yamaha   XJ-650 J/K "Maxim" (82-83)
36   Yamaha   XJ-650 RJ "Seca" (82)
36   Yamaha   XJ-750J/K "Maxim" (82-83)
36   Yamaha   XJ-750RH/RJ/RK "Seca" (81-83)
36   Yamaha   XS-750 2D (77)
36   Yamaha   XS-750 E/F (78-79)
36   Yamaha   XV-750 H "Virago" (81)
36   Yamaha   XV-750 J/K "Virago" (82-83)
36   Yamaha   XV-750 MK "Virago" (83),
36   Yamaha   XS-850 G/H (80-81)
36   Yamaha   XS-850 LG/LH/SG/SH (80-81)
36   Yamaha   XV-920 J "Virago" (82)
36   Yamaha   XV-920 K "Virago" (83)
36   Yamaha   XV-920 MK "Midnight Virago" (83)
37   Honda   CR-80R (96-98)
37   Honda   CR-80R (99-02)
37   Honda   CR-85R (03-04)
37   Honda   CR-125R "Elsinore" (79)
37   Honda   CR-125R "Elsinore" (80)
37   Honda   CR-250R "Elsinore" (78-80)
37   Honda   NX-250 (88-90)
37   Honda   XR-250R (81-82)
37   Honda   CMX-450C (86-87)
37   Honda   CX-500TC (82)
37   Honda   FT-500 "Ascot" (82-83)
37   Honda   VF-500C "Magna" (84-85)
37   Honda   VT-500C "Shadow" (83-84)
37   Honda   VT-500C "Shadow" (85-86)
37   Honda   XL-500R (82)
37   Honda   CB-550SC (83)
37   Honda   CBR-600F "Hurricane" (87-90)
37   Honda   CB-650SC "Nighthawk 650" (82)
37   Honda   CX-650T "Turbo" (83)
37   Honda   VF-700C "Magna" (84)
37   Honda   VFR-700F "Interceptor" (86)
37   Honda   CB-750F (81-82)
37   Honda   VF-750C "V45 Magna" (82-83)
37   Honda   VF-750S "Sabre" (82-83)
37   Honda   VFR-750F "Interceptor 750" (86)
37   Honda   CB-900C "Custom" (80-82)
37   Honda   GL-1000/K "Goldwing" (75-79)
37   Kawasaki   EX-500D1-D11 "Ninja 500R" (94-04)
37   Kawasaki   ZL-600A1/A2 (86-87)
37   Kawasaki   ZX-600A1-A3 "Ninja" (85-87)
37   Kawasaki   ZX-750A1-A3 "GPz" (83-85)
37   Kawasaki   ZX-750E1/E2 "Turbo" (84-85)
37   Kawasaki   ZX-1100A1 "GPz" (83)
37   Kawasaki   ZX-1100A2 "GPz" (84)
37   Suzuki   RM-85 K2-K4 (02-04)
37   Suzuki   XN-85 D "Turbo" (83)
37   Suzuki   GS-500 EK/EL/EM/EN/EP/ER/ES/ET (89-96)
37   Suzuki   GS-500 EV/EW/EX/EY (97-00)
37   Suzuki   GS-550 LD/LF (83, 85)
37   Suzuki   GS-550 ED/ESD/ES3/ ESE/ EF/ESF/ESG (83-86)
37   Suzuki   GS-650 MD "Katana" (83)
37   Suzuki   GS-700 EF/ESF (85)
37   Suzuki   VS-700 GLPG/GLEPG/ GLPH/GLEPH "Intruder" (85-87)
37   Suzuki   GS-750 ED/ESD (83)
37   Suzuki   GS-750 LN (79)
37   Suzuki   GS-750 SD "Katana" (83)
37   Suzuki   GS-850 GN/GT/GX/GZ (79-82)
37   Suzuki   GS-850 GD (83)
37   Suzuki   GS-1000 C/EC/N/EN/ET (78-80)
37   Suzuki   GS-1000GT/GLT/GX/GLX (80-81)
37   Suzuki   GS-1100 ET/EX/EZ (80-82)
37   Suzuki   GS-1100 ED/ESD (83)
37   Suzuki   GS-1100 GZ/GLZ (82)
37   Suzuki   GS-1100 LT (80)
37   Suzuki   GS-1150 ES3/ESE/EF/ESF/EF2/EG/ESG (83-86)
37   Yamaha   XJ-650 LK "Seca Turbo" (83)
37   Yamaha   XJ-900 RK "Seca" (83)
37   Yamaha   XV-920 RH/RJ "Virago" (81-82)
37   Yamaha   XJ-1100 J "Maxim" (82)
37   Yamaha   XS-1100 E/F/G/H (78-81)
37   Yamaha   XS-1100 LG/LH (80-81)
37   Yamaha   XS-1100 LG/LH "Midnight Special" (80-81)
37   Yamaha   XS-1100 SF (79)
38   Honda   CR-125R (81-83)
38   Honda   XR-250R (84-85)
38   Kawasaki   KX-80R2/R3/R4/R5/R6/R7 (92-97)
38   Kawasaki   KX-125 A6-A7 (80-81)
38   Kawasaki   KDX-200 A1-A3 (83-85)
38   Kawasaki   KX-250 A5-A7 (79-81)
38   Kawasaki   KDX-400 A1-A2 (79-80)
38   Kawasaki   KX-420 A1-A2 (80-81)
38   Kawasaki   KL-600A1 "KLR" (84)
38   Kawasaki   ZX-600C1-C6 "Ninja" (88-93)
38   Kawasaki   ZX-600C7-C10 "Ninja 600R" (94-97)
38   Kawasaki   KL-650A1-A18 "KLR650" (87-04)
38   Kawasaki   VN-700A1 "Vulcan" (85)
38   Kawasaki   VN-750A2-A20 "Vulcan" (86-04)
38   Kawasaki   ZX-750F1-F4 "Ninja" (87-90)
38   Kawasaki   ZL-900A1/A2 "Eliminator" (85-86)
38   Kawasaki   ZX-900A1-A3 "Ninja" (84-86)
38   Kawasaki   KZ-1000C1-C4 "Police" (78-81)
38   Kawasaki   KZ-1000J1-J3 (81-83)
38   Kawasaki   KZ-1000K1/K2 "Ltd" (81-82)
38   Kawasaki   KZ-1000P1-P20 "Police" (82-01)
38   Kawasaki   ZL-1000A1 (87)
38   Kawasaki   KZ-1100A1-A3 (81-83)
38   Kawasaki   KZ-1100B1/B2 "GP" (81-82)
38   Kawasaki   KZ-1100D1/D2 "Spectre" (82-83)
38   Kawasaki   ZN-1100B1/B2 "Ltd" (84-85)
38   Suzuki   RM-125 N/T/X/Z (79-82)
38   Suzuki   RM-125 D (83)
38   Suzuki   PE-175 Z/D/E (82-84)
38   Suzuki   RM-250 N/T/X/Z (79-82)
38   Suzuki   RM-400N/T (79-80)
38   Suzuki   LS-650 FG/PG/FH/PH/PJ (86-88)
38   Suzuki   LS-650 PS/PT/PV/PW/PX/PY/PK1/PK2/PK3 "Savage" (95-03)
38   Yamaha   YZ-125 H/J/K (81-83)
38   Yamaha   IT-175 J (82)
38   Yamaha   IT-175 K (83)
38   Yamaha   IT-250 H/J (81-82)
38   Yamaha   YZ-250 D/E/F/G (77-80)
38   Yamaha   FZR-400 U/SUC/W/SWC (88-89)
38   Yamaha   FZR-400 A/SAC (90)
38   Yamaha   YZ-400 D/E/F (77-79)
38   Yamaha   IT-465 H (81)
38   Yamaha   IT-465 J (82)
38   Yamaha   YZ-465 G (80)
38   Yamaha   XT-550 J/K (82-83)
38   Yamaha   FZR-600 W/WC/AC/B/BC (89-91)
38   Yamaha   FZR-600 RA/RAC/RB/RBC/RD/RDC/RE/REC (90-93)
38   Yamaha   FZR-600 RF/RFC/RG/RGC/RH/RHC/RJ/RJC (94-97)
38   Yamaha   XJ-600 SD/SDC/SE/SEC/SF/SFC/SG/SGC "Seca II" (92-96)
38   Yamaha   XJ-600 SH/SHC/SJ/SJC "Seca II" (96-97)
38   Yamaha   FZX-700S/SC/T/TC (86-87)
38   Yamaha   XJ-700N/NC/S/SC "Maxim" (85-86)
38   Yamaha   XJ-700 XN/XNC/XS/XSC "Maxim" (85-86)
38   Yamaha   XV-700L/LC/N/NC "Virago" (84-85)
38   Yamaha   XV-700CS/CSC/CT/CTC "Virago" (86-87)
38   Yamaha   XV-700 J1/J1C (97)
38   Yamaha   XV-750 U/UC/W/WC/A/AC/B/BC "Virago" (88-91)
38   Yamaha   XV-750 D/DC/E/EC/F/FC/G/GC/H1/H1C/J1/J1C "Virago" (92-97)
38   Yamaha   XV-1000 L/LC/N/NC "Virago" (84-85)
38   Yamaha   XV-1100 S/SC/T/TC/U/UC "Virago" (86-88)
38   Yamaha   XV-1100 W/WC/A/AC/B/BC/D/DC/E/EC "Virago" (89-93)
38   Yamaha   XV-1100 F/FC/G/GC/H/HC/J/JC "Virago" (94-97)
39   Honda   XL-350R (84-85)
39   Honda   VT-600C "Shadow VLX"(88-04)
39   Honda   VT-600CD "Shadow VLX Deluxe" (93-04)
39   Honda   VT-600CD2 "Shadow Deluxe" (99-00)
39   Honda   XL-600R (83-87)
39   Honda   CB-650SC (83-85)
39   Honda   CX-650C "650 Custom" (83)
39   Honda   CB-700SC (84-86)
39   Honda   VF-700C "Magna" (85-87)
39   Honda   VF-700F "Interceptor" (84-85)
39   Honda   VT-700C "Shadow" (84-87)
39   Honda   VF-750C "V45 Magna" (88)
39   Honda   VF-750F "Interceptor" (83-84)
39   Honda   VT-750C "Shadow" (83)
39   Honda   VT-800C "Shadow" (88)
39   Honda   CB-900F "Super Sport" (81-82)
39   Honda   CB-1000C "Custom" (83)
39   Honda   CBX (81-82)
39   Honda   CB-1100F "Super Sport" (83)
39   Kawasaki   ZR-550B1-B4 (90-93)
39   Suzuki   GV-700 GLF/GLF2 "Madura" (85)
39   Suzuki   VS-750 GLPJ/GLPK/GLPL/GLPM "Intruder" (88-91)
39   Suzuki   VS-800 GLN/GLP "Intruder" (92-93)
39   Suzuki   VS-800GL R/S/T/V/W/X/Y/K1/K2/K3-K4 "Intruder" (94-04)
