Author Topic: interchangeability of CB master cylinders  (Read 970 times)
Offline ltrr1971
« on: July 01, 2009, 11:13:01 AM »
My question is does all the CB four cylinder bikes, 350f,550f,750f up to 1976 use the same master cylinder and it's internal parts?  I thought that they were all the same but am not sure.  I have a 76 750f, 76 550f, and a 73 350f and would like to rebuild all three masters starting with the master from the 76 750f and then putting it on the 350f while I do one of the others.  I picked the 750f master as first as the bike is waiting to rebuilt and the 350f is running but needs a master cylinder rebuild.  Also, which brand and where to get the rebuild kit?  thanks!
Offline d_soles
  • My two girls...
Re: interchangeability of CB master cylinders
« Reply #1 on: July 01, 2009, 11:43:03 AM »
Well, let me put it this way.
My 1973 CB500 parts bike has the old metal, cylindrical shape MC with a twist on cap.
My 1975 CB550F has a nasty little plastic-box looking MC, with 4 screws holding the cover on.
But, I'm going to downgrade to the better looking old style.  The plastic box on the 550 is disgustingly disintegrated.
Doug
'75 CB550F - Field Beater at it's best....
Offline ltrr1971
« Reply #2 on: July 01, 2009, 12:35:50 PM »
The ones I'm referring to have the cylindrical shape with the twist on cap.
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #3 on: July 01, 2009, 02:48:13 PM »
I have the one with the plastic body.  When I got the rebuild kit it came with a new cup, cap, screws and O ring along with the internals for the master cylinder.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
« Reply #4 on: July 01, 2009, 02:50:10 PM »
ltrr,
I'm assuming you are using one of the online microfiches to cross reference parts between bikes?!
ie http://www.motogrid.com/pages/parts/viewbybrand/7/default.aspx
Order the rebuild kits from Honda! I prefer ServiceHonda.com due to their discount and excellent service. They have another website address for ordering too but I do not have it tagged.
« Reply #5 on: July 02, 2009, 06:50:40 AM »
Only the GL1000 and the 77/78 750F have different cylindersand whoever has the square bodied mast on the 55F it aint original
Offline d_soles
  • My two girls...
« Reply #6 on: July 02, 2009, 06:55:37 AM »
Wouldn't surprise me, I've found a lot of....fun.... on my bike from the PO...where is the square bodied MC off of, then?
Doug
cycleman
« Reply #7 on: July 02, 2009, 07:02:29 AM »
What matters is if the bike is a single disc or dual disc.  The piston size in the master cylinder is different.  Usually a 16 mm or bigger for dual discs & 14 mm for single discs. Match the master cylinder to your brake system.
Other than that its just cosmetics.  Whatever suits your fancy.
Offline Laminar
  • Retsam
« Reply #8 on: July 02, 2009, 07:05:43 AM »
Doug
It could just be a generic master cylinder, but the '80s Hondas all came with square master cylinders that should be a direct swap as long as you're getting one from a bike with the same brake setup (single/dual calipers).
« Reply #9 on: July 02, 2009, 07:08:51 AM »
May not even be Honda, probably just what he had lying about or available in breakers
