Author Topic: accel plug wires  (Read 1222 times)
wornknobby3
accel plug wires
« on: November 02, 2008, 01:34:02 PM »
OK so its been almost a year since i bought the Dyna ignition kit, but I finally managed space and time in putting it all together now, but i ran into a problem w/ the park plug wire caps.
the original caps are straight for the outside cylinders and  45 degree caps for the inners. now i have 8 90 degree ones, which should still work on the inners, but not on the outers.  but looking @ the caps unless i use the ones which screw onto the wire, how do i make the connector which is on the end of the wire go into the straight cap and still be able to push the top of the plug into it? I ask this b/c the 90's work fine, you push the wire straight in and the connector end is sitting in the cap ready for a plug to be pushed up in, but w/ the straight connectors, when you push the wire in, the metal connector on the wire is sitting vertically, and not in a position for a plug to be pushed into it... ???
wornknobby3
Re: accel plug wires
« Reply #1 on: November 05, 2008, 02:28:12 PM »
heres a visual to better explain what i'm trying to deal with...
Offline dusterdude
« Reply #2 on: November 07, 2008, 01:18:49 PM »
i dont quite understand what your asking,however that boot in your picture is designed to be bent,its an universal boot.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline squirley
« Reply #3 on: November 07, 2008, 02:35:10 PM »
Looks like to me taht the 90° fitting is for the coils and not the spark plug.  My accel wires came with 90° for the coils and 4 180° for the plugs.  Just a thought