39   Yamaha   FZ-700 T/TC (87)
39   Yamaha   FZ-750/N/S/SC/UC (85-88)
40   Kawasaki   KZ-1000E1/E2 "ST/Shaft" (79-80)
40   Kawasaki   ZX-1000A1/A2 "Ninja" (86-87)
40   Yamaha   VMX-12 N/NC/S/SC/U/UC/W/WC/A/AC/B/BC/D/DC (85-92)
40   Yamaha   XVZ-12 DL/DKC2 "Venture Royale" (84)
40   Yamaha   XVZ-12 DN "Venture Royale" (85)
40   Yamaha   XVZ-13 T/TC/U/UC "Venture" (87-88),
40   Yamaha   XVZ-13 DS/DSC/DT/DTC/DU/DUC/DW/DWC "Venture Royale" (86-89)
40   Yamaha   XVZ-13 DA/DAC/DB/DBC/DD/DDCDE/DEC "Venture Royale" (90-93)
41   Honda   CR-250R (81)
41   Honda   XR-250L (91-96)
41   Honda   XR-250R (86-89)
41   Honda   XR-250R (90-04)
41   Honda   XR-350R (83)
41   Honda   XR-350R (84)
41   Honda   XR-350R (85)
41   Honda   CB-400F (89-90)
41   Honda   CR-450R (81)
41   Honda   CBR-600F2 (91-94)
41   Honda   CBR-600SE (98)
41   Honda   XL-600V "Transalp" (89-90)
41   Honda   NT-650 "Hawk GT" (89-91)
41   Honda   NX-650 (88-89)
41   Honda   CB-750 "Nighthawk" (91-03)
41   Honda   RVF-720R (94)
41   Honda   VF-750C "Magna" (94-03)
41   Honda   VF-750C2 "Magna Deluxe" (97-00)
41   Honda   VFR-750F (90-97)
41   Honda   VT-750CDA/B/C/D "Shadow American Classic Ed. Deluxe" (03)
41   Honda   VT-750DC (01-03)
41   Honda   PC-800 (89-90, 94-98)
41   Honda   CBR-1000F "Hurricane" (87-91, 93-96)
41   Honda   VF-1000F "Interceptor" (84)
41   Honda   VTR-1000F "Super Hawk" (98-04)
41   Honda   ST-1100 (91-02)
41   Honda   VF-1100C "V65 Magna" (83-86)
41   Honda   VT-1100C "Shadow 1100" (85-90, 92-96)
41   Honda   VT-1100C2 (95-99)/ C2-2 (97) "Shadow 1100 American Classic Ed."
41   Honda   VT-1100C3 "Shadow Aero" (98-02)
41   Honda   VT-1100D2 "Shadow 1100 American Classic Ed." (99)
41   Honda   VT-1100T "Shadow 1100 American Classic Ed. Tourer" (98-00)
41   Honda   GL-1200 "Goldwing" (84)
41   Honda   GL-1200 I "Interstate" (84-87)
41   Honda   GL-1200L "Ltd" (85)
41   Honda   VTX-1300C (04)
41   Honda   GL-1500 "Goldwing" (88-90)
41   Honda   GL-1500I "Interstate" (91-96)
41   Kawasaki   KX-125 B1 (82)
41   Kawasaki   KX-125 H1 (90)
41   Kawasaki   KDX-200E5-E6 (93-94)
41   Kawasaki   KX-250H1 (90)
41   Kawasaki   KXT-250B1 (86)
41   Kawasaki   EN-500C1-C8 "Vulcan 500 Ltd" (96-03)
41   Kawasaki   EN-500C9 "Vulcan 500 Ltd" (04)
41   Kawasaki   KX-500 E2 (90)
41   Kawasaki   ZX-600D1-D4 "Ninja (ZX-6)" (90-93)
41   Kawasaki   ZX-600E1-E12 "Ninja (ZX-6)" (93-04)
41   Kawasaki   ZX-600F1-F3 "Ninja (ZX-6R)" (95-97)
41   Kawasaki   ZR-750C1-C3 (91-93)
41   Kawasaki   ZR-750F2 (00)
41   Kawasaki   ZX-750K1/K2 "Ninja (ZX-7R)" (91-92)
41   Kawasaki   ZX-750L2-L3 "Ninja (ZX-7)" (94-95)
41   Kawasaki   VN-800 A1-A10 "Vulcan" (95-04)
41   Kawasaki   VN-800 B1-B9 "Vulcan Classic" (96-04)
41   Kawasaki   VN-800 C1-C2 "Vulcan Drifter" (99-00)
41   Kawasaki   ZX-900B1-B4 "Ninja (ZX-9R)" (94-97)
41   Kawasaki   ZG-1000A1-A13 "Concours" (86-98)
41   Kawasaki   ZG-1000A14-A19 (99-04)
41   Kawasaki   ZR-1000A1/A2 (03-04)
41   Kawasaki   ZX-1000B1-B3 "Ninja (ZX-10)" (88-90)
41   Kawasaki   ZX-1100E1-E3 "GPz 1100" (95-97)
41   Kawasaki   ZG-1200A1/B1-B17 "Voyager XII" (86-03)
41   Kawasaki   KZ-1300A1-A4 (79-82)
41   Kawasaki   ZN-1300A1-A6 "Voyager" (83-88)
41   Kawasaki   VN-1500A1-A5 "Vulcan 88/Vulcan 1500"(87-91), VN-1500 B1-B4"Vulcan 88 SE" (87-90)
41   Kawasaki   VN-1500A6-A13 (92-99)
41   Kawasaki   VN-1500 D1-D2 "Vulcan 1500 Classic" (96-97)
41   Kawasaki   VN-1500 E1-E7 "Vulcan 1500 Classic" (98-04)
41   Kawasaki   VN-1500 G1/G1A/G2 "Vulcan 1500 Nomad" (99-00)
41   Kawasaki   VN-1500J1-J2 "Vulcan 1500 Drifter" (99-00)
41   Kawasaki   VN-1500 L1-L5 "Vulcan 1500 Nomad Fi" (00-04)
41   Kawasaki   VN-1500N1-N3 "Vulcan 1500 Classic Fi" (00-02)
41   Kawasaki   VN-1500R1-R4 "Vulcan 1500 Drifter" (01-04)
41   Suzuki   RM-125 L (90)
41   Suzuki   RM-250 K/L (89-90)
41   Suzuki   RMX-250 K/L (89-90)
41   Suzuki   AN-400 K3/K4 (03-04)
41   Suzuki   GSF-400 M/N/P "Bandit" (91-93)
41   Suzuki   GSF-600 ST/SV/SW "Bandit" (96-98)
41   Suzuki   GSF-600 SX//SY/SK1/SK2/SK3 "Bandit" (99-03)
41   Suzuki   GSX-600 FJ "Katana" (88)
41   Suzuki   GSX-600 FK/FL/FM "Katana" (89-91)
41   Suzuki   GSX-600F N/P/R/S/T/V/W/X/Y/K1/K2/K3/K4 "Katana" (92-04)
41   Suzuki   GSX-R600 WN/WP (92-93)
41   Suzuki   AN-650 K3-K4 (03-04)
41   Suzuki   SV-650 SX/SY/SK1/SK2 (99-02)
41   Suzuki   SV-650 S K3-K4 (03-04)
41   Suzuki   GSX-750 FK/FL/FM (89-91)
41   Suzuki   GSX-750F N/P/R/S/T/V/W/X/Y/K1/K2/K3/K4 "Katana" (92-04)
41   Suzuki   GSX-R750 G/H (86-87)
41   Suzuki   GSX-R750 M/N (91-92)
41   Suzuki   VL-800 K1-K4 "Intruder Volusia" (01-04)
41   Suzuki   VX-800 L/M/N/P (90-93)
41   Suzuki   VZ-800 V/W/X/Y/K1/K2/K3/K4 "Marauder" (97-04)
41   Suzuki   GS-1100 GKZ/GK2/ GKD/GKE (82-84)
41   Suzuki   GSX-1100 FJ "Katana" (88)
41   Suzuki   GSX-1100 FK/FL/FM/FN/FP "Katana" (89-93)
41   Suzuki   GSX-R1100 G/H/J (86-88)
41   Suzuki   GSX-R1100 M/N (90-91)
41   Suzuki   GSX-R1100WP/WR (93-94)
41   Suzuki   GV-1200 GLF/GLF2/GLG "Madura" (85-86)
41   Suzuki   GV-1400 (85-89)
41   Suzuki   VS-1400GLP H/J (87-88)
41   Suzuki   VS-1400GLP L/M (90-91)
41   Suzuki   VS-1400GLP N/P/R/S/T/V/W/X/Y/K1/K2/K3/K4 "Intruder" (92-04)
41   Suzuki   VL-1500 W/X/Y/K1/K2/K3 (98-03)
41   Yamaha   YZ-125 W (89)
41   Yamaha   YZ-125 A (90)
41   Yamaha   WR-200 RD (92)
41   Yamaha   YZ-250W/WRW (89)
41   Yamaha   YZ-250A/WRA (90)
41   Yamaha   YZ-250 WRN (89)
41   Yamaha   YZ-250 WRW/WRA (89-90)
41   Yamaha   XT-600 L/LC/N/NC/S/SC/T/TC/U/UC (84-88)
41   Yamaha   XT-600 W/WC/EA/EAC/EB/EBC (89-91)
41   Yamaha   XT-600 ED/EDC/EE/EEC/EF/EFC/EG/EGC (92-95)
41   Yamaha   YZF-600 RG (94-95)
41   Yamaha   YZF-600 RJ/RJC (97)
41   Yamaha   YZF-600 RK/RKC/RL (98-99)
41   Yamaha   XVS-650 AK/AKC/AL/ALC/AM/AMC/AN/ANC/A/AP/APC/AR/ARC (98-03)
41   Yamaha   XVS-650 N/NCP/PC/R/RC (01-03)
41   Yamaha   XVS-650 ATR/ATRC (03)
41   Yamaha   XVS-65 AS (04) "Star Classic"
41   Yamaha   XVS-65 S (04) "Star Custom"
41   Yamaha   FZR-750RT/RU (87-88)
41   Yamaha   YZF-750 RF/RFC (94)
41   Yamaha   YZF-750 RH/RHC/RJ/RJC/RK/RKC (96-98)
41   Yamaha   TDM-850 D/DC/E/EC (92-93)
41   Yamaha   FZR-1000 B/BC/D/DC/E/EC (91-93)
41   Yamaha   FZR-1000 T/TC/U/UC (87-88)
41   Yamaha   YZF-1000 RK (98)
41   Yamaha   FJ-1100 L/LC/N/NC (84-85)
41   Yamaha   XVS-1100 AM/AMC/AN/ANC/AP/APC (00-02)
41   Yamaha   XVS-1100 M/MC/N/NC/P/PC/R/RC (00-03)
41   Yamaha   XVS-1100 R/RC/AR/ARC/ATR/ATRC/AWR/AWRC (03)
41   Yamaha   XVS-1100 S/SC/AS/ASC/ATS/ATSC (04)
41   Yamaha   FJ-1200 AD/ADC/AE/AEC (92-93)
41   Yamaha   FJ-1200 S/SC/T/TC/W/WC/A/AC (87-90)
