Author Topic: advance timing unit ?  (Read 2393 times)
Offline scunny
  • don't call me expert
« on: January 16, 2009, 03:41:41 PM »
probably a silly question but give an ageing man a break.
on the advance timing unit, should the cam be sprung loaded so it returns to normal advance as the motor slows down.
thoughts !!!
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: advance timing unit ?
« Reply #1 on: January 16, 2009, 03:50:09 PM »
Which bike? Or all of them?
I thought there were spring loaded arms that did that... push back I mean.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline scunny
« Reply #2 on: January 16, 2009, 04:05:14 PM »
it's a 650 but all the advance units I've seen look the same.
it has the weights and springs that throw out as the revs rise allowing the centre cam to advance but what brings the cam back to normal idling advance ?
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Bodi
« Reply #3 on: January 16, 2009, 04:33:27 PM »
The springs hold the arms in. At higher RPMs the (imaginary) centrifugal force acting on the weighted arms moves them out against the springs. The little ears on the inner ends of the armes engage slots in the points cam and cause it to rotate "forward", making the spark happen sooner in the crank rotation - advanced. When revs go down again the springs pull the arms back in.
Offline HavocTurbo
  • Can you tell?
« Reply #4 on: January 16, 2009, 07:49:57 PM »
That would be the technical explaination of what I was trying to say. ;D ;D
09 XL883L - No Name
Offline Hush
« Reply #5 on: January 17, 2009, 03:45:30 AM »
Thats how mine works Scunny! ;D
Offline scunny
« Reply #6 on: January 21, 2009, 03:00:56 PM »
OK guys the plot thickens.
the advance unit I have on the 79 motor is off a 82 model and dosn't "index" properly on full advance nor at idle
have managaged to pull apart my other " very rusty spare" advance which is off a 79 and the index is positive woohoo, now to find the weerubber bit that fell off it when I was cleaning it  ;D
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #7 on: January 21, 2009, 03:51:20 PM »
Is weerubber bit one of them there teknikkle termz?  ;D
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline scunny
« Reply #8 on: January 21, 2009, 03:53:50 PM »
yep, thats a weerubber bit alright, and I've robbed it off one set and super glued it to the hopefully good one
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
« Reply #9 on: January 21, 2009, 03:58:53 PM »
I think you'd be better off sticking to fishing and boozing, mechanicing is not your forte ;D ;D ;D ;D ;D
Sam. ;)
Offline scunny
« Reply #10 on: January 21, 2009, 04:54:14 PM »
ya cheeky old coot  ;D
after carefull inspection of the misbehaving advance it appears the PO had filed the index marks off the inside lever thingys.
this came from the 650 motor he had installed in a go cart, I wonder what he did that for ?
don't worry Sam, tis beer o'clock shortly
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Soos
« Reply #11 on: January 22, 2009, 02:47:31 AM »
nope... the '79cb650 has a different advancer...or at least the part # stamped on it is different.
Not too sure if it advances the timing to a different degree than the '80-'82 cb650 advancers do.
My '79 advancers have #426  stamped on them, the '80, '81, and '82 advancers I have seen all have the same part #460 stamped on them.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline scunny
« Reply #12 on: January 22, 2009, 11:11:34 AM »
correct soos, 426 and 460. the backing plates are the same but I cant compare the advance due to PO butchery. my cobbling together the good from both seems to work ok, bike starts well and can now rev past 3000 without setting my carbs on fire  but I will delve into the finer points of timing later.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
