Author Topic: cb650c Spark pugs... wtf is with #2 & #3  (Read 1415 times)
BigDaddyP77
« on: August 12, 2008, 08:44:57 AM »
After dumping my bike and haveing to wait for replacement parts, i decided to take off the carbs to clean them as well as install the set of iridium plugs i've had for a month.  I got #1 and #4 done no prob, how the hell are you supposed to get #2 and #3 changed?   You can't fit a deep socket in the space and you can fit a shallow socket in but of course, it's to shallow to be useful.  does ANYONE have and tips on how to get around this stupid design flaw???????
Offline eurban
Re: cb650c Spark pugs... wtf is with #2 & #3
« Reply #1 on: August 12, 2008, 09:13:37 AM »
Use the the spark plug removal tool that comes in the OEM tool kit.  Or in your case, locate, buy and use the previously mentioned tool . . .You might find a suitable spark plug tool at Sears etc but the stock tool really works the best.
Offline NickC
« Reply #2 on: August 12, 2008, 09:21:06 AM »
I got mine from the honda dealer. I think it was about 10 or 15 bucks, but I couldn't find any other way. Not to mention it works great
upperlake04
« Reply #3 on: August 12, 2008, 09:32:37 AM »
You can custom make one..
BigDaddyP77
« Reply #4 on: August 12, 2008, 12:45:03 PM »
Interesting custom tool.  I might be able to do that.  i'll cann honda too.  as for the OEM tool kit...MIA when i bought the bike.
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #5 on: August 12, 2008, 12:53:45 PM »
Buy an 18mm spark plug socket or an 18mm socket and fire that grinder up.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline tomkimberly
« Reply #6 on: August 12, 2008, 04:35:17 PM »
Removing the tack drive sure make getting to the # 3 plug much easier.
Tom
Offline WFO
  • Will work for powerbands
« Reply #7 on: August 12, 2008, 04:41:56 PM »
To install the plugs slide a length of fuel line into the top of the plug it helps avoid cross threading, i have a 650 and ran into the same problem i used the tool kit for removal.
82 cb650 sc nighthawk - 78 kz 650 b
