Author Topic: Inflating a Tire Using WD40  (Read 3785 times)
« on: March 26, 2009, 07:14:12 AM »
I have not tried this so I put it here rather than Tip and Tricks:
[youtube=425,350]<object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
« Last Edit: March 26, 2009, 07:19:04 AM by BobbyR »
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
Re: Inflating a Tire Using WD40
« Reply #1 on: March 26, 2009, 08:18:47 AM »
Starting fluid works well.  I use it to seat the bead but not to inflate the tire.  I leave the stem valve out in case there is an over pressure situation which will ruin your day.  After the bead is seated put the valve back in and inflate as needed.
333:  Think "Shakeweight".
Offline azuredesign
  • Knupping pin
« Reply #2 on: March 26, 2009, 08:58:49 AM »
Yikes, any damage to the rubber? I would guess the amount of air pressure obtained would relate to how much combustible material makes it onto the rim?
Interesting.
Offline unkle fester
« Reply #3 on: March 26, 2009, 09:04:37 AM »
have used ether many times to re-seat the bead on a big truck tire.........old-timers trick............
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #4 on: March 26, 2009, 09:05:28 AM »
used to carry around the little finger pump bottles wwhen we went out on 4wheelers. works pretty well.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline tramp
« Reply #5 on: March 26, 2009, 09:07:41 AM »
i never saw that before
wonder what happens when you use too muck
1974 750k
Offline goon 1492
  • Sucka Repellant
« Reply #6 on: March 26, 2009, 09:37:51 AM »
Nothing happens when yo use too much, remember fire has to have air to breathe just like we do.
Ether is the best to use and is what is used when your out in BFE and that can is all ya got.
Speaking of wd-40, one of the engineers here just shared it with me today so me is paying it forward.
You are here:
GlobalSpec.com > Company Directory > United Bio Lube > Go Green with Soy-Based Renewable Lubricants
 The Engineering Toolbar
The Ultimate Resource for Engineering and Technical Research. (Learn More)
Go Green! BPL™ - Bio Penetrating Lubricant with Bio Corrosion Inhibitors Replaces Hazardous WD40!
Bio Penetrating Lubricants for OEMs, Fleets, Auto Repair, Bicycles, Boating, Motorcycles, Construction, Maintenance, Landscaping, Gardening, Farming, Restoration, Home
Advanced Equipment Protection
Worker & Environmental Safety
Government Regulatory Compliance
Return On Capital Investment
United Bio Lube sells Bio Penetrating Lubricants to Original Equipment Manufacturers (OEM), Wood & Metalworking Facilities, Fleet Maintenance & Auto Repair Shops, Machine Shops, Lock Smiths, Marinas, Ports, and Restoration/Cleaning/Handy-man/Janitorial Services all across America.
An ideal product for LEED Certified Green Buildings, BPL™ - Bio Penetrating Lubricant w/ Bio Corrosion Inhibitors is both a superior and renewable alternative to hazardous WD40, 3in1, TriFlow, Liquid Wrench, PowerLube, LPS#2, PB-Blaster, Mouse Milk, Unilease, GT85, Kroil, CRC 5-56, and all other toxic and flammable petroleum (Mineral Oil, Synthetic, Synthetic Blends) penetrant products!
A Green Chemistry Break-Through!
United Bio Lube offers higher performance, new safety features, and a series of Return On Investment (ROI) incentives for switching over to biobased lubricants made from renewable Green Chemistry.
United Bio Lube's Bio Penetrating Lubricants apply the sound principles of Green Chemistry to achieve new worker safety and environmental standards while protecting capital investments in equipment, tools, and hardware. Green Chemistry naturally provides our nation with a means to sequester harmful CO2 gas from the atmosphere while fostering U.S. Oil Independence.
Bio Penetrating Lubricants combine patented Stabilized™2 Soy High Oleic Base Stocks (HOBS)1 with patented Bio Corrosion Inhibitor (BCI™) chemistry to produce a penetrating lubricant with:
Naturally superior Lubricity
Outstanding Penetrating quality
Very high Load Carrying Capacity
Exceptional Anti-Wear Extreme Pressure performance
Superb Anti-Rust and Anti-Corrosion protection
Superior long lasting Anti-Oxidation properties
U.S. Government Tested & Approved To Replace WD40!
Bio Penetrating Lubricants ultilize patented Biobased Lubricants technology developed in collaboration with U.S. Commodity Groups, National Laboratories, and Federal Agencies including United Soybean Council, National Corn Growers Association, U.S. Dept. of Agriculture, Dept. of Defense, Dept. of Energy, and Dept. of Interior.
