Author Topic: Correct Dyna Coil for CB350F w/ stock points  (Read 3084 times)
Offline CrashBar
« on: November 14, 2008, 10:41:56 AM »
I have a 1973 CB350F running the original coils and points ignition.  If I want to replace the coils with Dynas shown on the Z1 website, what should I get?  From the Z1 site I am infering that the 1.5 ohm coils are appropriate.
OR -  if I am going to upgrade to their electronic ignition at some point, can I run the 2.2 or 3.0 now with my points?
The site says "Never select a coil with a lower resistance than your ignition system - this will cause the coils to overheat and burn out... It is OK to select coils with a slightly higher resistance."  I need a little more guidance...
CB
....to trade in these wings on some wheels...
2017.5 BMW R1200GS
1973 CB350F
1978 CB550K
1973 TR5T
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Correct Dyna Coil for CB350F w/ stock points
« Reply #1 on: November 14, 2008, 10:52:31 AM »
I do believe stock is 5 ohm.
3 ohm will really tax the little 350's charging system.
1.5 would be terrible.
Stick with stock on the 350f, because the charging system is already weak. Going lower ohms just taxes it more.
No.
Offline CrashBar
« Reply #2 on: November 14, 2008, 01:09:27 PM »
Glad I asked  :)   Thanks.
CB
2017.5 BMW R1200GS
1973 CB350F
1978 CB550K
1973 TR5T
Offline kghost
« Reply #3 on: November 15, 2008, 12:24:39 AM »
could just get a hondaman ignition........
Better timing...better spark...
Stranger in a strange land
Offline ct_racer
« Reply #4 on: November 16, 2008, 08:02:16 AM »
If I were you I would try to get the Dyna S ignition.  Electronic Ignition is way better than those points and requires almost no maintenance.
Offline kghost
« Reply #5 on: November 16, 2008, 11:48:38 PM »
Hondaman's transitorized ignitions have some pluses over the Dyna S.
