Excellent Ron, sure appreciate that. I have one motor with chain damage, another with a pinhole leak in the oil feed from the main gallery to the right-most crankshaft bearing, it leaks into the points cover area. Probably have several other parts that could be salvaged if I knew a good weldor, I just hate to throw any of these things sway, ya know?
Do let us know what you find out.
mystic_1
Being that you're a little closer to Indy than GA, this may be of interest. I went to the shop I'm using for welding and mods "Saldana Racing Products" today.
http://www.arsatweb.com/saldanaracingproducts/index.shtmlThey are rebuilding their website and there is nothing in the services link. The catalog gives the best idea of what they are up to. Besides the production pieces in inventory, which they make, they are interested in the one-off repair and alteration/fabrication business. They repair lots of broken sprint car pieces, he said they have some Porsches in right now, stock cars etc.
I gave them 3 sets of crankcases. My current project to have the motormounts linebored to fit the OS SS motor mount bolts they made. The next project to have the motor mount repaired, it was cracked in an accident, and bored to fit as in #1. And the 3rd set is for sale but they had a broken off stud. I've removed broken studs before but its a #$%*. THey said they would weld a rod to the stud and heat the case and back it out.
Dang, I just got a call from Saldana and everything is done! Gotta go in a minute. I could have waited, had some breakfast, and picked it up.
So about fixing broken cases from chain damage. THey said no problem as I figured. But it would be a case by case (no pun) decision. If all the pieces are there, better. If just cracked, best. THey grind the crack in a vee as has been mentioned here, then TIG it up.
But, if the pieces are loose or missing, harder. Their concern is getting the 2 case halves surfaces to match. They have tools to do it, but at some point, it may not be salvagable.
So gotta go. I'll have pictures of the motor mount crack before and after.
