Author Topic: Another carb problem... sorry, there seems to be a lot of these  (Read 1786 times)
written_black
« on: September 12, 2005, 01:10:33 PM »
I've got some issues. First off, I did adjust the valves, and set timing. I rebuilt the carb's and the bike has ran fine. It's been sitting for about two weeks since I last rode it. Granted I havent rode it much since I haven't gotten tagged yet. Today I finally got it tagged and took it for it's maiden voyage and it ran like crap. I let it warm up for a few minutes then I took off. It did good for about two blocks then it acted like the petcock was off, so I checked to see that it was on, and it progressively got worse and I barely made it home. I checked to make sure the fuel was flowiing like it shoudl, and it was. Anyway this is what it's doing now: have to choke it to make it run, have to keep the engine above 3000 rpm or it wants to die, it pop out the exhaust when you give it gas. The other night I noticed that it was blowing smoke like it was running too rich. You couldn't see it unless it was out of the light in my garage. I looked at the carb FAQ and it has qualities of running lean and running rich. Thanks for any help.
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
Re: Another carb problem... sorry, there seems to be a lot of these
« Reply #1 on: September 12, 2005, 01:20:15 PM »
Did you synch the carbs after you put them back together?  Do you have a fuel filter installed?  Standard exhaust/ filter ?
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline dusterdude
« Reply #2 on: September 12, 2005, 01:34:10 PM »
ask bob wessner,he`s the local carb guru. :D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: September 12, 2005, 01:57:42 PM »
First off, does it seem reasonable to you that we would remember what bike you have?
Clean carbs that are fed dirty fuel become dirty carbs.  Any bits in the fuel larger than about .016 inch plug up the slow jets.  Plugged slow jets do fit the symptoms you describe.
You also might want to try switching reserve.
Check your spark plug deposits for clues.
Check you points for water contamination.
written_black
« Reply #4 on: September 12, 2005, 03:16:02 PM »
Sorry.. it's a 73 CB500. I synced the carbs, it has new fuel filers, and I cleaned the tank out. I also switched it over to reserve. The plugs were white on the electrodes. I also forgot the other day when I tried to start it it flooded on me, and I had to let it sit. It's got me baffled.
« Reply #5 on: September 12, 2005, 09:16:59 PM »
If the plugs are white it is running too lean and you have a fuel starvation issue.  I'd guess at this point it is plugged jets.  Probably the slows at least.
See:
http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
Please describe why you think it was "flooded".
written_black
« Reply #6 on: September 12, 2005, 09:32:37 PM »
The plugs were drenched when I pulled them, and it smoked for a bit after I finally started it. Yeah I am going to pull the carbs tomorrow and look at them. That makes sense that the slow jets may be clogged since it wont run under 3,000 rpm. I"ll keep everyone updated on the problem. On a good note I got the brakes fixed. They were squeeling horribly. The piston had crud and rust on it. I cleaned it up with 1500 grit sand paper, and beveled the pads. They work like a charm now. Probably as soon as I get it running great again, something else will mess up on me. Thats been the trend so far. Oh well, I like working on it, thats part of the charm.
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« Reply #7 on: September 13, 2005, 12:22:24 AM »
Yesterday I rode mine without a problem* for the first time. It feels good once it's all working but sometimes it's frustrating getting there.
*I still need a blinker relay :)
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
written_black
« Reply #8 on: September 14, 2005, 01:48:10 PM »
Carb problem fixed!! I had a set of part carbs that i took the floats out of and put in mine, I was hoping they would all be set the same, and they seem to be doing great. Drove it around for about an hr today. I need to resync the carb's but I am going to wait for a rainy day. Guess what though... The brake squeel is back. I'm thinking I am going to have to rebuild the caliper or something. The more I used the brakes the worse the squeel got. Of course the noise ended as soon as I layed on the brakes. What a pain. Hopefully I'll have the new pics of it up soon.
