Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
after the top end rebuild... go in after 100-500 miles and retorque... i don't think re-torque means to undue every bolt and re torque to spec... i think it means check your torque against spec and tighten if needed (you supposedly torqued correctly in the first place).
I use a "clicker" The handle will give slightly and a single CLICK can be heard. WARNING! you will get only ONE click. There is nothing in the wrench which will prevent you from over torquing. And the click is pretty easy to miss in the 5-7 ft-lb range.
