I have a CB750 K5. I have my master cylinder and brake hoses taken apart, so I can't use them to push the piston out to remove the brake pad. I tried using compressed air according to oldmanhonda, but so far that hasn't worked. There is a bolt that is inset between the top of the pad and the top of the caliper. Does this bolt have any function for holding the pad in? Using a screw driver, I can turn the bolt approximately 1/3 of a turn. Any suggestions besides hooking it back up to pump it out?
Enforcer