United Bio Lube's Bio Penetrating Lubricants have undergone rigorous testing by federal agencies, independent labs, and industry. Bio Penetrating Lubricants have been approved by and are currently recommended for use within the U.S. Coast Guard, National Park Service, U.S. Fish & Wildlife Service, and National Oceanic & Atmospheric Administration's (NOAA).
Bio Penetrating Lubricants are rated worker-friendly by the Occupational Safety & Health Administration (OSHA) and 100% Ultimate Biodegradable3 (ASTM D-5864 PW1) by U.S. Dept. of Agriculture (USDA).
United Bio Lube's BPL™ - Bio Penetrating Lubricant w/ Bio Corrosion Inhibitors is proudly registered in the USDA's BioPreferredSM Catalog of biobased products designated for preferred purchasing by U.S. Federal Agencies.
United Bio Lube's Bio Penetrating Lubricants are reliable, affordable, and available in all quantities today.
To purchase, simply call (650) 213 - 9979.
1 High Oleic Base Stocks (HOBS) are specialized Soy, Corn, Sunflower, and Canola vegetable oils containing high levels of Oleic Acid. HOBS are renewable lubricants engineered to replace petroleum basestocks. Economically sustainable, HOBS is America's solution to petroleum based oils. Moreover, HOBS supports U.S. Farmers, protects workers and their environment, and reduces dependancy on foreign oil.
2 Stabilized™ is Renewable Lubricants, Inc's trademarked, proprietary, and patented Anti-Oxidant, Anti-Wear, and Cold Flow Technology. Stabilized™ chemistry enables HOBS to perform as a high performance formula in high and low temperature applications, reducing oil thickening and deposits.
3 Ultimate Biodegradation (Pw1) within 28 days in ASTM D-5864 Aerobic Aquatic Biodegradation of Lubricants.
Offline goon 1492
  • Sucka Repellant
« Reply #7 on: March 26, 2009, 09:40:20 AM »
Ok I screwed that link up use this one...
http://www.globalspec.com/Supplier/Profile/UnitedBioLube/
Globalspec is an awesome place.
Offline Steve F
« Reply #8 on: March 26, 2009, 07:45:24 PM »
The propellant used in WD-40 is butane, and that's the stuff that fires off so easily.  I once saw a program on Discovery channel about some Toyota SUV's that Toyota built specially for arctic driving through deep snow and over glaciers, and they were using these huge tires inflated only to about 5 psi.  Eventually they had a tire loose it's bead seal, and they used some explosive gas to get the tire back on the rim.  Really cool!
billybobobrain
« Reply #9 on: March 26, 2009, 09:13:03 PM »
I would like to see it done on a motorcycle tire.
Any volunteers? Must provide video to the whole class.
Markcb750
« Reply #10 on: March 27, 2009, 04:02:05 AM »
An acquaintance in the shop next to mine in Middletown NY (about 1970)was killed by seating a truck tire this way, something about not having the split rim prepped properly for the tire bead to seat against. He was using starting fluid (ether).
The mechanic who taught me suggested I use rope and a big wrench to "tourniquet" the center of the tire.  Worked for me!
Soon after this the shop put (OSHA?) all split rim assembly's into a cage for initial inflation. Suspect the rule already existed, just the tire shop did not follow it until my young friend was killed.
Offline Frankencake
  • Yesssssss,
« Reply #11 on: March 27, 2009, 06:17:25 AM »
I don't have the video but I've done it.  It's very important to leave the valve stem out unless you are out in the middle of nowhere and you don't have a compressor.  Then it's up to fate.
« Reply #12 on: March 27, 2009, 06:28:06 AM »
You were from Middletown. I remember that incident. I was in Weschester and word spreads quickly. We had a giy come in with a Truck and a cage to do that work.
« Reply #13 on: March 27, 2009, 06:39:29 AM »
split rim truck wheels are dangerous anyways.........anything you have to put into a steel cage just to inflate is bad news......but that was high tech then...................
Offline Steve F
« Reply #14 on: March 27, 2009, 06:43:07 AM »
When I was a kid, I used to watch the local gas station guy do those split rim tires, and he would run 2 or 3 heavy chains through the center of the tire/wheel before inflating.
Offline DarkRider
« Reply #15 on: March 27, 2009, 08:25:52 AM »
When i was working at Kal-Tire we had a T bar that locked unto a plate in the cement floor for wheels like that. We used them for Steer tires on semi tractors as well even with normal rims just to be safe.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
