Author Topic: What's the best way to thread wires through handle bar?  (Read 1516 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: March 14, 2009, 03:32:25 PM »
I have to replace my right hand switch on my CB750. Do all the wires go through the handle bar and into the headlight bucket? If I pull them out, how to get the new wires back in, with a string or wire or something. And do I have to remove both throttle cables from the carbs before removing the switch? This isn't a trick question, I'd just like to do it right the first time.
jsaab2748
Re: What's the best way to thread wires through handle bar?
« Reply #1 on: March 14, 2009, 03:37:33 PM »
As long as the bars are stock, getting the wires back in shouldn't be a big issue. They push thru easily. Cables come off as far as memory serves me.
« Reply #2 on: March 14, 2009, 03:40:13 PM »
Yes disconnect the cables from the carbs first, and the switch wires all attach in the headlight bucket.
I twist a light steel wire around the switch wiring and wrap it tightly with electrical tape. You can push/pull it through the bar this way. Make sure the hole in the replacement h-bars are at least the size of the one you've got, if not enlarge it.
Good luck.
Offline Old Scrambler
« Reply #3 on: March 14, 2009, 03:47:09 PM »
I use 20-lb. fishing line and some spray-graphite.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Spanner 1
« Reply #4 on: March 14, 2009, 03:49:06 PM »
Bit lost here !, did the wires run thru' the bars on a stock K6 set-up ?? If just changing the switch, no need to do anything with the throttle cables, right K6'ers ?
Offline Magpie
« Reply #5 on: March 14, 2009, 03:49:36 PM »
The wire/string taped to the end or the wires works well but I prefer silicone spray lube. iI seems to go away quicker with less mess.
Cliff.
Offline NickC
« Reply #6 on: March 14, 2009, 05:09:30 PM »
I used some 18ga utility wire. thread each bullet connector on there. Works great!
Offline Alan F.
« Reply #7 on: March 14, 2009, 05:54:34 PM »
In a past life spent manufacturing electronics, we used to tie two lengths of string similar to dental floss arount the wires, cross over and tie again a few times (to spread the load over a greater area) then we'd dust the wires with talcum powder and pull them through.  Some would tie a small weight like a fishing sinker to the end of the string just to speed up the pre-threading process.  Then with a sawing motion, begin to draw the wires into the bar, keeping an eye on the opennings to make sure nothing binds and is damaged.
  Sounds good to me.
