Author Topic: Inline fuel filters  (Read 3530 times)
Offline Johnny5
    • CB350F build thread
Inline fuel filters
« on: May 09, 2009, 02:02:40 PM »
I have one of these filters installed. Just curious if they are effective enough to keep my slow jets clear?
I ask because I've always had one installed, and the slow jet on the 2nd carb was clogged after a good cleaning after my third short ride.
If the filters do a good job, then I must have missed a section on that carb when I cleaned them. The other three slow jets were clear.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
TripleDeuce
Re: Inline fuel filters
« Reply #1 on: May 09, 2009, 02:17:06 PM »
I run the same filter on my 650. the last time I pulled the carbs I found an alarming amount of crap in my bowls, no clogging, yet. I will be changing to a larger paper element soon.
Offline hymodyne
« Reply #2 on: May 09, 2009, 03:09:45 PM »
+1 on crap in bowls with this type of filter. I think paper filter element is the way to go...
hym
Offline Johnny5
« Reply #3 on: May 09, 2009, 03:20:29 PM »
Sounds like I'll be changing also.
Thanks,
1971 CB350
1973 CB350F
Offline TheHun
« Reply #4 on: May 09, 2009, 05:37:35 PM »
I got a filter 1/4" from autozone...last time I took my carbs off...it was spot clean...not a single grain of dirtyness...paper filters are the best in my opionion
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
crinklesmith
« Reply #5 on: May 09, 2009, 06:09:25 PM »
Thanks for the heads up, I'll go for the paper from now on.
Spillman
« Reply #6 on: May 09, 2009, 06:28:29 PM »
ya these don't seem to work all to good. there just a generic filter and thats what I had on my bike.
Offline jeepster
« Reply #7 on: May 10, 2009, 07:58:57 PM »
Do you remember the brand/model?
"An ounce of prevention is worth more if you break it up into nickel bags."
Offline Johnny5
« Reply #8 on: May 10, 2009, 08:07:08 PM »
I'd like to know too. I went there today and could only find a large filter for 1/4".
1971 CB350
1973 CB350F
Offline tlbranth
« Reply #9 on: May 11, 2009, 10:03:04 AM »
Got mine at the John Deere tractor shop. They seem to work OK. I think the element is paper
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Old Scrambler
« Reply #10 on: May 11, 2009, 11:12:31 AM »
You have several threads going about fuel and carb issues..............they are all inter-related.  #1.......If you have a dirty tank.......fix it.  A good radiator shop that also fixes gas-tanks can clean the tank, pressure test it, and install a modern liner that will withstand ethanol for less than $100.  I live in the land of the cheap and pay less than $50 including pin-hole repair.
The fuel filters slow the flow and impede the carbs from performing at their best under all throttle conditions.  When the filter is doing its job, it loses flow capacity over time.  #2......The fuel line ID must be the same as stock or the bowl filling rate will be wrong.  Your high idle could be caused by a temporary vacuum in the bowls that will cause the available fuel to be sucked into the main jet until enough fuel gets to the bowl.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: May 11, 2009, 12:58:40 PM »
The float bowl vents prevent any of this from happening or becoming a problem.  Also, even with an in-line filter, the maximum fuel flow rate is much more than the carbs could ever use even at the fastest speeds.  Sure a clogged filter would impede the flow of gas, but so would a clogged petcock filter or screen.
I've said it before and I'll keep saying it whenever necessary:  An in-line fuel filter, if fitted properly and installed on properly routed fuel lines will cause zero problems with fuel delivery.
« Last Edit: May 11, 2009, 01:02:51 PM by Gordon »
Offline Johnny5
« Reply #12 on: May 11, 2009, 01:03:31 PM »
From my other thread, everything is clean, carbs, new filter, and tank. My issue with the revving is happening in neutral as well as at speed. Plus, I've used these inline filters forever without seeing this issue. Im sure it's the carbs out of sync. Will report later on tonight.
1971 CB350
1973 CB350F
Offline lordmoonpie
    • Moonpie
« Reply #13 on: May 11, 2009, 01:52:33 PM »
Shhhh! Don't speak too loud or you'll wake Two Tired up and he'll notice this thread too  :D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
