Author Topic: Throttle Cable drag  (Read 1341 times)
Offline Sparked
  • Cheaper then therapy
Throttle Cable drag
« on: March 15, 2009, 05:59:11 PM »
I've installed some new A & B throttle cables on my CB350F.  I think I have the linkage routed right but there is drag in the cable which keeps the throttle from closing when it is released.  Is there a way to lube the cable? Or is there something else I am missing??
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
Offline Sparked
Re: Throttle Cable drag
« Reply #1 on: March 17, 2009, 03:34:52 PM »
Nobody has any ideas??
1972 CB350F
1982 CM450A
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
« Reply #2 on: March 17, 2009, 04:18:23 PM »
Hi, If they are brand new,I myself always lubed them. Are yours brand new? If so make sure they are not being kinked,Try to keep the cables in smooth curves as possible, (2) With the cables unattached to the carbs or unattached to the hand grip,see how smooth the grip turns,It may need lubed on the handle bar. Look where they attach to the handle pipe to make sure they are not unwound a little from when you screw the cable to the lower switch plate housing. I hope maybe this might help you.   Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Offline wireman
« Reply #3 on: March 17, 2009, 04:56:47 PM »
I ran my cables about every different way possible until I found just the right spot that didn't kink up on me.  I also shot some lube in there that did help.
Live life to the fullest!!
75 CB 750    05 Honda 1300 VTX C
Offline Sparked
« Reply #4 on: March 17, 2009, 05:22:38 PM »
Yeah they are brand new.  How do you lube the cables inside the sleeves??
1972 CB350F
1982 CM450A
billybobobrain
« Reply #5 on: March 17, 2009, 05:28:36 PM »
This is the best there is as far as cable lube goes!
Offline Head
    • My Bikes
« Reply #6 on: March 17, 2009, 07:22:59 PM »
One way is to tear off the corner of a baggie ,stick the top end of the cable through it and wrap a rubber band around it,to seal it so the oil doesn't drain out and down the out side of the cable and hang the the bag and put some oil in it,let it siphon though it! On go down to a motorcycle store and buy a cable luber,with a aerosol can of cable lube.
Which is the best way.    Head
billybobobrain
« Reply #7 on: March 17, 2009, 08:04:55 PM »
This stuff is graphite in solvent, the solvent evaporates and leaves dry graphite. Oil attracts dust. I used this on my 500 8 years ago and the cables are still working very smooth with one application. It is damn good stuff.
Offline Sparked
« Reply #8 on: March 31, 2009, 09:11:08 PM »
Finally got a chance to use the lockease on the throttle cables.  fixed the problem lickied-split,  Thanks
1972 CB350F
1982 CM450A
