They are nice but the idea of sleeves kills me.
I agree. I had a cast block many years ago and with 1000cc liners in it there was but a weasel's whisker of metal left between them. And guess what, it cracked. Oh dear! Hope you don't suffer the same fate.
Cheers
Eric
That's interesting Eric, I've got an RC block at home that's cracked between the sleeves, was yours an RC block as well? The RC block I bought from Michrobi was fine though, and a much better casting all round. I wonder if RC changed the material/casting process due perhaps, to this cracking problem? Cheers, Terry.
Cheers
Eric
G'day Eric
Our block is a solid sand cast unit. There is no air gap between the cylinders therefor oil leaks and cracking isn't a problem.
As far as a Whisker of metal goes, if you look closely we have actually milled a small amount off the sides of our sleeves to mate them up.
Having said that any damage to the sleeves and the whole unit is a through away.
Brian
[/quote]
That's good info Brian, thanks for that mate, I've got a K0 block at home, it's an entirely different casting from the later (K1 on) blocks, I'll have to check it out and see if it's a candidate for a big bore job, what sleeves are you using? Cheers, Terry.
