Author Topic: Dyna 3 ignition dead?  (Read 1679 times)
550_ko
« on: November 08, 2005, 03:29:01 PM »
Hello all.  Turns out that the yellow wire coming out of my dyna 3 ignition module was pinched between the seat and the bolt that grounded the module.  Today it finally rubbed through, and now whichever coil is attached to the yellow wire won't fire.    Both coils fire off of the blue wire and all the connections are clean and tight.
Is the module  truly dead?
Does anyone know of a bench test procedure?
Is replacing it the only option?  And if so, is the dyna s any better or worse (it's substantially cheaper).
Thanks.
Offline ofreen
Re: Dyna 3 ignition dead?
« Reply #1 on: November 08, 2005, 03:56:08 PM »
Thanks.
The Dyna S is nice because the whole works is contained under the points cover.
Greg
'75 CB750F
Greg
'75 CB750F
Offline dusterdude
« Reply #2 on: November 09, 2005, 06:10:35 AM »
isnt the dyna 3 a "computer" controlled system and dyna s still uses the mechanical advance
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #3 on: November 09, 2005, 07:21:25 AM »
cool,i thought i read somewhere that dyna has a system that uses a computer type deal that controls timing and replaces the advance unit.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline n9viw
  • Floyd, '76 CB550k
« Reply #4 on: November 09, 2005, 11:43:34 AM »
I think that's the Dyna 1000.
Nick
'76 Honda CB550k
'73 Honda CB750k
Offline dusterdude
« Reply #5 on: November 09, 2005, 11:55:35 AM »
groovy and floyd do you have any bigger pics of the bike in your avatar
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #6 on: November 09, 2005, 12:08:32 PM »
See my email Jorge, Dynatek can probably repair it, or provide you with a new module, up to you, if you decide to "chuck" it, and buy a new "S", then chuck it my way, one of my guys is a technician who can fix anything! Cheers, Terry. ;D
