Author Topic: need some help with coils  (Read 6836 times)
slambert49
« on: March 04, 2009, 05:18:52 PM »
hey the wires on my stock coils are really crusty and my bike will run on all cylinders some time but its like the wires come lose inside the boots and will fire sometimes and sometimes it will cut out. the coils are a bad design because you cant just replace the plug wires. I wanted to know if i can replace the coils with 3 ohm coils so eventually I can get the dyna ignition to go with the 3 ohm coils. Is it possible to use 3 ohm coils with the stock points system? Do I need to put resistors on them until I get the ignition? Is there any way to clean the inside of the spark plug wires? Or should I just get replacement coils?
some many questions????? :-\ please help me out
Offline OldSchool_IsCool
  • Really feeling like an
Re: need some help with coils
« Reply #1 on: March 04, 2009, 05:44:50 PM »
Depends on the bike's charging system.  Which model/year do ya have?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
slambert49
« Reply #2 on: March 04, 2009, 06:00:22 PM »
its a 73cb750 the frame says its a k2 but the engine says is a k3
72COOL
« Reply #3 on: April 07, 2009, 04:22:44 PM »
My coils are fine on my '72, but I need new wires.  Can't believe it is so difficult.
Can't find a tutorial or a clear answer to replacement.
Would like to buy some car wires and plug caps just to be cheap and useful.
Any updates?
(In FAQ there is a description of drilling out the connection to the coils, but I can't really tell what he is describing)
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #4 on: April 07, 2009, 04:30:34 PM »
Is there a decent M/C salvage yard near you?
I found some later year Honda coils, that did have
replaceable wires,  cheap at my favorite local
place, Union Salvage. They were the right resistance too!
Bikes parked out front mean good chicken-fried steak inside.
ev0lution7
« Reply #5 on: April 07, 2009, 05:43:21 PM »
here is my coil setup i used
GL1000 coils.. (with the resister removed)
and i got accell 8mm spiral core wires
and used this link to help me make my own coil wires... for the coils..
http://forums.sohc4.net/index.php?topic=17310.0
it was a big help my spark plugs have BLUE ARCHS not orange sparks...
also i replaced my spark plug CAPS! try parts-n-more.com for spark plugs caps at a good deal!
« Last Edit: April 07, 2009, 06:14:48 PM by ev0lution7 »
72COOL
Thank You
« Reply #6 on: April 07, 2009, 06:26:51 PM »
Link was what I was looking for.  Not sure I want to do operation on my coil, but it does make it clear what can be done.
I'm gonna look for salvage and try it on an extra set that I could use or just leave to the side.
my ride is a cb500, 1972.  The GL1000 are a straight swap?  I had a 77 Wing that sold last year!  Coulda scarfed some parts before I let it go.
Thanks for the responses, fellas.
ev0lution7
« Reply #7 on: April 07, 2009, 07:04:28 PM »
yes GL1000 are dirrect replacement coils no modification nessissary just remove the balist resistor and your home free it was an old 70's racer trick the coils "look" like CB750 coils but are "hotter" than stock!
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #8 on: April 07, 2009, 07:30:49 PM »
I just upgraded  (I hope it's an upgrade) to 1996 Honda CBR 600 F3 coils for $25 + wires..
Easily replaceable wires, somewhat hotter than stock (I've seen 3 ish ohms stated).
spwg
ev0lution7
« Reply #9 on: April 07, 2009, 08:08:36 PM »
ya thats what its about.. although i was looking for a stock looking coil so no one would would second guess my coils as a proformance part ;)
« Reply #10 on: April 08, 2009, 06:47:43 AM »
The gL100 without resistor will fit but they aint gona last as long as without resistor they are 9 volt coils not 12 volt
ev0lution7
« Reply #11 on: April 08, 2009, 07:31:23 AM »
thats funny mine say 12v right on them???? do you have a pair that you got your info from?
Offline 1timduke
  • '75 CB550
« Reply #12 on: April 23, 2009, 05:10:39 PM »
   I'm gonna try and pick up another set of coils from a salvage yard tomorrow.   I'm assuming the GL1000 coils are good for a '75 550?   What things should I be looking out for as far as just looking a the coils?   Will any year GL1000 work?   I want to tear into mine as they are not the strongest, I don't want to end up with a non running bike.   Also, how much would be a fair price for the coils, I've never bought from a bike salvage yard.
Thanks,
-Tim
The only thing I miss about the South is Waffle House!
« Reply #13 on: April 23, 2009, 06:09:36 PM »
You need to check the primary resistance of whatever coil you select.  Stock was about 5 ohm.  Lower ohm coils draw extra power from the bike's system (and even more with a dyna-s).  Since the stock alternator can't keep up with stock loads at idle, increased coil draw will deplete the poor 550's battery even faster and delay the recharge cycle.
I don't have GL1000 coils to measure.  I thought these were actually 6V coils (2.4 ohm primaries)?  They only have 12v applied to them while the electric starter is engaged in it's native application, and an inline resistor to reduce the voltage/current draw while the bike is actually running.
Offline 1timduke
  • '75 CB550
« Reply #14 on: April 23, 2009, 10:47:47 PM »
How exactly do you measure the resistance, TT?   I have a multimeter and I can measure the ohms, but where do I apply the leads?   I'm currently running what I believe are '72 500 coils on a '75 550, are these the same?   Should I look for a set of CB coils instead?   I was thinking the GL1000 coil would be nice b/c it has the removable wires.   Sorry for all the ?s just looking for some guidance.
