Author Topic: the infamous cb550 with the 32 miles.....no-one believes!!!  (Read 1977 times)
gary delaney
« on: October 30, 2005, 10:18:00 AM »
To the believers....
Help again please.
I have removed the front brake caliper from my restoration project 1978cb550 four k3 - the "piston side" pad is ceased tight. Any tips on freeing, or replacing the full caliper with a new one if required....where to get????
If I free the one I have, should I repaint, or is powdercoating an option. The external surface is damaged.
Thanks again,
Gary
Kelvin8
Re: the infamous cb550 with the 32 miles.....no-one believes!!!
« Reply #1 on: October 30, 2005, 10:42:55 AM »
I used compressed air through the brake line to blow mine out. make sure it's pointed at something that will catch it.
Offline chrometank
  • cb750 1976 owned 33 yrs
« Reply #2 on: October 30, 2005, 04:19:39 PM »
Hey gary,If the air dosent work you could try a grease gun over the bleed nipple.If you do a search here you will find plenty of threads on this subject.
cheers
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #3 on: October 30, 2005, 07:41:19 PM »
I could not get mine out with compressed air. I rebuilt master cylinder and put in new fluid and started pumping. It came out.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline MikeDeB
« Reply #4 on: October 31, 2005, 01:39:43 AM »
Help again please.
Thanks again,
Gary
As Bodain suggests, pump the piston out with the hydraulic system.  As for the caliper, you can have it ceramic coated.  The coating wiill last longer than paint and resists brake fluid.  Andy in NZ had one done and it looks great.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline Jay B
« Reply #5 on: October 31, 2005, 04:03:38 AM »
The caliper piston on my 350F project was seized tight also. Compressed air wouldn't budge it. I laid it on my bench piston up and tapped on it using a big socket the same size as the piston for a drift. Got it to move just a little (inwards) then used compressed air to push it back out a little. I repeated many times till the piston popped out.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline L.A. Nomad........
  • 1976 CB550 K
« Reply #6 on: October 31, 2005, 10:01:49 AM »
Yeah, what the person above said! But, put our caliper in a plastic bag and pump your brakes! It'll jump out! Don't worry! It's nothing nothing crazy like a bullet, just a pop.....
Nomad
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
gary delaney
« Reply #7 on: November 01, 2005, 01:06:22 PM »
Once again...Thanks to all.
Will try air first, then grease, then reconnect cylinder.
Until nxt time, Gary
