Author Topic: Re-zinc engine bolts  (Read 1238 times)
Offline mazingerzeca
« on: August 06, 2009, 06:25:50 AM »
Hello all.
Some of the engine bolts on the CB750 K7 I'm rebuilding are a bit rusty, and I was thinking on putting new zinc on them. I wonder if it would be a problem on the bolt threads, which could get bigger with the zinc layer, causing damage to aluminum engine threads.
Thanks for your help.
Re: Re-zinc engine bolts
« Reply #1 on: August 06, 2009, 06:33:43 AM »
Wire brush them down first, like with a wire wheel on a bench grinder or in a drill that's clamped to a bench. Then they should be fine. The threaded portion doesn't really need zinc where the nut or threads are going to be engaged, if you first oil or grease them (which should be done, anyway  ;) ).
« Reply #2 on: August 06, 2009, 06:35:20 AM »
You mean, after having them re-zinced?
« Reply #3 on: August 06, 2009, 06:51:52 AM »
Yep. Threads on bolts shuld always be oiled or greased before assembly. Few actually do this, but it makes torquing far more accurate.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: August 06, 2009, 06:54:59 AM »
Would a little anti-seize be as good as oil or grease?
« Reply #5 on: August 06, 2009, 07:06:47 AM »
Thank you. So, I will re-zinc them.
« Reply #6 on: August 06, 2009, 07:12:48 AM »
Anti seize is very good. moly-coat is fine, and I use a mild loctite where I expect extra vibrations. The point is to have the threads smoothly interface with each other so you get an proper torque value. I am sure you turned a bolt by hand and felt tight spots. After the bolt is properly seated the coating will help prevent the two disimiliar metals from reacting with each other and freezing the bolt in place.
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: August 06, 2009, 07:34:15 AM »
Coat them with Super-Alloy Z, they'll be indestructible!    ;D  Guess you're nowhere near Mt Fuji, though.
mystic_1
- John Augustus Shedd