41   Yamaha   XV17 PCP/PCPC (02) "Road Star Warrior"
43   Honda   CR-125R (84-86)
43   Honda   CR-125R (87)
43   Honda   CR-125R (88-89)
43   Honda   CR-125R (92-93)
43   Honda   CR-125R (94-96)
43   Honda   CR-250R (82)
43   Honda   CR-250R (83-84)
43   Honda   CR-250R (85-87)
43   Honda   CR-250R (88)
43   Honda   CR-250R (92-94)
43   Honda   CR-250R (95)
43   Honda   XR-400R (96-04)
43   Honda   CR-480R (82)
43   Honda   CR-480R (83)
43   Honda   CR-500R (84)
43   Honda   CR-500R (85-87)
43   Honda   CR-500R (88)
43   Honda   CR-500R (92-94)
43   Honda   CR-500R (95)
43   Honda   XR-500R (83-84)
43   Honda   CBR-600F4 (99-00)
43   Honda   CBR-600F4 (01-04)
43   Honda   XR-600R (85-00)
43   Honda   XR-650L (93-04)
43   Honda   VFR-750R (90)
43   Honda   VFR-800/A (02-04) "Interceptor/Interceptor ABS"
43   Honda   CB-900F (02-03)
43   Honda   CBR-929RR (00-01), CBR-929RE (01), CBR-954RR (02-03)
43   Honda   CB-1000 (94-95)
43   Honda   RVT-1000R (00-04)
43   Honda   CBR-1100XX (97-03)
43   Kawasaki   KX-125B2/C1/C2/D1/E1-E2 (83-87)
43   Kawasaki   KX-125 F1 (88)
43   Kawasaki   KX-125 H2 (91)
43   Kawasaki   KDX-200C1-C3 (86-88)
43   Kawasaki   KDX-200E1-E4 (89-92)
43   Kawasaki   KDX-200H1-H10 (95-04)
43   Kawasaki   KDX-250D1-D4 (91-94)
43   Kawasaki   KLX-250D2-D4 (94-96)
43   Kawasaki   KX-250C1-C2/D1-D2/E1 (83-87)
43   Kawasaki   KX-250F1 (88)
43   Kawasaki   KX-250H2 (91)
43   Kawasaki   KLX-300 A2-A9 (97-04)
43   Kawasaki   KX-500A1-A2/B1-B2/C1 (83-87)
43   Kawasaki   KX-500 D1 (88)
43   Kawasaki   KX-500E3-E8 (91-96)
43   Kawasaki   KLX-650A1-A3 (93-95)
43   Kawasaki   KLX-650D1 (96)
43   Kawasaki   ZX-750H1/H2 "Ninja (ZX-7)" (89-90)
43   Kawasaki   ZX-750N1-N2 "Ninja (ZX-7RR)" (96-97)
43   Kawasaki   ZR-1100 A1-A4 (92-95)
43   Kawasaki   ZR-1100 C3-C4 (99-00)
43   Kawasaki   ZX-1100C1-C4 "Ninja (ZX-11)" (90-93)
43   Kawasaki   ZX-1200 C1-C3 (02-04)
43   Suzuki   RM-125 E/F/G (84-86)
43   Suzuki   RM-125 H (87)
43   Suzuki   RM-125 J (88)
43   Suzuki   DR-250 L/M/N/P (90-93)
43   Suzuki   DR-250 SL/SM/SN/SP/SER/SES (90-95)
43   Suzuki   DR-Z250 K1-K4 (01-04)
43   Suzuki   RM-250 D/E/F/G/H (83-87)
43   Suzuki   RM-250J (88)
43   Suzuki   DR-350 L/M/N/P/R/S/T/V/W/X (90-99)
43   Suzuki   DR-350 SL/SM/SN/SP/SER/SES/SET/SEV/SEW/SEX (90-99)
43   Suzuki   RM-465 X/Z (81-82)
43   Suzuki   RM-500 D/E (83-84)
43   Suzuki   SP-600 F (85)
43   Suzuki   DR-650 SET/SEV/SEW/SEX/SEY/SEK1/SEK2/SEK3/SEK4 (96-04)
43   Suzuki   GSX-R750 J/K/L (88-90)
43   Suzuki   GSX-R750 WR/WS (94-95)
43   Suzuki   RF-900 RR/RS/RZS/RT/RV (94-97)
43   Suzuki   DL-1000 K2/K3/K4 (02-04)
43   Suzuki   TL-1000 SV/SW/SX/SY/SK1 (97-01)
43   Suzuki   TL-1000 RW/RX/RY/RK1/RK2RK3 (98-03)
43   Suzuki   GSX-1100 GM/GN/GP (91-93)
43   Suzuki   GSX-R1100 WS/WT/WV/WW (95-98)
43   Suzuki   GSF-1200 K1-K3 (01-03)
43   Suzuki   GSF-1200 SV/SAV/SW/SX/SY/SK1-SK4 "Bandit" (97-04)
43   Suzuki   GSX-1300 RX/RY/RK1/RK2/RK3/RK4 "Hayabusa" (99-04)
43   Yamaha   YZ-125L/N (84-85)
43   Yamaha   YZ-125 S/T (86-87)
43   Yamaha   YZ-125 U (88)
43   Yamaha   YZ-125 B (91)
43   Yamaha   YZ-125 D1/E1/F1/G1 (92-95)
43   Yamaha   IT-200 L/N/S (84-86)
43   Yamaha   IT-250 K (83)
43   Yamaha   TTR-250N/NC/P/PC (01-02)
43   Yamaha   TT-250RM/RMC (99-00)
43   Yamaha   WR-250 ZB/ZD/ZE/ZF/ZG/ZH/ZJ (91-97)
43   Yamaha   YZ-250 H/J/K/L/N/S/T (81-87)
43   Yamaha   YZ-250 U (88)
43   Yamaha   YZ-250 B (91)
43   Yamaha   YZ-250 D1/E1 (92-93)
43   Yamaha   YZ-465 H (81)
43   Yamaha   IT-490 K/L (83-84)
43   Yamaha   YZ-490 U/W/A (88-90)
43   Yamaha   WR-500 ZD/ZE (92-93)
43   Yamaha   TT-600 K/L/N/S (83-86)
43   Yamaha   YZF-R6 L/LC/M/MC/N/NC/P/PC (99-02), YZF-R6 SN/SNC (01)
43   Yamaha   YZF-R6 SR/SS (03-04)
43   Yamaha   FZR-1000 W/WC/A/AC (89-90)
43   Yamaha   VMX-12 E/EC/F/FC/G/GC/H/HC/J/JC/EK/EKC (93-98)
43   Yamaha   VMX-12 L/LC/M/MC/N/NC/P/PC/R/RC/S/SC (99-04)
43   Yamaha   XVZ-13 AH/AHC - AM/AMC (96-00) "Royal Star"
43   Yamaha   XVZ-13 AN/ANC (01) "Royal Star Boulevard"
43   Yamaha   XVZ-13 ATH/ATHC-ATKJ/ATKC (96-98) "Royal Star"
43   Yamaha   XVZ-13 ATL/ATLC (99) "Royal Star Tour Classic"
43   Yamaha   XVZ-13 ATM/ATMC (00) "Royal Star Classic"
43   Yamaha   XVZ-13LTJ/LTK (97-98) "Royal Star"
43   Yamaha   XVZ-13 LTMJ/LTMC-LTN/LTNC (01-02) "Royal Star Tour Deluxe"
43   Yamaha   XVZ-13 TFL/TFLC-TFS/TFSC (99-04) "Royal Star Venture"
43   Yamaha   XVZ-13 TFSM (00) "Venture MM Ltd. Ed."
43   Yamaha   XVZ-13 TFSR/TFMS (03-04) "Royal Star Midnight Venture"
43   Yamaha   XV-1600 AL/ALC-AP/APC (99-02) "Road Star"
43   Yamaha   XV-1600 ALM/ALMC (02) "Road Star MM Ltd. Ed."
43   Yamaha   XV-1600 ATL/ATLC-ATR/ATRC (99-03) "Road Star Silverado"
43   Yamaha   XV-1600 ASN/ASNC (01) "Midnight Star"
43   Yamaha   XV17 AS/ASC/ATS/ATSC (04) "Roadstar"
45   Honda   CR-125R (90)
45   Honda   CR-125R (91)
45   Honda   CR-250R (89-90)
45   Honda   CR-250R (91)
45   Honda   CR-500R (89-90)
45   Honda   CR-500R (91)
45   Honda   CBR-900RR (93-99)
45   Honda   GL-1500C"Valkyrie" (97-00, 03)
45   Honda   GL-1500CF "Valkyrie Interstate" (99-01)
45   Suzuki   RM-125 M/N/P/R/S (91-95)
45   Suzuki   RM-250 M/N/P/R/S (91-95)
45   Suzuki   RMX-250 M (91)
45   Suzuki   RMX-250N (92)
45   Suzuki   RMX-250S/T/V/W (95-98)
45   Suzuki   GSX-R600 V/W/X/Y/K1/K2/K3 (97-03)
46   Honda   CR-125R (97-98)
46   Honda   CR-125R (99)
46   Honda   CR-125R (00-04)
46   Honda   CR-250R (96)
46   Honda   CR-500R (96-01)
46   Honda   XR-650R (00-04)
46   Kawasaki   KX-125G1 (89)
46   Kawasaki   KX-125K3-K5 (96-98)
46   Kawasaki   KX-125L1 (99)
46   Kawasaki   KX-125L2-L3 (00-01)
46   Kawasaki   KX-250G1 (89)
46   Kawasaki   KX-250K3-K5 (96-98)
46   Kawasaki   KX-250L1 (99)
46   Kawasaki   KX-250L2-L3 (00-01)
46   Kawasaki   KX-500E1 (89)
46   Kawasaki   KX-500E9-E16 (97-04)
46   Kawasaki   ZX-600G1-G2 (98-99)
46   Kawasaki   ZX-600J1-J3 "Ninja (ZX-6R)" (00-03)
46   Kawasaki   ZX-900C2 "Ninja (ZX-9R)" (99)
46   Kawasaki   ZX-900F1-F2 "Ninja (ZX-9R)" (02-03)
46   Suzuki   RM-125 K (89)
46   Suzuki   RM-250 K1-K3 (01-03)
46   Yamaha   YZ-125 H1/J1/K1/L1/M1/N1/P/R (96-03)
46   Yamaha   YZ-225 FN/FP (01-02)
46   Yamaha   WR-250 FN/FP (01-02)
46   Yamaha   WR-250 FR/FS (03-04)
46   Yamaha   YZ-250 H1-R (96-03)
46   Yamaha   YZ-400FK/FL (98-99)
46   Yamaha   WR-400 FL/FM (99-00)
46   Yamaha   YZ-426FM/FN/FP (00-02)
46   Yamaha   YZF-450 FR (03)
46   Yamaha   WR-450FR/FS (03-04)
47   Honda   CR-250R (97-98)
47   Honda   CR-250R (99-00)
47   Honda   CR-250R (01-03)
47   Honda   CRF-450R (02-03)
47   Suzuki   RM-125K1-K4 (01-04)
47   Suzuki   RM-250K4 (04)
