Author Topic: Axle cap holders (front)  (Read 2000 times)
« on: July 24, 2009, 02:13:51 AM »
In HondaMan's Tips & Tricks Aligning the Front Forks I read
They should be flat and even at the back side with a (parallel) gap on the front side. Tighten the rear sides first, then the fronts. The caps are DIRECTIONAL: they have a HI and LOW side to them. The gap side must be in front.
I always thought it was the other way around. Tighten the front sides first, then the rears and - as a result - gap will be in the rear. Cf. various Owner's Manuals.
« Last Edit: July 24, 2009, 02:26:20 AM by Deltarider »
Offline jaknight
  • ....Round Town Ride......
Re: Axle cap holders (front)
« Reply #1 on: July 24, 2009, 07:52:37 AM »
Hi Deltarider,
I questioned Mark, HondaMan, about this around 4 years ago.  Below is what he emailed me.... I thought it was fascinating:
"Yes, the gap should be to the front. I've seen many manuals with the things reversed in the pictures, too, as well as on a lot of bikes. I always switched them when they came through my arena, though. The stress "lift" from the bump travel is designed to go up the rear edge of the fork tube, which should have the solid mount."
"I got this straight from a Honda suspension engineer in 1973 or 1974 in Illinois. He was helping us with the Production roadracing stuff, and was quite sure to point out to us that we had them both ways on the 4 different bikes we were using that day. We changed them all to the rear, at his direction. On some bikes (I think it was the CB350 twins), the front studs were shorter than the rear, which was further indication of what he was pointing out to us."
"When I ran the shape of the structure through a stress program (it was an early PC-based finite-element analysis program we used in the oilfield), it showed the shear stresses concentrated at the end-of-thread of the front stud when the gap was in the back, and vice-versa. Since the entire body of the fork tube is available to suppress a rearward-moving bump stress, it makes sense that the Honda guy wanted that extra strength "in the front" of the fork. The front stud has to bear both the initial impact and the rearward shear if it is tight, without gap. The program showed this load to be split between front and rear when the rear had no gap."
"Although, I've never seen one break in real life..."
Mark
___________________________________________________
~ ~ ~ jaknight ~ ~ ~
« Last Edit: July 24, 2009, 07:56:09 AM by jaknight »
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline jaknight
« Reply #2 on: July 24, 2009, 07:58:52 AM »
Bob Wessner,
Do you remember this one?  You were the go between Mailman!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: July 24, 2009, 08:00:29 AM »
I recall the question and discussion, but not the specifics of being a go-between. I'll take your word on it though.  ;D
