Bryan, I regard you as one of the more technically astute contributors to this worthy tombe, so don't think that I'm questioning your profound wisdom for one moment, but could you explain to me the advantages of ball over roller bearings, in relation to their relative uses in headstocks and swingarms?
If tapered rollers are more suited to wheel bearings, (continuous rolling) then why are our Honda wheel bearings of the "ball" variety? To go a step further, all the bicycles I've owned have rolled along on "ball and races", which your post suggests would be better in headstocks, and perhaps swingarms?
It's been my experience that the swingarm sleeves wear due more to no grease/water ingress, I really can't see how a bronze, plastic or even mild steel bush will wear slower against a hardened steel sleeve? Most of the ones that I've seen are badly rust pitted, like the top 8 inches of early CB750K forks, where the factory decided to save 10 cents on hard chrome per unit? I used to "chuck" the pitted sleeves, but now I machine them on the lathe and turn up oversize bronze bushes to compensate. Cheers, Terry.
