Author Topic: Got (carb) boots?  (Read 1481 times)
Offline turboguzzi
Got (carb) boots?
« on: June 19, 2009, 06:42:23 AM »
Buongiorno,
Need new rubber boots/sleeves/connectors for the VERY nice 29mm Keihin CR's I found on THAT auction site.
These carbs are going on my CB500 racer and there are no off-the-shelf, bolt-on rubber flanges to be found, gonna have to turn on a lathe my own inlet stubs and connect the carbs to them with rubber boots.
Just before ordering special (read expensive) boots from SUDCO/Allen's/etc., was wondering if there are any stock Honda (or other make) boots that i can get off the shelf at David Silver or such, maybe a CB650's, CB750 DOHC?
These are more or less the dimensions, the retaining bump's shape doesn't really matter as I am making new stubs anyway and can modify the Keihin screw-on connectors to suit.
Can people measure any stock boots that they may have in the workshop?
Cant wait to bolt these CR's on and see if they make any difference compared to my trusty 26VM's
Cheers & Thanks
TG
« Last Edit: June 21, 2009, 10:23:24 AM by turboguzzi »
Offline turboguzzi
Re: Got boots?
« Reply #1 on: June 21, 2009, 10:21:08 AM »
Gee.... not my style to bump my own postings but with the pace that threads are pushed back, got no choice
would really appreciate any feedback on this,
Grazie 1000
TG
Re: Got (carb) boots?
« Reply #2 on: June 21, 2009, 01:33:36 PM »
About the only thing I can help with is to to keep this up front for a bit.
Good luck.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #3 on: June 24, 2009, 03:16:00 PM »
I just measured a set of 650 boots (uknown year, unfortunately... I think they were for '79-80 slide carbs) and they're really close to your drawing. Not measuring the raised sealing ribs, I get 34mm on one end, 37mm on the other, with 29mm in the middle. Hope that helps!
Paul
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline turboguzzi
« Reply #4 on: June 26, 2009, 11:54:20 AM »
hi paul
thanks for that
BTW, looks like its the jinx season.....
one friend pulled a cyl stud on his R80G/S
another broke a drive shaft in his  R1100G/S
and in my own GSXR750 streefighter one carb is flooding, ended up with the cranckases full of gas...
TG
Offline paulages
  • 1976 cb735
« Reply #5 on: June 26, 2009, 12:39:00 PM »
hi paul
thanks for that
TG
damn. let's hope the trend turns!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« Reply #6 on: June 26, 2009, 01:39:22 PM »
I just bought some booties for the 650 100 beans for 4 from honda. Hope they fix some of my nagging issues.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline turboguzzi
« Reply #7 on: June 26, 2009, 02:41:42 PM »
hope they work for you bobber
mind measuring them to sse if they match the dimesnions I need and tell their part number?
paul could figure out which year where his, so am afraid of ordering the wrong ones, so it could help
thanks
TG
Offline Alan F.
« Reply #8 on: June 26, 2009, 02:47:52 PM »
Well as long as nobody gets hurt, the bikes can always be repaired. It's only time and money after that.
Offline Hush
« Reply #9 on: June 26, 2009, 03:59:02 PM »
I looked at using custom radiator hoses when I was looking for carb isolators for my CB650, they would have fitted too but I got some practically new ones off another forum member.
Offline turboguzzi
« Reply #10 on: June 28, 2009, 01:40:13 AM »
huff
that's always an idea, thing is that since i run filter less,
i need the internal ridge to hold the carbs
TG
Offline paulages
  • 1976 cb735
« Reply #11 on: June 28, 2009, 12:53:46 PM »
huff
TG
TG-
sorry, didn't make it back to the shop all weekend. i'll be down there today and will get some specs for you.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
