OK so its been almost a year since i bought the Dyna ignition kit, but I finally managed space and time in putting it all together now, but i ran into a problem w/ the park plug wire caps.
the original caps are straight for the outside cylinders and 45 degree caps for the inners. now i have 8 90 degree ones, which should still work on the inners, but not on the outers. but looking @ the caps unless i use the ones which screw onto the wire, how do i make the connector which is on the end of the wire go into the straight cap and still be able to push the top of the plug into it? I ask this b/c the 90's work fine, you push the wire straight in and the connector end is sitting in the cap ready for a plug to be pushed up in, but w/ the straight connectors, when you push the wire in, the metal connector on the wire is sitting vertically, and not in a position for a plug to be pushed into it...
