Author Topic: Stuck Cylinder head stud  (Read 2583 times)
Offline Skunkmiester
« on: January 16, 2009, 03:44:18 PM »
Guys, all but one Cylinder head syuds are out, just one left, have tried gallons of WD40, gentle heat with blow torch, tap with hammer etc.
Any other ideas?
Please?
Cheers
1973 CB 750 Cafe Racer
1992 (original) Fireblade
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: Stuck Cylinder head stud
« Reply #1 on: January 16, 2009, 03:51:05 PM »
What are you using for a stud remover?
I had a similar problem with a 550 that heat wouldn't remove. Then I heated it with a cam style remover and it popped right out.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline toycollector10
« Reply #2 on: January 16, 2009, 05:42:04 PM »
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
« Reply #3 on: January 16, 2009, 06:39:54 PM »
Just bend it at right-angles and wind it out mate, I presume that you don't intend to re-use it? Cheers, Terry. ;D
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: January 16, 2009, 06:48:07 PM »
+1 to PB Blaster.  WD-40 is not a penetrating oil or lubricant, it is an anti-moisture protectant.
That said, I'd try Terry's suggestion.
mystic_1
- John Augustus Shedd
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #5 on: January 16, 2009, 11:26:59 PM »
« Reply #6 on: January 17, 2009, 02:12:07 AM »
Well I was going to, will it be stretched or ruined? Should you not re use studs?
« Reply #7 on: January 17, 2009, 06:06:21 AM »
It will be ruined. You are going to be replacing them with heavy duty pieces anyway...right?
Offline nokrome
« Reply #8 on: January 17, 2009, 01:06:06 PM »
i had  the same problem, i got all of them out by bending them over and spinning them out except for the fwd one on the left side where all the water collects when its on the kick stand (severely corroded), that one broke off :'( picking it up from the machine shop on monday
        anyways those stud removers look like the ticket.
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
    • My Album
« Reply #9 on: January 17, 2009, 01:16:23 PM »
surprisingly they do work
« Reply #10 on: January 17, 2009, 03:31:30 PM »
Correct mate, they will be stretched and ruined, but like Mike said, you'd be well advised to use H/D studs, even if you're keeping the engine stock.
Be very careful with stud removers, if they gouge your OEM studs, there's a likelehood that they'll snap when you retension them. Cheers, Terry. ;D
« Reply #11 on: January 17, 2009, 03:54:31 PM »
Cheers Terry, last stud is out. Bent beyond use.
Now then, HD studs, any suppliers for the UK?
Now I have the kick start retaining pin to worry about, wil tackle that tomorrow.
Oh the joy of restoring.
« Reply #12 on: January 17, 2009, 03:59:23 PM »
G'Day Skunky, well either Big Jay at APE or Jeff at Z1 Enterprises will sell you some H/D studs, (Big Jay manufactures them, and they're both members here) and if you squeeze and twist that roll pin with a set of vise grips you'll get it out no worries. Cheers, Terry. ;D
