Author Topic: quick suzuki two stroke question  (Read 1542 times)
Offline zoo mob
« on: June 26, 2009, 12:44:45 PM »
My buddy picked up a 1970 Suzuki T250 two-stroke street bike and we're trying to get this thing on the road. It will start with starting fluid blown in the carbs and run if you keep it throttled. If you let the gas off, put it in gear or turn the choke off, it dies, also, when you are starting it, gas blows out the back of the carbs. Clearly, the carbs need to come off and be soaked, blown out etc. Can you guys offer any advice as to what these symptoms speak to as a root problem? Thanks, looking to get this little screamer on the streets soon.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: quick suzuki two stroke question
« Reply #1 on: June 26, 2009, 12:58:19 PM »
Carbs and mixture. Clean carbs. Run with proper intake restriction.
No.
Offline Hush
« Reply #2 on: June 29, 2009, 04:12:12 AM »
I owned the bigger brother in the 70's the T350 REBEL very fast very much fun and only out matched slightly by the famous RD350 Yammie, we don't count he 350 Kwaka as not many of those hand grenades survived initial run-in milage. :D
As Mlinder said get em off get em cleaned out, very forgiving carbs on those early model Suzukis, I'd be surprised if you even needed an air filter.
Once set the carbs are bullet proof and need nil adjusting.
Stock standard the T250 HUSTLER could do the ton any day you asked it. ;D
God I love the sound of those long twin chrome pipes, there is just something about them, the T500 TITAN had the best ones, what a great noise. (owned 2 of those)
« Last Edit: June 29, 2009, 04:15:11 AM by Hush »
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #3 on: June 29, 2009, 02:41:02 PM »
Dangit, now I want to get the GT500 apart and running.
Yeah, older Suzuki's are tanks. Pull the carbs and clean them, you'll be ready to rock after that. Good luck with it, I'd love to get a 2-stroke on the road.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Hush
« Reply #4 on: June 29, 2009, 02:46:58 PM »
Pictures Sporkfly I now demand pictures of your old Titan. :)
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #5 on: June 29, 2009, 02:48:04 PM »
You don't at all, it's been in the woods for about 15 years and won't be a restoration by any means :(
1977 CB550K
1979 CX500
Offline Hush
« Reply #6 on: June 29, 2009, 05:09:22 PM »
No but they make great drag bikes. :D
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #7 on: June 29, 2009, 05:57:18 PM »
I'm thinking street tracker :D
1977 CB550K
1979 CX500
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #8 on: June 29, 2009, 06:03:24 PM »
sounds just like the 72 titan i recently acquired
Mark Twain - Notebook, 1894
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #9 on: June 29, 2009, 06:30:52 PM »
I know a guy that had reverberation in the intake on his piston-ported Kawasaki. He lengthened his intake stacks and solved the problem. also check for leaks at the carb mounts or between crank case seals on multi cyl engines...
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
