Author Topic: CB750 Starter Motor cable route  (Read 1501 times)
Offline 77honda
« on: April 04, 2009, 12:42:46 AM »
 Can anyone tell me where the cable from the Starter motor exits the engine case
1. Is it from the notch in the starter housing
2 Or the slot in the engine case
see photo
Thanks Mike
CB750 K7
Offline rhinoracer
Re: CB750 Starter Motor cable route
« Reply #1 on: April 04, 2009, 01:50:31 AM »
I don't have my bike with me right now but I think the oil pressure sender wires go into the starter box thru the top notch with a similar shaped grommet and all the wires incl alt and starter go uot thru the slot near the sprocket.
Baja native.
Offline jaknight
  • ....Round Town Ride......
« Reply #2 on: April 04, 2009, 02:25:10 AM »
Hi 77,
Rhino's got it.  The roundish shaped notch is for the oil pressure sender unit's cable.  The larger slot shape is other wires bundled together near the chain/sprocket cover and the joining side case cover.
~ ~ ~ jaknight ~ ~ ~
« Last Edit: April 04, 2009, 04:10:34 AM by jaknight »
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
robert6920
« Reply #3 on: April 04, 2009, 02:29:43 AM »
That's right, the oil pressure switch wires use the top notch and all the wires go out via the slot   ;)
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #4 on: April 04, 2009, 02:33:27 AM »
It should exit in between the  "or from here" and the vin # There should be a little tunnel and a cut out in the front sprocket cover. The other notch is for the oil pressure switch thing. Did differant year 750's have the vin in differ spots on the case? Mine's vertical.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline 77honda
« Reply #5 on: April 04, 2009, 02:41:09 AM »
Thanks for the help guys, I was not sure as when I got the bike the starter and oil switch wires were already removed.
PS Model is 1977 K7
Thanks, Mike
CB750 K7
Offline Steve F
« Reply #6 on: April 04, 2009, 04:15:22 AM »
Nice lookin' engine you have there! (well, it'd be an engine when it's back together, anyway  ;D)  I like the engine stand too.  Do you have any more pics of that?
Offline 77honda
« Reply #7 on: April 04, 2009, 04:53:55 AM »
Thanks Steve, The engine is almost back together (at least the bottom end) only have to bore out the cylinders and it will be finished.
As for the stand I seen some photos on the web somewhere and copied it, made it from some left over 20mm & 25mm box section and some 25 x 6 flat bar. Only took about 4 hrs to make, I can rotate the engine 360 deg so it makes life easy.
I have some picks in the projects forum
http://forums.sohc4.net/index.php?topic=31333.0
Mike
CB750 K7
Offline Steve F
« Reply #8 on: April 04, 2009, 05:13:45 AM »
I checked out your project thread, and it seems you've come a long way, and it's looking really nice.  You do nice work.  ;)
