Author Topic: Taking engine out question/s  (Read 1561 times)
Offline turninwheels
« on: July 16, 2009, 09:46:47 AM »
It seems to me to be easier to lay the bike on its side and take thre frame off rather then right side up to take the engine out...would you agree?  I know I'll need to take off the oil filter housing, disconnect the oil lines...any other suggestions...
"high powered suicide machine."
Offline Johnny5
    • CB350F build thread
Re: Taking engine out question/s
« Reply #1 on: July 16, 2009, 10:53:34 AM »
Take off the breather cover too. There's three screws for it.
Then, get a buddy to help inch the motor over a couple inches (it helps big time), then lay on the side and the frame will slide pretty easily off the engine.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: July 16, 2009, 11:09:10 AM »
There is at least one thread with some pics about taking it out this way. I'll let you search for it if your interested.  :)
Offline 736cc
« Reply #3 on: July 16, 2009, 04:19:16 PM »
 Remove drivechain, wires, starter motor etc. Centerstand helps. Put a car jack under oil pan w/ a 2x4 between them. Just crank the jack up till it BARELY supports the motor. Then pull the long motor bolts, use a drift to tap them thru. Don't bang on bolts w/ a hammer unless you have a nut screwed on to them. Have a 2nd person handy (to help drink beers). Get on left side of bike , lean over and lift, and have 2nd person grab the kick lever. Drop it on a milk carton. Sometimes they come out very ez. The floor jack can help lift all the while. Gotta get the rear of motor up.
[/URL][/img]
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #4 on: July 16, 2009, 04:24:35 PM »
[/URL][/img]
+1000
Mark Twain - Notebook, 1894
Offline Magpie
« Reply #5 on: July 16, 2009, 04:26:09 PM »
Removing the exhaust spigots will give you a little more play room and save scratching the frame  up more.
Cliff.
Offline noahspop
  • 1977 CB750F2
« Reply #6 on: July 16, 2009, 04:42:56 PM »
[/URL][/img]
"before we start working you better have a beer in your hand, cause if something goes wrong, we can always blame it on the beer"
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #7 on: July 16, 2009, 04:50:42 PM »
I take out the exhaust studs, pull the chain, and all the bolts, pop the wiring harness plug and pull the sparkplug wires, pull the carbs, then lay it on an old chair cushion with a large metal plate and a floorjack and 2x4 chunks under the clutch housing  and jugs to shim it up
then I gently moved the frame around to get it up off the motor (with the help of my wife)
Offline Old Scrambler
« Reply #8 on: July 16, 2009, 06:25:48 PM »
Since you have to drain the oil.......I also remove the sump drain plug for more cleanance.  Have done both ways and by myself.  Take it easy and tape the frame.  I use grocery bags to prevent scratches.  When re-installing........it helps to have the front left motor mount bolt ready.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
  • Like a well oiled
    • Undead Asphalt
« Reply #9 on: July 16, 2009, 06:50:30 PM »
oh yeah i forgot the oil plug and filter. instead of tape and such,  I use clear pvc hose from lowes and split it.
Offline Magpie
« Reply #10 on: July 16, 2009, 07:31:57 PM »
Good wife you have there Brian!
Cliff.