47.5   Kawasaki   KX-250L4/M1/M2 (02-04)
47.5   Suzuki   RM-Z250 K4 (04)
49   Suzuki   RM-125 T/V/W/X (96-99)
49   Suzuki   RM-125 Y (00)
49   Suzuki   RM-250 T/V/W/X (96-99)
49   Suzuki   RM-250 Y (00)
49   Suzuki   DR-Z400 E Y- K4 (00-04)
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline hahnda
  • lskdfhs;dljksa;
« Reply #9 on: August 12, 2008, 01:46:32 PM »
Front Axle Diameters
Compiled by Hahnda
10mm
Kawasaki KX80 C1 81 (left), KX80 E1 83 (left), KX80 E2/E3 84-85 (right), KD100 M1-M4 76-79 (right), KE100 A5-A10 76-81 (right), KE100 B 82-97 (right), KM100 A1-A7 76-81 (right). Suzuki RM50 78-79 (right), RM60 80 & 82 (right), DS80 78-97 (right), RM80 78-81 (right). Yamaha PW50 81-98, YSR50 88-90, PW80 82-86 & 91-98,YSR80 90-92, Honda C70 80-84, CL70 K1-K3. Kawasaki KX60 B1-B13 85-97 (right), KX80 79-80, KX80 C1 81 (right), KX80 E1 83 (right), KX80 E2/E3 84-85 (left), KD100 M1-M4 76-79 (left), KE100 A5-A10 76-81, KE100 B 82-97, KM100 A1-A7 76-81 (left). Suzuki RM50 78-79 (left), RM60 80 & 82 (left), DS80 78-97 (left), RM80 78-81 (left). Yamaha DT50 80, DT80 81-83, GT80 74-80, MX80 80-82.
12mm
Honda Z50 A/R 68-97, CR60 83-84, CR80 83-02, CR80 R 86-98, XR80 R 85-98, CT90 91-96, XR100 R 85-98, CBX250 H 87, CN250 Helix 86-87 & 92-96, Honda MB50 82, CT70 69-82, CT70 91-94, XL70 74-76, SL70 71-73, XL75 77-79, XR75 73-78, CR80 80-82, XL80 S 80-85, XR80 79-84, CT70 66-79, SL100 70-73, XL100 S 74-80, XR100 81-84, CT110 80-83 & 86, CB125 S 73-84, CR125 M 74-78, CT125 77, MT125 74-76, TL125 73-76, XL125 74-78, XL125 S 70-82, XL185 S 79-83, TLR200 86-87, XR200 80-84, Kawasaki KX80 86-97, KX100 B5-B7 95-97, KX250 74, KX125 74-76 & 78-79 (right), KX125 A6-A7 80-81 (right), Suzuki RM80 90-97, DR100 83-90, RM100 76-78 & 79-81, DR125 82-84 & 86, DR125 S 85-86, DR125 SE 94-95, DS125 78-80, RM125 77-80, SP125 82-84, TS125 71-73 & 76-81, PE175 78-81, TS185 77-81, DR200 85-88 & 90, DR200 SE 96-97, DR250 82-84, DS250 80-81, GN250 80-82, PE250 77-81.RM250 78-80, SP250 82-86, TS250 77-81, DR370 78-79, SP370 78-79, DR400 80, PE400 80-81, RM400 79-80, SP400 80, DR500 81-83, SP500 81-83. Yamaha YZ80 93-97, Kawasaki KX125 74-76 (left), KX125 78-79 (left), KX125 A6/A7 80-81 (left), KE175 D4/D5 82-83, KDX175 80-82 (left), KL250 80-81, Suzuki GN125 82-83, GN125 93-94, RM125 75-76, TS125 74-77, RG250 CH 87, RM250 76-77, TM250 72-75, RM370 76-77, TM400 71-75, Yamaha DT50 88-95, DT100 78-83, MX100 81-83, RT100 90-97, YZ100 77-83, DT125 77-83, IT125 80-83, XT125 82-84, DT175 74-81, SR185 81, XT200 82-85, TY250 77-78, TY250 84 & 91, TZR250 87-88, RZ350 84-89
15mm
Honda CR125 R 79-84, XL200 R 83-84, XR200 81-91 & 93-97, CR250 R 78-84, NX250 88-90, XL250 R 82-87, CL250 S 78-81, XR250 79-80, XR250 L 91-96, XR250 R 81-82 & 84-97, CR450 81, CR480 R 82-83, CR500 R 84, XL500 R 82, XL500 S 79-81, XR500 79-80, XR500 R 81-84, XL600 R 83-87, XR600 R 85-92, Honda CB125 TT 90, XL175 73-78, CM185 Twinstar 78-79, CM200 T 80-82, TR200 G 86, CB250 Nighthawk 91-92, CM250 82-84, CMX250 Rebel 85-86, CMX250 Rebel 96-97, CR250 M 73-76, VTR250 90, XL250 72-76, CB360 74-76, CB400 75-81, CM400 A/B/E 79-81, NS400 RG 96-97, CB450 65-74, CB450 SC Nighthawk 82-85, CB450 Tc 82, CM450 A/C/E 82-84, CMX450 C Rebel 86, Kawasaki KDX250 80-81, KL250 78-79, KX250 75-81, KZ305 B2/B3 87-88, KX400 A1/A2 75-76, KZ400 A/D/S 74-78, KZ400 C1/H1 78-79, KDX420 80-81, KX420 80-81, KZ440 80-83, K440 D6 84, EN450 85-90, Suzuki GS250 T 80-81, GT250 73-77, GT380 73-77, GN400 80-82, GS400, GSF400 Bandit 91-93, GS425 79, GS450 82-83, GS500 89-97, GT500 76-77, RE5 75-76, RG500 86, GS550 All, GSX600 F Katana 89-97, GR650 D/XD/E/F Tempter 83-85, GS650 G/GL 81-83, GS650 EX/EZ 81-82, GS650 M 83, LS650 P 96-97, LS650 Savage 86-88, XN85 Turbo 86-88, GV700 85, GS750 77-86, GSX750 F Katana 89-97, GSX-R750 85-86, GT750 73-77, VS750 Intruder 85-91, VS800 92-97, VX800 90-93, GS850 79-83, GS1000 78-81, GS1100 Chain & Shaft 80-84, GSX-R1100 86, GS1150 84-86, GV1200 Madura 85-86, GV1400 Cavalcade 86-88, XS1400 GL 84-87 & 96-97, Yamaha RD250 73-74, XV250 88-90, XS360 76-77, FZR400 88-89, RD400 79, XS400 77-81, XS400 Maxim/Seca 82-83, XS400 S 80-82, XJ550 R 81-83, XZ550 Vision 82-83, FJ600 84-85 & 89, FZ600 86-88, FZR600 R 89-95, SRX600 C 86, YX600 Radian 86-90, XJ650 80-83, FJ700 Maxim X 85-86, FZ750 85-88, FZR750 87-88, FZX750 Fazer 86-87, XJ750 81-84, XV750 Virago 81-87, XV750 90-98, XS850 80-81, XJ900 R Seca 83, XV920 Virago 81, FZ1000 87-88, XV1000 84-85, FJ1100 84-85, XV1100 86-98, FJ1200 86-93, Kawasaki KX125 B1/B2 82-83 (right), KX125 C1 84, KDX200 A 83-85, KDX200 C 86-88, KDX200 E 89-94, KDX200 95-97, KZ200 A1/A2 78-79, KDX220 H 97, EL250 88-94, EX250 Ninja 86-90 & 92-97, KDX250 82-84, KXD250 D 91-94, KLX250 R 94-96, KL250 D KLR 85-97 (right), KX250 82-84 (right), KZ250 G LTD 80-81, KZ250 82-83 & 85, KLX300 97, EX305 B1-B3 83-85, KZ400 C2 81, EX500 A1-A7 87-93, EX500 D1-D4 94-97, KX500 A 83-84 (right), ZL600 B2/B3 96-97, KLX650 C1-C4 93-96, KLX650 A1-A3 93-96, KL650 87-97 (right), Suzuki RM125 81-86, PE175 82-84, TS200 R 91-93, RM250 81-86, TS250 71-76, DR350 90-96, DR350 S 90-97, TS400 72-77 (left), RM500 83-84, DR600 85-89, DR650 S 90-95, DR750 S 88-89 (left), DR800 S 90 (left), Yamaha YZ125 81-91, IT175 77-83, RT180 91-93 & 95-97, DT200 85-86, DT200 R 89-90 & 95, IT200 84-87, TW200 87-98, WR200 92, TT225 86-87, XT225 92-96, DT250 74-79, IT250 77-83, MX250 73-75, SR250 80-82, TDR250 89-90, TT250 80-83, WR250 Z 91, XT250 80-84, XV250 94-96, YZ250 77-91, YZ250 WR 89-90, TT350 85, TY350 85-86, XT350 85-87 & 92/94/96, DT360 74, MX360 73-74, YZ360 74-75, DT400 75-78, IT400 77-79, MX400 75, YZ400 76-79, IT425 80, IT465 81-82, YZ465 80-81, IT490 83-84, YZ490 82-90, SC500 73, TT500 77-78, XT500 76-81, XV500 Virago 83-85, XT550 82-83, TT600 83-86, Honda CB500 71-76, CX500 78-82, CX500 Tc Turbo 82, FT500 Ascot 82, GL500 81-82, VF500 C Magna V30 84-85, VF500 F Interceptor 84-86, VT500 C Shadow 83-84, VT500 FT 83-84, CB550 F 75-77, CB550 K, CB500 SC Nighthawk 83-84, CBX550 FD 83, CB650 C 79-82, CB650 SC Nighthawk 82-85, CX650 T/E 83-84, GL650 I 83, CB750 A 76-78, CB750 C 80-82, CB750 F 75-78, CB750 F/K/L 79, CB750 K 69-78, CB750 SC 80-85, VF750 C Magna 82-88, VF750 F Interceptor 83-85, VF750 S Sabre 82-85, VT750 C 83-86, VT800 88, CB900 C 80-82, CB900 F 81-82, GL1000 Goldwing L 75-79, VF1000 F 84-85, VF1000 R 84-85, CBX1050 79-82, CB1100 F 83, GL1100 A/I 80-83, VF1100 C, 83-86, VF1100 S 84-85, VT1100 C 85-86, GL1200 A/I/K/SE 84-87, Kawasaki EN500 Vulcan 90-96, EN500 C 96-97, KZ550 A 80-83, KZ550 C 80-83, KZ550 D 81, KZ550 F1/F2 83-84, KZ550 H1/H2 82-83, KZ550 M1 83, ZR550 B1-B4 90-93, ZX550 A 84-86, ZL600 A1/A2 Eliminator 86-87, ZX600 Ninja A1-A3 85-87, ZX600 C1-C4 88-91, ZX600 C8-C10 95-97, KZ650 H1-H3 81-83, KZ750 F1 83, KZ750 H1/H4 80-83, KZ750 K1/K2 83-84, KZ750 L Supersport 83-84, KZ750 N Spectre, KZ750 R 82, KZ750 S1 82, VN750 Vulcan 86-97, ZX750 A1-A3, ZX750 E1/E2 Turbo 84-85, VN800 95-97, ZL900 A1/A2 85-86, ZX900 A1-A3 84-86, KZ1000 J1-J3 81-83, KZ1000 K 81-82, KZ1000 M1 81, KZ1000 P 82-97, KZ1000 R 83, ZG1000 Concours 86-93, ZL1000 A1 87, ZX1000 Ninja 86-87, KZ1100 A1-A3 81-83, KZ1100 B1/B2 81-82, KZ1100 L1/R1 83, KZ1100 R1 84, ZN1100 B1/B2 84-85, ZX1100 A1/A2 83-84, ZG1200 Voyager 86-97, VN1500 Vulcan 87-97, VN1500 B 87-90
