Author Topic: Carb Sync Tools - which one?  (Read 8871 times)
MotoMartin
« on: June 02, 2009, 11:45:29 PM »
Hi Guys,
I'm bringing a beater (can't say Rat Bike anymore - no skulls) 750F2 back to life. I'm hoping that syncing the carbs is the final magic act that will smooth out some of the roughness per enthusiatic claims on this site. Anyway which of these two tools do I want to get? For ease of use for someone who hasn't used one before and acuracy. Actually I'd rather borrow someone else's (I'm in Oceanside, So. Cal drop me a pm if you have one locally). Keep in mind we are in a deep recession, this is a $500 bike, and I'm not going to be earning a living with this tool. (Don't recommend the $1,000 digital gold plated Snap On gizmo).
Gauges
http://cgi.ebay.com/ebaymotors/Carburetor-Synchronizer-carb-sync-Gauge-CB-450-500-650_W0QQcmdZViewItemQQ_trkparmsZQ7c301Q3a1Q7c293Q3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem588162ab4cQQitemZ380127849292QQptZMotorsQ5fAutomotiveQ5fTools
Manometer
http://cgi.ebay.com/ebaymotors/Carb-Sync-Mercury-Tuner-W-5-6mm-adapters-Motorcycle_W0QQcmdZViewItemQQ_trkparmsZQ7c301Q3a0Q7c293Q3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem5881223d30QQitemZ380123626800QQptZMotorsQ5fAutomotiveQ5fTools
Offline Hush
Re: Carb Sync Tools - which one?
« Reply #1 on: June 03, 2009, 01:19:04 AM »
The only model I can find for 4 cylinder bikes costs $200 kiwi so I'll probably get it done by my mechanic.
redschwa
« Reply #2 on: June 03, 2009, 01:34:23 AM »
Are you saying niether of MotoMartin's options will work?
Offline Joe Mig
« Reply #3 on: June 03, 2009, 03:57:44 AM »
Could  you use a automotive vacuum gage and do one at a time  and go back and forth?
"If everything feels undercontrol...you are not going fast enough"
Offline Lars
« Reply #4 on: June 03, 2009, 04:04:06 AM »
Highly recommended.
http://www.carbtune.com/
Lars
...if you got the ability to act...
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #5 on: June 03, 2009, 04:29:46 AM »
You really can't.  To balance carbs you need to know the relative vacuum of all 4 carbs at the same time.  To adjust one carb affects the vacuum on the other three.  So trying to set one carb to a specific value that used to exist at another carb would be a never ending exercise.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: June 03, 2009, 06:27:33 AM »
161.00 NZ dollars to your door from Z1.
« Reply #7 on: June 03, 2009, 06:51:12 AM »
Highly recommended.
Lars
+1
get the locknut and screw adjuster tool too!
« Last Edit: June 03, 2009, 07:14:09 AM by flybox1 »
Offline Johnie
« Reply #8 on: June 03, 2009, 06:56:40 AM »
You will see a lot of guys here with the Morgan Carbtune.  Cost under $100 and very reliable.  You can check it online.  Do a search on the board here and you will see it comes up a lot.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline ev0lve
« Reply #9 on: June 03, 2009, 07:47:10 AM »
+3 Morgan Carbtune. I know that doesn't answer your original question but...
Looks to run $101.82 with the pouch today.
http://www.xe.com/ucc/
Make sure to get the brass adaptors as well - if not from them then try Z1
http://www.z1enterprises.com/detail.aspx?ID=3263
Well worth it  ;)
Offline IHWillys
« Reply #10 on: June 03, 2009, 08:38:34 AM »
I've somehow gotten by using one of the cheapy mercury manos like in the $40 ebay auction there.  But I'm jealous of these other guys' Morgan...hehe.
On a $500 bike, a $100 tool can hurt but will this be your last bike?  Probably not.  I purchased the aforementioned mano nearly 20 years ago.  It works as good today as it did then and has been connected to a few bikes between then and now.
Ken
Offline bozo4onion
« Reply #11 on: June 03, 2009, 08:45:50 AM »
+4 Carbtune. Way cool tool. Just really fun to use.
Offline Popwood
« Reply #12 on: June 03, 2009, 09:48:30 AM »
Make that +5 for Carbtune. Good service too. Mine arrived in about a week. Have used it on several bikes, not just 4's with good success, always. Do get the brass inserts. I didn't, and the plastic ones have worked fine, but I'm sure the brass would last and last.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline bender01
« Reply #13 on: June 03, 2009, 09:58:05 AM »
  Thats the one I have and it works good for me.Its not like I am a bike mechanic so it will last me a long time! Just dont let the rubber hoses dangle onto the headpipes.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline ratSOHC
« Reply #14 on: June 03, 2009, 10:20:53 AM »
Anyone know if there's a Carbtune supplier in Canada.. or are they only driect from the UK?
Offline Johnie
« Reply #15 on: June 03, 2009, 10:35:07 AM »
Only UK on line is your best bet.  Their shipping is really fast.
Oshkosh, WI  USA
MotoMartin
« Reply #16 on: June 03, 2009, 11:13:56 AM »
Has anyone used the $40 manometer? Your feedback would be appreciated.
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
« Reply #17 on: June 03, 2009, 02:33:49 PM »
I've used the mercury manometers and still have one sitting in a dark corner of my garage.  I think it is a little short of mercury - partly from the stuff being sucked into the engine and partly due to a spill.  For the $50 difference, I'd go for the Carbtune - it'll work as well or better, last longer, and not have the toxic substance issues - think of the day when you might want to dispose of it - you'll get back more than half your money selling the Carbtune; you can't ship the mercury manometer and will likely end up taking it to a toxic waste disposal center to get rid of it.
Offline bikebitzofvt
« Reply #18 on: June 03, 2009, 02:45:07 PM »
I've used the same set of mercury filled sync gauges for 20 yrs.  8 yrs as a line tech at dealerships in CT.  I've never had to refill them or had them "suck mercury" into the engine.  You simply can't blip the throttle with them attached.  However, I see they're becoming very hard to find (likely 'cause of the mercury content)
Just my .02
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
gregory1975
« Reply #19 on: June 03, 2009, 02:50:02 PM »
I have the one from your first link.  It worked well for me, shipped quickly, and was fairly cheap.  I might be lying to myself but I would like to believe that it's not a uni-tasker either like I suspect the carbtune would be.
« Last Edit: June 03, 2009, 06:19:58 PM by gregory1975 »
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #20 on: June 03, 2009, 03:21:15 PM »
I made my own, It worked good. Used aquarium tubing, welder tips for restrictors, and bought the 5mm adapters from california sport touring. In the end, I would just buy the 40 dollar mercury off ebay. I didn't save too much, and that seems like it would work just fine.
Tubing 50 feet:         $6
3 way adapters:        $4
Restrictors:              $7
Adapters (shipped):   $15
If you figure in zip ties, and ATF fluid, it cost more, but as is, it cost $32. PAY THE EXTRA 10 BUCKS FOR THE NICE SETUP!
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
gregory1975
« Reply #21 on: June 03, 2009, 07:35:47 PM »
Factor in accuracy and pain in the ars factor and I definitely say buy one my dizzle..
Offline Pawsoff
« Reply #22 on: March 25, 2010, 11:15:45 AM »
I just ordered a morgan carbtune now, came to just under $100 Canadian, I will let you know when it gets here and how well it works.
Pawsoff
1977 CB550F
On the road, slowly improving the bike :)
