Author Topic: Coils and Wires  (Read 1581 times)
fpixley
Coils and Wires
« on: October 31, 2005, 03:13:35 AM »
What coils will interchange on the SOHC 750?  Preferably something with replaceable wires. ???
eldar
Re: Coils and Wires
« Reply #1 on: October 31, 2005, 08:08:40 AM »
Well a common coil replacement is a coil from a cb750 from 1979 on tp 82 or something like that. The same coil is on the cb 900. These are 3 ohm coils so spark will be stronger and may go through points quicker if you still use them. If you use electronic then the performance will be better but you may or may not notice much difference.
The wires are replaceable also.
fpixley
Re: Coils and Wires
« Reply #2 on: October 31, 2005, 01:41:22 PM »
Eldar,
That's pretty much what I wondered.  Are the stock coils 5 ohm?  And is the bracket a direct bolt-on?  Actually I am still running points ignition, I even bought a new assembly mounted on the backer plate for replacement when necessary. :-\
Offline dusterdude
Re: Coils and Wires
« Reply #3 on: October 31, 2005, 01:47:19 PM »
stockers are 5 ohm
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
Re: Coils and Wires
« Reply #4 on: October 31, 2005, 01:54:53 PM »
There may be some modification. I do not know since I have not done it yet. I am going to sometime though over the winter.
Offline cben750f0
Re: Coils and Wires
« Reply #5 on: November 01, 2005, 03:41:29 AM »
or some vf1000 coils...