17mm
Honda CR125 R 85-94, CR250 88-94, XR400 R 96-97, CR500 R 85-94, XR600 R 93-97, XR650 L 93-97.Suzuki RM125 87-95, RM250 87-95, RMX250 89-96, DR350 97, DR650 SE 96-97. Yamaha YZ125 92-95, WR250 Z 91, YZ250 92-95, Kawasaki KX125 B1/B2 82-83 (left), KX125 C1 84 (left), KX125 D1 85, KX125 86-92, KL250 D KLR 85-97 (left), KX250 82-84 (left), KX250 85-92, KX500 A 83-84 (left), KX500 B1 85, KX500 86-93, KL600 KLR 84-86 (left), ZX600 D ZX-6 Ninja 90-92, KL650 KLR 87-97 (left), KZ650 B 77-79, KZ650 Custom 77-79, KZ650 D 78-79, KZ750 B1-B4 twin 76-79, KZ750 G twin 80, ZR750 Zephyr 91-93, KZ900 76-77, Z1 900 73-75, KZ1000 A/B/G 77-80, KZ1000 E shaft 79-80, KZ1000 D Z1R 78 & 80, ZG1000 Concours 86-93, ZR1100 A1-A5 92-95. Yamaha BW350 86-87, FZR1000 89-93, Kawasaki KZ1000 C Police 78-81, ZX1000 B XZ10 Ninja 88-89, KZ1300 79-82, ZN1300 Voyager 83-88. Suzuki GSX-R1100 88. Yamaha DT100 74-77, RD250 75, RD350 73-75, RD400 76-78, SR500 78-79, XS500 76-78, XV535 Virago 87-98, TX650 74, TDM850 92-93, XS1100 78-79, XJ1100 Maxim 82-83, XS1100 G/H 80-81, XS1100 Special 79-81, VMX12 V-Max 85-97, XVZ12 Venture 83-85, XVZ13 86-93.
20mm
Honda CB400 F 89-90, CBR600 Hurricane 89-90, CBR600 F Hurricane 91-96, CBR600 SE 96, VT600 Shadow 88-97, NT650 Hawk 88-91, CB750 SC 91-93 & 95-97, RVF750 R RC45 94-95, VF750 C/C2/D 94-97, VFR750 F 86, VFR750 F Interceptor 88-97, PC800 Pacific Coast 89-90, CBR900 RR Hurricane 93-97, CBR1000 F 87-88 & 90-91 & 93-96, CBR1100 XX Blackbird 97, VT1100 C Shadow 87-96, VT1100 C2 ACE Shadow 95-97, GL1500 88-97, GL1500 Valkyrie 96-97, Honda VF750 C/C2 98. Kawasaki ZX750 Ninja ZX-7 89-90. Suzuki GSX-R750 88-92, GSX-R750 W 92-95, Honda CR125 00-03, CR125 95-97, CR250 95-97, CR250 00-03, CR500 R 95-97. Kawasaki KX125 93-97, KX250 93-97, KX500 94-97. Suzuki RM125 96-97, RM250 96-97. Yamaha YZ125 96-97, WR250 Z 97-98, YZ250 96-98, Kawasaki ZX600 E ZX-6 93-98, ZX600 F ZX-6R 95-97, VN800 Vulcan Classic 96-97, VN1500 D 96-97, Yamaha YZF750 R 94-97, FZR1000 94-95, XVZ13 Royal Star 96
25mm
Kawasaki ZX750 ZX-7, ZX-7R, ZX-7RR 91-96, ZX900 B ZX-9R 94-97, ZX1100 D ZX-11 93-97, Suzuki GSX-R750 96-97, TL1000 S 97. GSX-R600 97
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline hahnda
  • lskdfhs;dljksa;
« Reply #10 on: August 12, 2008, 01:47:40 PM »
   Japanese Bike Steering Stem Bearing Sizes
   Helpful info when trying to decide if one front end will swap to another. One word of caution. Even though to models may use the same bearings it does not always mean a swap can be made. Steering stem length is also something to keep in mind. For example, the CB750 and CB450 use the same beaing but the CB450 stem is about 1" shorter.
   Compiled by Hahnda
   Upper: 22.5 x 41 x 12.5
   Lower: 24 x 41 x 12.5
Honda   MB-5-50 (82)
Honda   MR-50/K1 (74-75)
Honda   MT50Z, MTX50
Honda   NSF50F (90)
Honda   Z50A/K3-K5/RH/RJ, Z50A (71-76)
Honda   Z50R (79-87), Z50RD (86)
Honda   CR60R (83)
Honda   ATC70/K1 (73-74), ATC70 (78-85)
Honda   CL70/K1-K3 (69-73)
Honda   CT70/K1-K4 (69-76), CT70H/HK1 (70-73), CT70 (76-82)
Honda   SL70/K1 (71-73)
Honda   XL70 (74-76)
Honda   XL75 (77-79)
Honda   XR75 (73-78)
Honda   MB80, MBX80RFD/RSD
Honda   MTX80/C
Honda   XL80S (80-85)
Honda   XR80 (79-84), XR80RF-R (86-98)
Honda   ATC90 (75-85)
Honda   CS90
Honda   CT90 (68-79)
Honda   SL90 (69)
Honda   ST90K1-K4
Honda   CB/CL100/K1-K3 (76-78)
Honda   SL100/K1-K3 (70-73)
Honda   XL100/K1 (74-75), XL100/S (76-85)
Honda   XR100RP-R (85-98)
Honda   ATC110 (79-85)
Honda   CT110 (80-86)
Honda   XL110/S (76-85)
Honda   ATC125M (84-87)
Honda   CB125/S (76-85), CB125T/J (78-81), CB125TT (90)
Honda   CG125
Honda   CM125T/J (82-85)
Honda   CR125M/M1 (74-78)
Honda   CT125 (77), CT125H/J/K (87-89)
Honda   MBX125
Honda   MT125 (74-76), MT125R/RII (77-78)
Honda   SL125/K1/K2
Honda   TL125/K1/K2/S (73-76)
Honda   XL125K-3 (78-79), XL125S (79-85)
Honda   MR175K (75-77)
Honda   ATC185/S (80-83)
Honda   CM185C (78), CM185T (78-79)
Honda   XL185S (79-83), XL185SH/SJ/SK
Honda   XR185 (79)
Honda   ATC200 (79-83), ATC200E Big Red (82-84), ATC200S (84-85)
Honda   CM200T (80-82)
Honda   XR200 (80-83)
Honda   CB250N (Late Models)
Honda   CBX250F (85)
Honda   CM250C (82-86), CM250T (80-82), CMX250C/CD (85-87)
   Upper:30 x 55 x 17
   Lower: 30 x 55 x 17
Suzuki   GSXR600 (97-00)
Suzuki   GSXR750 (96-01)
Suzuki   TL1000R (98-00)
Suzuki   TL1000S (97-01)
Suzuki   GSXR1300R (99-00)
Yamaha   YZFR6 (99-01)
Yamaha   YZF-R1 (99-00)
   Upper: 25 x 47 x 15
   Lower: 30 x 55 x 17
Honda   CB750KZ/FZ
Honda   CB900FZ
Honda   CBX/Z
Honda   GL1000 (77-79), GL1000K3/Z
Kawasaki   KX125 (82-91)
Kawasaki   KDX200 (83-98)
Kawasaki   KX250A5-A7(79-81), KX250B1/C1/C2/D1/D2/E1/F1/G1/H1/H2 (82-91)
Kawasaki   KXT250A1/A2/B1/B2 (84-87)
Kawasaki   KDX420B1 (81)
Kawasaki   KX420A1/A2 (80-81)
Kawasaki   KDX450A1 (82)
Kawasaki   EX500B1-B4 (88-91)
Kawasaki   KX500A1/A2 (83-86) B1/B2 (85-86), C1/D1 (87-88), E1-E3/E4/E5 (89-93)
Kawasaki   ZG1200B1-B12 Voyager (87-98)
Suzuki   DR125SER/SES/SET/SEV (94-97)
Suzuki   RM125J
Suzuki   PE/RS175T-E (80-84)
Suzuki   DR200SET/SEV/ SEW (96-98)
Suzuki   DR250 (90-91), DR250S L/M/N/P/R /SES (90-95)
Suzuki   GN250Z/D/F (82-85), GN250Z-ER (81-95)
Suzuki   GSX250F M/N/P/R (91-94)
Suzuki   PE250T/X (80-81)
Suzuki   RG250G/FG (85)
Suzuki   RGV250K (88-89), RGV250M/N/P/R (91-94)
Suzuki   RM250J (88)
Suzuki   RS250T/X (80-81)
Suzuki   DR350 (90-98)
Suzuki   DR350S L-HR (90-94)
Suzuki   DR350SL/SM/SN/ SP/SER/SES/SET/SEV/SEW (90-98)
Suzuki   DR400T (80) DR400ST
Suzuki   GN400 (80), GN400T/TX/TZ (80-82)
Suzuki   GSF400M (91-93), GS400 Bandit (91-93)
Suzuki   GSX400EE/SE/EF/SF (85), GSX400ET/ST/EX/ SX/X
Suzuki   GSXR400F
Suzuki   PE400T/X (80-81)
Suzuki   GS450E T/X/Z/D (80-83)
Suzuki   GS450G Z/D/F(82-85), GS450L (80-88)
