Author Topic: can i put another tank on  (Read 1475 times)
Offline andy8190
« on: October 11, 2008, 10:47:26 PM »
will a 1976 cb500 tank fit on a 1974 cb550 fram without any mods? i know the petcocks are different but is that the only thing?
Offline Geeto67
  • A grumpy
Re: can i put another tank on
« Reply #1 on: October 12, 2008, 05:42:42 AM »
cb500 twin? the last cb500 four was 1973 and the tank is pretty much the same as your 74 550.
Anything will fit so long as you have welding/fabrication skills but no the tanks will not be a direct bolt on. Even if the front cups line up the rear mount will not.
Maintenance Matters Most
Offline andy8190
« Reply #2 on: October 12, 2008, 08:17:08 AM »
ok thanks
Offline karmasic
  • pull-a-part boy
« Reply #3 on: October 13, 2008, 09:51:52 PM »
i did a detailed post on the cb500t tank on a cb550. easy enough, but takes some mods. cb550s have wider tank mounts the most cbs. if you cut a 1/4" off each side of the mount, you can run all kinds of tanks: cb500t, cb750, cb450, etc...
Offline mrbreeze
  • Not your average
« Reply #4 on: October 13, 2008, 10:09:17 PM »
Can I put another tank on???......I'm guessin' the answer is.....Yep!!!!
MEMBER # 257
