Author Topic: quick s90 turn signal  (Read 882 times)
Offline jamesv220820
« on: February 28, 2009, 08:59:04 PM »
ok my brother is finishing up fixin our s90 and wants to put turn signals on it now someone we quickly talked to said the turn signals are the same as my cb350f
this might sound like a stupid question but the s90 is a 6v system while the cb is 12v will the cb lights work in the s90 ? or would something in the fixture have to be replace example just the bulb ?
thanks
james
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
Re: quick s90 turn signal
« Reply #1 on: March 01, 2009, 06:00:35 AM »
I use 12 volt bulbs on 6 volt systems quit often. They work fine. After all voltage is a maximum rating, but you couldn't use 6 volt bulbs on a 12 volt system. They would probably burn out real quick.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
« Reply #2 on: March 01, 2009, 06:37:35 AM »
You will need to fit 6 volt bulbs and flasher can with the bulbs being the correct load for the can--don forget the "idiot" light needs to be there as well to get the load right