Thanks,
-Tim
ev0lution7
« Reply #15 on: April 23, 2009, 11:24:24 PM »
measure resistance on the primarry side... yellow to black/w
blue to black/w
and then secondary side with out the spark plug caps... both wires....
and GL1000 coils are ABOUT 3Ohm they are actually 12v coils with a resistor just remove the resistor and you get 3 ohm High output coils :)
« Reply #16 on: April 24, 2009, 12:43:27 AM »
As explained, you measure the primary, B/W to yellow or Blue to find out if it is going to draw more power from the bike's electrical system.  Low ohms = more power draw.
While lower ohm coil primaries have the potential to make higher spark voltage.  It doesn't mean that it actually does provide more voltage at the spark gap.  The size of the gap determines the firing voltage.  The coils only have to generate the required gap voltage, not it's full potential.  On a stock motor, 3 ohm coils provide no run time benefit unless you increase the spark gap of the plugs (which requires more spark voltage to create the arc).
The main benefit of 3 ohm coils on a stock motor, is during electric start when large current draws from the battery bring the system voltage down.  Then the excess capacity of the coil's winding ratio can develop more potential spark voltage.  Some even use 3 ohm coils when the electrical routing of the bike loses excessive voltage going to the coils.  A 3 ohm (or less) coil being fed 10 V, instead of full battery voltage, can create more spark potential than a 5 ohm primary type.
sabres7th
« Reply #17 on: October 20, 2009, 09:00:33 AM »
The gL1000 without resistor will fit but they aint gona last as long as without resistor they are 9 volt coils not 12 volt
1978 cb550k, with dyna s 1-2 ign
ok, i want to get my spark voltage up higher stock to make a bigger spark. i realize the stock charging system is weak. is it possible to use the dyna 3ohm coils or stay with 5ohm? right now i have the stock coils on the bike. is there a output difference between the 5ohm dyna and the stock coils? could i use the gl1000 coils and not worry about the battery draw with the resistor left on them?
alot of questions i know what i am really asking is where do i get more bang for the buck or just leave well enough alone. thank you agian for taking your time to help out!
« Last Edit: October 20, 2009, 09:07:55 AM by sabres7th »
« Reply #18 on: October 20, 2009, 12:15:06 PM »
For what reason?
Sure.  Re-set your idle to 3000 or 3500 RPM and run with no lights on.
yes.  I understand it is more a spark duration issue, rather than a peak voltage issue.
I'm not certain of the gl1000 coil resistance, or the resistor value that they use.  Report that and I can do a calculation.
...But, you won't get something for nothing.  The coils work on a voltage ratio multiplication.  Low ohm coils have a higher voltage multiplication, but draw higher current/power.  A resistor lowers the current draw by reducing the voltage the coils receive, and there is less to multiply.
Your dyna S already draws more power from the stock coils than the points system.  Increasing the current draw for the coils will just multiply that condition.
Offline Spanner 1
« Reply #19 on: October 21, 2009, 07:45:11 AM »
I love my stock ignition....!
Stock points
Stock points gap
Stock timing
Stock advance mech.
Stock coils............................. haven't touched it for 2K miles !
« Reply #20 on: October 21, 2009, 03:31:01 PM »
+1 Spanner, tho I'll add that I love my HondaMan Ignition Module too!
Sure.
Is it hard?
sabres7th
« Reply #21 on: October 21, 2009, 08:50:50 PM »
i'll take it as leave well enough alone. dyna products or high powered ign parts are crap with no advantage over stock.
« Reply #22 on: October 21, 2009, 10:03:08 PM »
Yes, who could have thought that the parts that came with the Honda could work so well?
It is nice to see well reasoned and level headed comments in the forum, isn't it?  ::)
I wonder why you never defined the advantage you were seeking?
sabres7th
« Reply #23 on: October 22, 2009, 08:30:31 PM »
no really no sarcasm. just wanted to know if their is hidden horse power that can be milked out of the ign system. can not afford to bore out the bike. or buy a 750.
« Reply #24 on: October 22, 2009, 11:05:06 PM »
Hotter spark does not make more power.  However, doing other things to the engine may require hotter spark to enable that power increase.
For example, higher cylinder pressure requires higher voltage to create the arc across the electrodes.
So, high performance engines often require a spark improvement.  But, spark improvement is not going to make an ordinary engine produce more power just from the added spark energy.
Here's a crude calculation:
1 horsepower hour = 745.699 861 11 watt hour
Let's say we make our engine output 50hp.  This converts to  37250 watt hours.
The ignition system, regardless of the output voltage, is current limited to a percentage of what the primary of the coil draws from the electrical system.
Two 5 ohm coils draw 67 watts, (in one hour it uses 67 watt hours).
Two 3 ohm coils draw 112 watts, (in one hour it uses 112 watt hours).
Even if we assume that the coil energy conversion is 100%, and that 100% of the coil energy is transferred into the engines output (it is certainly not in either case)
67 watt hours = 0.089 848 481 265 horsepower hour
112 watt hours = 0.150 194 476 14 horsepower hour
These are small numbers to start with, and the differences between them are even smaller.  I don't think even the most calibrated butt dyno will feel an added boost from high output ignition systems as the sole variable.
I admit that there are other (valid) reasons to improve an ignition system besides a desired HP boost.  But, those goals need identification before a cost/benefit analysis can be reasoned.
IMO, of course.
