Author Topic: how many guys interested in buying Viton X-rings for 500,550,650 cylinder head?  (Read 3950 times)
Offline motorhead55
I have been searching for some "X-rings" to substitute for the standard orings that always leak between the cylinder and head. They are round like an oring but the cross section is better. GOOGLE "X-rings" and see what I am talking about. kayaker43 mentioned this and I looked them up. I got a quote for $100.00 for 100 pieces. The material is VITON. That is their minimum. I would be interested in splitting the costs with 4-10 guys. NO mark-up! Just pay your EQUAL precentage and postage. Maybe I am crazy but I don't want to pull tha head off again just because it is leaking oil.
1976 Honda 550F bought new in 1978
2006 Yamaha TW200 TrailWay
1967 Triumph 200cc Tiger Cub
2007 Dodge 5.9 Cummins Diesel, 6spd. Stick, 4X4
1955 European Spec VW Bug, 1700cc engine, Porsche 356 "A" brakes
1939 Willys Pickup
2003 Kubota B7400
Offline aussie
I would be interested ,if you were ok with shipping them to Australia.
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Me too.
+ shipping to UK.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
How about the Base ones as well, they are 11 x 2.5 ( head should be 5 x 2.4)  If you can get both I would have 10 of each
Offline jreich
Those look great...I'll throw in for the total amount once we see how many guys/gals are interested
cheers
JD
Offline hymodyne
count me in for two full engine sets
hym
Offline Soos
A buck a o-ring?
But to try something new... priceless.
Fixing the frigging persistent oil weep... again priceless.
Count me in.
PM sent.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline psykod
You can add me to the list for 4 as well.
1977 CB550F.  Mostly Stock.
Offline fastbroshi
  • Puppet
Put me down for 4 as well.
Just call me Timmaaaaay!!!
Offline motorhead55
OK....I have been researching this and another member suggested finding the lower orings also. These are the ones that are between the case and cylinder and seal the oil restrictors. I found them in McMaster-Carr online catalogue. www.Mcmastercarr.com  I am still researching the cyl to cyl head ones. The BOTTOM X-rings or Quad rings as they are also known, the ones between the case and cylinder are a Mcmaster-Carr part number "6540K135" They are a direct size replacement. $12.50 for a pack of 25. These are Viton material. I will probably buy a pack of these for me.
I am going to contact a place on the east coast tomorrow(I am WEST coast). They specialize in METRIC orings, seals, ect. I will give him the dimensions of the upper o-ring. I will report back when I get an answer. Chris
« Last Edit: February 25, 2009, 04:52:57 PM by motorhead55 »
1939 Willys Pickup
2003 Kubota B7400
Offline jreich
Thanks for doing the footwork on this Chris!
JD
Quartza
you can put me down for a set.   Thanks,
Offline CBJoe
You can put me down for two sets as well.
Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline kayaker43
I did suggest X-rings as a possible improvement but can't say from experience whether they really work better. Think of it as an experiment and not a proven fact. I did try harder durometer o-rings but they leaked too.
Why is it some engines never have a problem while others can never be sealed? I would like to find the differences,.. is it depth of counterbore, surface finish, different head gasket crush, warped head????
The X-rings seem like a good try but their benefits might be more for aplications that need to seal while rotating or sliding?
« Last Edit: February 25, 2009, 05:54:29 PM by kayaker43 »
Offline motorhead55
kayaker43. Well...You know if they DON'T work...ALL of us are coming to your house and moon you on your front lawn!!! :o  :D
No really, I appreciate the idea. I didn't know that they even existed. They look like a much better way to go. I personally am going to take a chance and try them. Most all of us know how the O-rings work...NOT VERY WELL!
Buying my bike new, I had them retorque the head when they started to seep within the warranty period. It lasted for several years but I put it away 3 years ago when it really started to leak. And mind you, I ONLY have 9800 miles on my bike.
ONE thing I did have done was I had my head VERY fine cut surfaced. It came back looking like a mirror.