Suzuki   GS450TX/TXZ/TXD/TZ (81-83)
Suzuki   DR500X/Z/D (81-83)
Suzuki   DR/PE500T/X (80-81)
Suzuki   GS500E/EK/EV (89-00), GS500L (80-83)
Suzuki   RG500G
Suzuki   SP500X/Z (81-82)
Suzuki   GS550E (83), GS550EF (85), GS550ESE/ESF (84-86), GS550ESG (86)
Suzuki   GS550ET (80), GS550L (80-83), GS550LF/LG (85-86), GS550MZ (82), GS550TX (81)
Suzuki   GSF600 (1996-00)
Suzuki   GSX600FJ-FW (88-01)
Suzuki   GSXR600WN/WP (92-93)
Suzuki   RF600R (P/R) (93-94), RF600RR/RS /RT (94-96)
Suzuki   DR650RE R/UR (94)
Suzuki   DR650SN/SP (92-93)
Suzuki   GS650D/XD (83), GS650EX/EZ (81-82), GS650GL (81-83), GS650 GX/GZ/ GD (81-83), GS650 MD (83)
Suzuki   LS650F/P/G/J/K, LS650PS/PT/PV/PW Savage (95-01)
Suzuki   NX85D (83)
Suzuki   SV650  (99-00)
Suzuki   GS700EF/ESF (85)
Suzuki   GV700GLF (85)
Suzuki   VS700 (86-87)
Suzuki   DR750S/SU/J/K
Suzuki   GS750ED/ESD (83), GS750ET/EX/EZ (80-82),GS750LT/LX (80-81), GS750SD (83), GS750TZ/TD (82-83)
Suzuki   GSX750EF/F (85), GSX750ES D/E (83-84), GSX750F(89-92), GSX750FK-FT (89-96), GSX750S S/D (83)
Suzuki   GSXR750 (86-95), GSXR750W N/P/R
Suzuki   750T/X (81-82)
Suzuki   VS750G (88-91)
Suzuki   VS800GLN-GLT Intruder (92-01)
Suzuki   VX800L/M/N/P (90-94)
Suzuki   VZ800V/W Marauder (97-01)
Suzuki   GS850G/GL (79-83)
Suzuki   RF900RR/RS/RT/ RV (94-97)
Suzuki   GS1000C/EC/HC/N (78-79), GS1000ET (80), GS1000G/GL (80-81), GS1000L N (79)
Suzuki   GS1000LN/SN/ST (79-80), GS1000SZ (82), GS1000T/HT/ ET (80)
Suzuki   GS1100E (80-83), GS1100G/GL(82-83), GS1100GK (82-84), GS1100LT (80), GS1100SD (83)
Suzuki   GSX1100E/ES/EF, GSX1100E T/X (80-81)
Suzuki   GSX1100EE/ESF/EFF/EF/ESF/EFF (84), GSX1100F (90-93)
Suzuki   GSX1100FJ-FP (88-93), GSX1100G M/N/P/R (91-94)
Suzuki   GSX1100LT/ST (80), GSX1100 LN/SN (79), GSX1100S Z/D (82-83)
Suzuki   GSXR1100 (90-93), GSXR1100F (88-92), GSXR1100G-M (86-91), GSXR1100WP/WR/ WS/WT/WV (93-98)
Suzuki   GS1150EF/EG (85-86), GS1150ES3/ESE/ ESF (83-85)
Suzuki   GSX1150E (83-86)
Suzuki   GSF1200SV/SAV (97-01)
Suzuki   GV1200GLF/GLG (85-86)
Suzuki   GV1400G (86-89)
Suzuki   VS1400 (87-01)
Suzuki   VS1400GL H/R (87-01)
Suzuki   VL1500 (98-01)
Yamaha   BW80S/T/U/A (86-90)
Yamaha   YZ100J/K (82-83)
Yamaha   YZ125D-S (77-86)
Yamaha   IT175D-K (77-83)
Yamaha   IT200L/N/S (84-86)
Yamaha   IT250D/E/F/G/H/J/K (77-83)
Yamaha   TZ250F/G/H/J (79-82)
Yamaha   TZR250R
Yamaha   XT250L/LC (84)
Yamaha   YZ250D-T (77-87)
Yamaha   TT350S/T (86-87)
Yamaha   XT350N/NC-K/KC (85-98)
Yamaha   IT400D/E/F (77-79),
Yamaha   FZR400 (88-90)
Yamaha   YZ400D/E/F (77-79)
Yamaha   IT425G (80)
Yamaha   IT465H/J (81-82), YZ465G/H (80-81)
Yamaha   IT490K/L (83-84), YZ490J-A (82-90)
Yamaha   RZ500N (85)
Yamaha   XT550J/K (82-83)
Yamaha   FZR600 (89-99)
Yamaha   TT600L/N/S/T/U (83-88)
Yamaha   XT600L/LC-G/GC (84-95)
Yamaha   YZF600 (95-00)
Yamaha   XV650 (98-01)
Yamaha   FZ700T/TC (87), FZX700S/T/TC (86-87)
Yamaha   XJ700N/NC/S/SC/XN/XS/XSC (85-86)
Yamaha   XV700 Virago (84-87)
Yamaha   FZ750N/S/SC (85-86), FZ750U/UC (88)
Yamaha   FZR750RT/RU (87-88), FZR750R (90), FZX750 (87-89)
Yamaha   XS750 ALL (77-79)
Yamaha   XTZ750 (93)
Yamaha   XV750 Virago (88-97)
Yamaha   YZF750 (94-98)
Yamaha   XS850 ALL (80-81)
Yamaha   TDM850 (92-93)
Yamaha   XJ900RK (83), XJ900FN (85)
Yamaha   FZR1000 (87-91), FZR1000 EXUP (83-95)
Yamaha   XV1000 Virago (84-85)
Yamaha   FJ1100 (84-85)
Yamaha   XJ1100J (82)
Yamaha   XS1100ALL (78-81)
Yamaha   XV1100 Virago (86-97)
Yamaha   FJ1200 (86-91)
Yamaha   VMX1200 V-Max (85-97)
Yamaha   XVZ1200 Venture (83-85)
Yamaha   XVZ1300 Venture (86-93)
Yamaha   XVZ13 Royal Star
   Upper: 25 x 48 x 16
   Lower: 27 x 48 x 14
Suzuki   RM125A/B/C (75-78)
Suzuki   PE175C/N (78-79)
Suzuki   GS250FW (85)
Suzuki   GSX250T/ET (80)
Suzuki   GT250A/B (76-77)
Suzuki   PE250C/N (78-79)
Suzuki   RM250A/B/C/C2
Suzuki   TM250K/L/M (73-75)
Suzuki   TS250 (70-79)
Suzuki   GS300LF/LZ/LD (82-85)
Suzuki   RM370A/B/C (76-77)
Suzuki   SP370 (78-79)
Suzuki   GT380K-B (73-77)
Suzuki   GS400B/C/EC (77-78)
Suzuki   RM400C (78)
Suzuki   SP400T (80)
Suzuki   TM/TS400 (73-77)
Suzuki   GS425N/EN (79)
Suzuki   GT500A/B (76-77)
Suzuki   RE-Rotary (75-76)
Suzuki   GS550B/C/EC (77-79)
Suzuki   GT550J-B (72-75)
Suzuki   GS750B/C/EC/N (77-79), GS750D C/N (78-79), GS750EN/ LN/LT (79-80)
Suzuki   GT750 (72-77)
   Upper: 25 x 48 x 13
   Lower: 30 x 48 x 13
Suzuki   RM100N/T/X (79-81)
Suzuki   RM125N/T (79-80)
Suzuki   RM250N/T (79-80)
Suzuki   RM400N/T (79-80)
Yamaha   L5T/L5TA-100 (69-70)
Yamaha   RD125B/C (75-76)
Yamaha   RD125LC
Yamaha   TA125 (Roadrace)
Yamaha   TD2/TD2B125 (70-71)
Yamaha   TR2/TR2B125 (70-71)
Yamaha   TZ125G (Roadrace) (80)
Yamaha   YB125E/F
Yamaha   RD200A/B/C (74-76)
Yamaha   YTM200N/ERN (84)
Yamaha   YTM225DRN/DRS (85-86)
Yamaha   YTM225DXL/DXN (84-85)
Yamaha   FZR250
Yamaha   RD250 /LC (73-82)
Yamaha   RD250YPVS (83-84)
Yamaha   SR250G/H/J/TH (80-82)
Yamaha   SRX250N (85), SRX250T/TC (87)
Yamaha   TD3/TR3-250 (Roadrace) (72)
Yamaha   TZ250 (73), TZ250C/D/E (76-78)
Yamaha   TZR250 (87-91)
Yamaha   XS250
Yamaha   XV250U-W (88-89), XV250A/AC (90), XV250G/GC/H/HC/J/JC (95-99)
Yamaha   R5/B/C (70-72),RD350 (73-79), RD350LC (80-82)
Yamaha   RD350YPVS (83-84), RZ350L/N/NC (84-85)
Yamaha   TZ350C/D/E (74-78)
Yamaha   XS360C/D/2D (76-77)
Yamaha   RD400A/B/C/D (76-79)
Yamaha   XJ400 (80-85)
Yamaha   XS400E/F/2E/2F (77-79), XS400G/H/J/K (80-83), XS400RJ/RK (82-83), XS400SG/SH (80-82)
Yamaha   XV500 (83) XV535 (87-99)
Yamaha   XV535 (91-94), XV535H/N (89-90), XV535SE (88), XV535T/TC/U/A/ AC/EC/F/FC/G/GC/ SFC/SG/SGC/SH/SHC/SJ/SJC (87-97)
Yamaha   XJ550H/J/K/RH/RJ/RK (81-83)
Yamaha   FJ600L/LC/N/NC (84-85)
Yamaha   XJ600 (92-98)
Yamaha   YX600 (86-90)
   Upper: 25 x 43 x 11
   Lower: 30 x 48 x 12
Yamaha   DT50B, DT50MX, DT50U/W/A (88-90)
Yamaha   RD50MX (82), RX50K/L/MK (83-84)
Yamaha   YSR50T-E (87-93)
Yamaha   YZ50G (80)
Yamaha   JT1/JT2/JT2MX (71-72)
Yamaha   RD60/A/B (73-75)
Yamaha   YZ60H/J/KM (81-83)
Yamaha   DT80LC H/J/K (81-83), DT80MX
Yamaha   GT80A-G (74-80), GT1/GTMX80 (73), GTMXA/MXB/MXC 80 (77-79), MX80G/H/J (80-82)
Yamaha   RD80LC/MX(82)
Yamaha   TY80A/B Trials (74-75)
Yamaha   YZ80A-K (74-83)
Yamaha   HT1/HT1B/HT1BM90 (70-71)
Yamaha   AG100B
Yamaha   DT100A-K (74-83)
Yamaha   LT2/LT2M/LT2MX/LT3100 (72-73)
Yamaha   MX100A/B (74-75)
Yamaha   MX100F/H/J/K (79-83)
Yamaha   RS100B/C (75-76)
Yamaha   RT100A (90)
Yamaha   YZ100C/D/E/F/G/H (76-81)
Yamaha   AT1/AT1B/AT1C/ AT1E/AT1M/AT1MBAT1MX/AT2/AT2M/AT2MX/AT3/ 125 All (69-73)
Yamaha   DT125 All (74-81), DT125LC (82)
Yamaha   IT125G/H (80-81)
Yamaha   MX125A/B/C (74-76)
