Author Topic: Will an F1 750 rear master fit an F3?  (Read 855 times)
Offline Patrick
« on: December 02, 2008, 09:38:53 AM »
The reservoir on the earlier rear master is part of the master, rather than remote. Would there is clearance issues? Are the mounting bolt patterns the same? Anybody ever try this? If it works, does anyone know why the design of the master was changed?
Thanks,
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Re: Will an F1 750 rear master fit an F3?
« Reply #1 on: December 02, 2008, 10:34:28 PM »
The rear master changed during the '75 run. It had a nylon type reservoir for the first 10,000+ units then went to a sold aluminum unit for the last 1/3 of '75 and all of '76. I would assume the 77/78 master was less expensive to manufacture and you coud replace components rather than complete units.  I have my doubts about interchangability between 75/76 & 77/78.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #2 on: December 03, 2008, 04:45:54 AM »
I think you're right Jerry, The 75/76 F's also had a different rear caliper.
I know for sure that the master cyl. on the 77/78 F's are the same, as well as the caliper. But don't know if the earlier built in resivoir type will fit.
 Matt.
Gallery at:
Offline Patrick
« Reply #3 on: December 03, 2008, 08:27:12 AM »
I had a feeling that might be too easy, since I found one locally in working condition....
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