The SAE equivalent o-ring or x-ring cross section IS .0046" thicker. 2.5mm= .0984". 3/32= .103"
« Last Edit: February 25, 2009, 07:48:39 PM by motorhead55 »
1939 Willys Pickup
2003 Kubota B7400
Offline motorhead55
I received a set of Quad/X-rings yesterday. I ordered one set larger (#107)than the 106's that are a bit smaller dimension than the stock orings. I am going to go with the larger and take the cylinder to a machinist friend that has a mill. We are going to open the recess in the top of the cylinder about 10 thousandths in diameter, a 13/32 mill cutter is perfect. Here are some pics of the Quad rings and the supplier. I paid about $25.00 delivered. It would be $6.00 less if I didn't order the smaller quad rings. The smaller fit but the OD is about .007" smaller and the ID id as well. I also bought the bottom ones from them as well because they are a #70 DURO hardness instead of #75 (harder) like the ones I bought from Mcmaster-carr.
I think this should solve the leakage problem...I am willing to try it
The second pic is the smaller quad ring. The third is the larger installed but the cylinder hasn't been opened up yet. It fit too tight. The 4th and 5th is the 11mm one for the cylinder base. It fit PERFECT!  Use the part numbers in the pics if you want to order them.
Here is their website www.smallparts.com
« Last Edit: March 13, 2009, 11:37:48 AM by motorhead55 »
1939 Willys Pickup
2003 Kubota B7400
Offline motorhead55
Check the previous post
1939 Willys Pickup
2003 Kubota B7400
Offline 77honda
**Note**
We use viton o rings on some equipment at work and had a safety warning that if the material is subject to high temp around 300 deg c it degrades and produces hydrogen fluoride and if mixed with water produces hydrofluoric acid which is very nasty. We have removed all viton from rotating equipment and only use it in static situations
I doubt if an engine will reach these temps, but if you were using a heating torch to remove parts you should take precautions
Mike
CB750 K7
Decapitated Toy
thanks for the heads up and good idea on the x rings... did you have any leakage or did they work fine?
Offline motorhead55
I haven't started my engine yet. I need to go through my carbs still. I have been so busy with car work and working on my Dodge pickup that It is sidelined right now.
1939 Willys Pickup
2003 Kubota B7400
Offline kayaker43
I haven't been checking in often but would like a couple sets if that deal is still going?
If I build a race motor, I'll go with external lines but I hate weepy street motors.
Doug
Offline motorhead55
I found a place that I was able to buy 5 of one size and the larger ring I was able to buy separately. I will post my results when I get the bike running.
1939 Willys Pickup
2003 Kubota B7400
Offline manjisann
Please do!!
Brandon
1980 CB650 Custom
Offline motorhead55
IT'S ALIVE!!! I finally got the top-end done, carbs overhauled, ceramic coated the exhaust flanges. So far no leaks from the QUAD RINGS. The Bike runs SWEET! I am very confident that they are going to be a good deal to stop the leaks on the cylinder/cylinder head oil feed.
I also found that before I rebuilt the carbs that they would piddle while the bike was running. I was going to replace the needles and seats but they were about $30.00 EACH. On inspection of them, I discovered that the Orings shrink enough when they are old to let the fuel weep past the orings that seal the seat into the carb. I reused the same, origional, 33 year old needle and seats but put new HONDA oring kits in each carb. NO MORE PIDDLING! I will post some pictures of the bike when I get it cleaned up.
« Last Edit: August 02, 2009, 10:27:57 PM by motorhead55 »
1939 Willys Pickup
2003 Kubota B7400
Offline HB-1fan
I had a friend tell me he used "Coppercoat" to coat the o-ring and its seating area and never had a problem after that. It was a cb550 race engine and I have since done this to an 836 engine and still no leaks!!
 It comes in a small metal can with a brush in the cap. Permatex brand if I remember, right.
  NOT silicone with copper added!!!!!!!!
HB
"If you always expect the worst, you can never be dissappointed, only surprised"