Yamaha   XT125J/K/KC (82-83)
Yamaha   YT125N (85)
Yamaha   YZ125A/B/C/X (74-76)
Yamaha   AG175B
Yamaha   CT1/CT2/CT3 175 All (69-73)
Yamaha   DT175A-H (74-81)
Yamaha   MX175A/B (74-75)
Yamaha   MX175G/H/J (79-81)
Yamaha   TY175B/C (75-76)
Yamaha   YT175J/K Atv(82-83)
Yamaha   YZ175C (76)
Yamaha   SR185H/J (81-82)
Yamaha   AG200
Yamaha   BW200N/S/ES/ET/ EU (85-88)
Yamaha   TW200 (87-92)
Yamaha   TYM200EX/EL (83-84)
Yamaha   XT200J/K/KC (82-83)
Yamaha   YTM200K/EK (83), YTM200K/L (83-84)
Yamaha   YTM225DXK (83)
Yamaha   DT1/DT1B/DT1CMX/DT1MX/DT1S/ DT1C/DT1E/DT2/ DT2MX/DT250A-F/DT3 250 (68-79)
Yamaha   MX250A/B (73-75)
Yamaha   TT/XT250G/H/J (80-82)
Yamaha   TY250A/C/D (74-77)
Yamaha   XT250G/H/J/K/KC (80-83)
Yamaha   XT250W (89)
Yamaha   YZ250A/B/C (74-87)
Yamaha   DT360A/B (74-75),
Yamaha   MX360/A (73-74)
Yamaha   RT1/RT1B/RTM/RT1MX360 (70-71)
Yamaha   RT2/RT3/RT2MX360 (72-73)
Yamaha   YZ360A/B (74-75)
Yamaha   DT400B/C/D/E (75-78)
Yamaha   IT400C (76)
Yamaha   MX400B/C (75-76)
Yamaha   YZ400B/C (75-76)
Yamaha   SC500/A (73-74)
Yamaha   SR500E/F/G/H (78-81)
Yamaha   TT/XT500C-H (76-81)
   Upper: 25 x 47 x 15
   Lower: 28 x 52 x 16.5
Kawasaki   KL250D2-D8 (85-91), KLR250 (-98)
Kawasaki   ZX400K1/K2/K3
Kawasaki   EN450A1-A7 (85-91), EN450N
Kawasaki   EN500A1-A6 (90-96), EN500C1/C2 Vulcan Ltd (96-97)
Kawasaki   GPZ550H1
Kawasaki   KZ550F1/F2/M1 (83-84), KZ550H1/H2 (82-83)
Kawasaki   Z550G6, Z550M1 Ltd (83)
Kawasaki   ZR550B1-B5 (90-94)
Kawasaki   ZX550A1/A2 (84-85)
Kawasaki   GPX600R
Kawasaki   KL600A1/B1/B3 (84-86)
Kawasaki   ZX600 Ninja (85-97)
Kawasaki   KLR650/B2 Tengai (89)
Kawasaki   KL650A1-A11/B2/ KLR (87-97)
Kawasaki   KZ700A1 (84)
Kawasaki   ZN700A1/A2 (84-85)
Kawasaki   GP750R, GPZ750R/R1
Kawasaki   KZ750F1, KZ750L3 (83)
Kawasaki   KZ750N1/N2 (82-83), KZ750R1 (82)
Kawasaki   VN750A2 (86)
Kawasaki   ZR750C1-C4 (91-94), ZR750 Zephyr
Kawasaki   ZX750A1-A3/E1/E2/ F1-F4/H1/H2
Kawasaki   GPZ900R
Kawasaki   ZL900A1/A2 (85-86)
Kawasaki   ZX900A1-A3 (84-86)
Kawasaki   KZ1000J1-J3/K1/K2/ M1/M2 (81-82), KZ1000P1-P17 (82-98), KZ1000R1/R2 (82-83)
Kawasaki   Z1000K1 LTD (82)
Kawasaki   ZG1000A1-A9 (86-94)
Kawasaki   ZL1000A1 (87)
Kawasaki   ZX1000A1/A2 (86-87), ZX1000B1-B3 (88-90)
Kawasaki   GPZ1100A/S, B/S (81-82)
Kawasaki   KZ1100A1-A3 (81-83), KZ1100B1/B2 (81-82), KZ1100D1/D2 (82-83), KZ1100L1 (83)
Kawasaki   Z1100J/J2/Z
Kawasaki   ZN1100B1/B2 (84-85)
Kawasaki   ZR1100A1/A2 (92-93)
Kawasaki   ZX1100A1-A2 (83-84)
Kawasaki   VN15SE
Kawasaki   VN1500A1-A9 (87-95)
Kawasaki   VN1500B1-B5 (87-91)
Kawasaki   VN1500A10/A11/C3/C4/D1/D2 (96-97)
   Upper: 26 x 48.5 x 15.2
   Lower: 30 x 50 x 14.4
Honda   C250N (79)
Honda   CB250 (Early Models)
Honda   CB250RS (80-84)
Honda   CBX250RS
Honda   CM250T Rebel (82-84)
Honda   GB250F/F2
Honda   MVX250 (83-84)
Honda   VT250F (83-86), VTR250 (88)
Honda   CB350F/F1 (73-74), CB350G (73), CB350/ K2-K4 (69-72)
Honda   SL350 /K2/K3 (69-73)
Honda   CB360 (74-76), CB360GT (76), CB360T (74-77)
Honda   CJ360T (76-77), CL360 (74-75)
Honda   CB400A (74-75), CB400F (75-77), CB400TI/TII (78-79), CB400T (80-81)
Honda   CBX400F
Honda   CM400A/C/E/T (79-81)
Honda   GB400
Honda   CB450/K1-K7 (65-74), CB450T (82), CB450SC (82-86)
Honda   CL450 /K2-K6 (68-74)
Honda   CM450A/C/E (82-83)
Honda   CB500/K1/K2 (71-73), CB500T (75-76)
Honda   CX500 C/D (78-81)
Honda   FT500 Ascot (82-83)
Honda   GB500F/F2
Honda   GL500/I (81-82)
Honda   VT500 Ascot (83-84), VT500ED, VT500C/FT (83-84)
Honda   CB550K/K1 (74-78), CB550F (75-77), CB550SC (83)
Honda   CBX550F (82-83)
Honda   CB650 (79-82), CB650C (80-81), CB650SC (82-85), CBX650ED/SCD
Honda   CX650C (83), CX650ED
Honda   GL650/I (83)
Honda   VT700C (84-85)
Honda   CB750K (69-78), CB750A (76-78), CB750F (75-78)
Honda   VFR750C (83)
Honda   VT750C (83)
Honda   GL1000 (75-76)
Honda   GL1000L (76)
   Upper: 30 x 48 x 14
   Lower: 30 x 48 x 14
Kawasaki   KH250A5 (76)
Kawasaki   KZ250A
Kawasaki   EX350B1 (83)
Kawasaki   KZ350A1/A2/B1 (81-82), KZ350B2/B3 (87-88)
Kawasaki   KH400A3-A5 (76-78)
Kawasaki   KZ400A1/A2 (77-78), KZ400B1/B2/C1 (78-79)
Kawasaki   KZ400D/D3/D4 (74-77), KZ400H1 (79), KZ400S/S2/S3 (75-77)
Kawasaki   ZX400D1-D5 (80-83)
Kawasaki   KZ440A1-A4/D1-D5 (80-83), KZ440B1/B2 (80-81)
Kawasaki   H1 500 C/D/E/F (69-75), KH 500A8 (76)
Kawasaki   KZ500 (69-73)
Kawasaki   H2 750 A/B/C (72-75)
   Upper: 30 x 48 x 14
   Lower: 30 x 52 x 17
Kawasaki   EL250B2/B3 (88-89), EL250E1/E2 (91-92), EL250D4/D5 (93-94)
Kawasaki   EX250E/E2/F2-F4 (86-90), EX250 F6/F7/F8/F9,F10/ F11 Ninja250R (92-97), EX250 H1-H5 (90-94)
Kawasaki   ZX400H1/H2, ZXR400R
Kawasaki   EX500A1-A7 (87-93), EX500D1-D4 (94-97)
Kawasaki   KZ550A1-A4/C1-C4 (80-83), KZ550D1 (81)
Kawasaki   KZ650B1-B3/C1-C4/D1/D2/E1/F1/H/ H1-H3
Kawasaki   KZ750B1-B4 (76-79), KZ750E1-E3 (80-82)
Kawasaki   KZ750G1 (80), KZ750H1-H4(80-83), KZ750K1/K2 (83-84), KZ750M1 (82), KZ750T
Kawasaki   KZ900A4/B1 (76)
Kawasaki   Z1 900A/B (73-75)
Kawasaki   Z1R Series (78-80)
Kawasaki   KZ1000A1-A4/B1-B4 (77-80), KZ1000D1 (78), KZ1000D3/G1 (80)
   Upper: 25 x 48 x 15.2
   Lower: 30 x 48 x 15
Yamaha   FZR400R
Yamaha   SXR400
Yamaha   SX500B/C/D/E (75-78), TX500/A (73-74)
Yamaha   XS550RK/RJ (82-83), XZ550RK/RJ (82-83)
Yamaha   FZ600 (86-88)
Yamaha   SRX600S/SC (86), SRX600T
Yamaha   TX650/A (73-74)
Yamaha   XJ650G/H//J/K (80-83), XJ650LH (81), XJ650LJ/LK/RJ (82-83)
Yamaha   XS6501/1B/XS2 (70-72), XS650B-H/2F (75-81), XS650SE-SH (78-81), XS650SJ/SK (82-83)
Yamaha   TX750 (73-74)
Yamaha   XJ750J/K/MK/RH/RJ/RK (81-83)
Yamaha   XV750H/J/K/MK (81-83), XV750SE (82)
Yamaha   XV920J/K/MK (82-83), XV920RH/RJ (81-83)
Yamaha   XV1000K/L Virago (83-84)
   Upper: 26 x 47 x 15
   Lower: 30 x 55 x 17
Honda   NSR250R/F
Honda   VTR250 (89-91)
Honda   CBR400R (87)
Honda   CBR400 R/R
Honda   NS400RF/RG (85-86)
Honda   VFR400ZG/RG
Honda   CMX450C (86-87)
Honda   CX500TC (82)
Honda   VF500C (84-85), VF500F (84-86), VF500FE/FIIE/FF
Honda   VT500C (85-86)
Honda   CBR600 (89-90)
Honda   CBR600F (87-90), CBR600 FM-FR (91-97), CBR600H
Honda   VT600CJ (87), VT600C N-R (92-94)
Honda   VT600C/CD Shadow VLX (88-97
Honda   CX650T (83)
Honda   NT650 (88-89)
Honda   NT650J Revere
Honda   CB700SC (84-86)
Honda   VF700C (84-87)
Honda   VF700F/S (84-85)
Honda   VFR700F/F2
Honda   CB750C/F/K (80-82)
Honda   CB750F N-S (92-95)
Honda   CB750FA/FB/FC/ F2C
Honda   CB750SC (84-85)
Honda   CBX750FE/F2F (84-86)
Honda   VF750C (82-83)(88)
Honda   VF750CC/CD/CE/SC/SD
Honda   VF750F (83-84)
Honda   VF750 F D/E/F (83-85)
Honda   VF750FD
Honda   VF750S (82-83)
Honda   VFR750 (90-93)
