Author Topic: 750 K0 front sprocket cover.....unique to K0's?  (Read 3201 times)
Offline zoo mob
« on: August 22, 2008, 01:13:01 AM »
My K0 came missing the front sprocket cover, I thought I'd just swap the one from my 73 K3 before a ride recently, only it wouldn't fit, and looks to be clearly different. The guard on the K0 prevents a proper fit. Does anybody have any insight as to when this change was made or what bike have a cover that will work for me?
Here's the 1970 K0
and here's the 73 K3
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline Jonesy
  • Shop Rat
Re: 750 K0 front sprocket cover.....unique to K0's?
« Reply #1 on: August 22, 2008, 05:02:13 AM »
That parts shows up in the K0 parts diagram. As I recall, it was a band-aid for the early chain jumping problems related to the tiny front sprocket (which led to the demise of many a sandcast case) until Honda upped the size to improve the chain wrap (and subsequent wear).
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: August 22, 2008, 05:38:27 AM »
Factor in also the fact that the cases were redesigned between K0 and K1.  Later guards won't fit, and finding a K0 guard in good shape is rather a challenge.
mystic_1
- John Augustus Shedd
rhos1355
« Reply #3 on: August 22, 2008, 05:44:32 AM »
I too was trying to mix n' match some parts between bike models a short while ago and I got this invaluable advice from DustyC:
"Cross reference here:  http://www.cmsnl.com
You have to register.  Search the fiche for your bike to find the part numbers you're looking for.  Search by part number will give you your cross reference of other bikes that part was used on."
So you have to know what is the part number of the cover, enter it and if it's the same on any other bike it'll say which bike.
Hope that helps
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: August 22, 2008, 05:46:39 AM »
I've never had to register at cmsnl ???
mystic_1
« Reply #5 on: August 22, 2008, 09:50:50 PM »
That guard is not used on all the sandcasts, it came out after the start of production.
Offline City Boy
« Reply #6 on: August 22, 2008, 10:18:32 PM »
I don't think the case guard was used on any sand cast models.I recall it being offered to owners for free,with a new cover with milled surface to sandwich the guard between the cover and case.These bits became available shortly after I bought my K0 in April of 70.There was a flurry of upgrades and recalls shortly after my purchase.New throttle cables,slides and springs,the case guard,and a new set of exhaust pipes due to premature rust perferation.
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
« Reply #7 on: August 22, 2008, 10:25:22 PM »
Pretty sure there was a start serial number in the partsbook , when they started putting them on..
anyone know if you can use a 17T with it?
« Reply #8 on: August 23, 2008, 04:59:08 AM »
I've got one of those things on my K6 engine, I presumed that they were an optional Honda item, I haven't checked my K0 to see if it's got one. Cheers, Terry. ;D
Offline 6adan
« Reply #9 on: August 23, 2008, 05:44:37 AM »
I found on my K0 that the original cover would not work when I installed a o ring chain,the suppore post beside the screw hole would catch in the sprocket. I had to remove the guard and replace with a later cover.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
« Reply #10 on: August 23, 2008, 07:58:12 AM »
Terry, there were also aftermarket ones made..
Offline Johnie
« Reply #11 on: August 23, 2008, 09:46:31 AM »
Good point...I did install a 17T front drive sprocket on my KO with the O-ring chain.  I got my sprocket from Yamiya for $35 as I wanted to keep the same design.  The after market sprocket from Honda did not have the thick ridge on it.  And you are correct, that sprocket cover and my O-ring chain hit the support hole shaft, but there is no need to toss that cover.  I just used the Dremel to grind a little of that shaft out and put it back on.  All is well...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #12 on: August 23, 2008, 06:18:08 PM »
Oh, ok Frank, but it does look exactly like the one in my parts manual, so maybe the PO of my K6 "retro-fitted" it? Cheers, Terry. ;D