Honda   VFR750F/F2 (82-87), VFR750F L-S (90-95)
Honda   VFR750FG/FH/FJ/FK/ FL
Honda   VT800 (88-89)
Honda   VT800C Shadow(88)
Honda   PC800 Pacific Coast (89-98)
Honda   CB900C (80-82), CB900F A/B/2B/C/2C (80-82), CB900FS(94)
Honda   CBR900RR (93-98)
Honda   CB1000C (83), CB1000F S (95)
Honda   CBR1000 (87-93)
Honda   CBR1000F (87-88)(90-96)
Honda   CBX B/C (81-82)
Honda   VF1000F (84-85), VF1000FE/FF/F2F, VF1000R (85-86)
Honda   GL1100 (80-83), GL1100C/AC/DC/IC, GL1100D2D/AD/A/IA/DA, GL1100RB/RC/D/ID/DD
Honda   VF1100C (83-86), VF1100S (84-85)
Honda   VT1100C (85-89), VT1100C R-S (94-95)
Honda   GL1200 (84-87)
Honda   GL1500 (88-91)
Honda   GL1500 AP-AR (93-94)
Honda   VTX1800C (02)
   Upper: 26 x 47 x 15
   Lower: 26 x 47 x 15
Honda   CR80RL-RR (90-94 )
Honda   CR125R (82-89)
Honda   NX125 (88-90)
Honda   XL200R (83-84)
Honda   XR200R (81-87), XR200RE/RF/RG/RH/RJ
Honda   ATC250R (83-86)
Honda   CR250R (82-89), CR250RE/RF/RG/RH/RJ/RK
Honda   XL250R (82-87), XL250R E/F (84-85), XL250R J/K/L (88-90)
Honda   XR250RE/RF/RG/RH/RJ/RK, XR250R N-R (92-94)
Honda   XL/XR350R (83-85)
Honda   XR350RD/RE/RF/RG/RH/RJ/RK
Honda   XR400R (97-98)
Honda   CR450R (81)
Honda   CR480R (82-83)
Honda   CR500R (84-89)
Honda   XL500R (82)
Honda   XR500R (81-84)
Honda   XL600R (83-87), XL600RC/RF (85)
Honda   XL600RD/LD/RE/RF/RG/V-VH(Transalp)
Honda   XR600R (85-89), XR600RH/RJ/RK
Honda   CB750F/K/L (79)
Honda   CBX1000 (79)
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline sinister902
    • Anger Street Kustoms
Re: Modern Parts on Classic Bikes? See here!
« Reply #11 on: August 12, 2008, 02:13:32 PM »
sinister902: That's great news. What model did 750 was the arm from? The later wider/longer or the early arm? I hear they are the same at the pivot. I intend on using a sportbike mag on the rear so I'll be doing something custom with the chain centerline anyway. Thanks for the contribution.
I actually do not know because it was a junkyard find that i nabbed for $20 for the whole rear end. If it makes a difference, i layed the 750 swingarm over my 550 swingarm, and they were the same length...but the 750 swingarm is "boxed" tubing rather than round tubing, and doesnt taper from the axle point down to the pivot point like the 550 arm tapers.
Offline bradweingartner
  • 74 CB 550 x2
« Reply #12 on: August 12, 2008, 04:56:13 PM »
holy #$%* Kevin. You sir, are the man of the hour!  ;D
That's an awesome start, I'll start working on it tonight.
sinister902: Sounds like a pre-78 or whichever. Was it a lot wider than the 550?
Offline MJL
  • Don't listen to me, I'm no
« Reply #13 on: August 12, 2008, 06:13:30 PM »
That is quite a lot of data!  Now I just need to figure out the span between them so i know if I can just bolt new forks and whell to my stock triple clamps.
Offline sinister902
« Reply #14 on: August 13, 2008, 05:34:18 AM »
seemingly yes, but not enough to have clearance issues....
I thought i took a pic, ill try to dig it up later today
MrFluffy
« Reply #15 on: May 04, 2010, 01:13:37 AM »
I know Im dredging up a thread from the dead here, but its kind of interest to people and of relevance and popped up in google while searching for dimensions so forgive my threadcrophylia :)
Pretty much all the marquee camps of oldskool bikes are wrestling with the above, and ive started a site dedicated to hardcore modification of aircooled oldskool bikes, oldskool being defined as cooled by air or oil/air. Ive started a few threads to capture dimensions of modern donors for swingarms, we've got some dimensions of usd front ends etc and theres loads of people who've swapped in modern rubber and suspension. There are even some cbx and a few dohc (and currently a solitary sohc) owners in there. If we get our act together, the sites going to be taking on a cb900 (yeah I know its a dohc but...) project to carve about.
There will be banter, and some mickey taking happens but it wont degenerate into anything and would get nipped in the bud (although Ive only had to do that once). We're all bikers and we all dig aircooled stuff and modifications no matter who's name's on the tank.
Its not a place if you like to look at untouched originals, or modern watercooled stuff.
I hope the moderators wont mind me posting the url, since I think its of interest to the people here who might have the urge to take this route and the site could never even begin to replace the expertise gleaned from the make specific ones so its not even really in competition in any way. If you want me to drop a link into the links page for this place ive got no problem, and if people are on there and see a topic that really deserves to be answered here, Ive got no objection to people saying "hey, thats something you'd get a better response to on http://forums.sohc4.net/blahblah". Information just wants to be free and the more we all share it the better our bikes get.
The url is http://www.oldskoolperformance.com/forum
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #16 on: May 04, 2010, 05:09:02 AM »
   Upper: 25 x 47 x 15
   Lower: 30 x 55 x 17
Honda   GL1000L (76)
 Here's a correction to that list. The 78-79 GL upper bearing size should be 26 x 47 x 17.3 instead of 25 x 47 x 15 that is shown. The steering stems are the same on the 75-77 GL and the 78-79 GL.
A link;
http://forums.sohc4.net/index.php?topic=46362.msg486489#msg486489
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
  • 74 CB 550 x2
« Reply #17 on: May 04, 2010, 09:56:20 PM »
Blast from the past!!!  ;D
I have all my parts saved up, packed neatly away for some time off. I ended up with a career that requires me to be away from home (across country) 300+ days a year. Haven't ridden since summer of 2008 even  >:(
I can't be too upset, I have good work in a bad economy. I'm throwing up the white flag this year and taking three+ months off this summer with projects like this in mind. I'll keep everybody updated!
Thanks for the correction to the measurements. I have compiled all the dimension data into a spreadsheet and will need to convert it to a database someday when I have time to build the front-end.
chasanova
« Reply #18 on: July 11, 2010, 08:40:14 AM »
perhaps you could post the spreadsheet for posterity?
Offline Alan F.
« Reply #19 on: July 11, 2010, 10:28:07 AM »
Check the link in my sig line if you've never seen it, there are some documents there that I've collected together on the subject, but no measured parts diagrams.
-Alan F.
  • 74 CB 550 x2
« Reply #20 on: July 23, 2010, 03:01:38 PM »
I'll see dig it up!
